New break booster but pedal way down
Discussion in '1st Gen. Tacomas (1995-2004)' started by taco03Trd, Mar 8, 2023.
  1. Mar 8, 2023 at 6:30 PM
    taco03Trd
    taco03Trd [OP] 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    Quick info 03 v6 a/t
    New booster because original was making a whistle noise . Turns out inner seal was a bit torn not holding pressure.
    Installed rebuilt booster
    Bleed MC an lines an no assist from booster pedal goes down to the floor an a hear air went I press down on top of break pedal by fire wall .
    any ideas or I got a defective booster?
    Tia .
  2. Mar 8, 2023 at 6:35 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    sounds like its defective.
  3. Mar 8, 2023 at 6:39 PM
    Taco23Trl
    Taco23Trl Well-Known Member
    Brandon
    2023 Taco Trail Edition
    So far…. Added fog lights swapped halogens to led’s, interior lights to led’s, bed lights added, led/strobe brake lights, trying to figure out the right leds for turn signals.
    Did you replace or have to take fluid from the master cylinder? If so May need to bench bleed it to remove air from it as well, not 110% just a though
  4. Mar 8, 2023 at 6:47 PM
    taco03Trd
    Carlos
    Riverside ca
    Yes I drain the MC fluid was very dirty I did a bench bleed an after I install I crack open the lines at MC to take out air .
  5. Mar 8, 2023 at 8:02 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Bleed your MC
    1997tacomav6 likes this.
  6. Mar 9, 2023 at 6:52 PM
    taco03Trd
    Carlos
    Riverside ca
    I did with booster on or do I take it off again a redo the bench bleed ?
  7. Mar 9, 2023 at 7:07 PM
    ChargedSHOTaco
    Leave it on the truck.
    Put a vacuum on the system via the reservoir lid and let it sit about an hour. It’ll remove any air in the system.
  8. Mar 9, 2023 at 7:23 PM
    ChargedSHOTaco
  9. Mar 9, 2023 at 7:28 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    When you cracked the brake lines you allowed air into the system .
    Now bleed all 4 corners .
    Plus it sounds like you received a bad brake booster as well.
    Failed parts out of the Box are all to common these days
    taco03Trd[QUOTED][OP] likes this.
  10. Mar 9, 2023 at 7:40 PM
    taco03Trd
    Carlos
    Riverside ca
    Yes I bleed all 4 Conners with the truck on the pedal goes to the floor an a sound on top of the break pedal by firewall like a plunger very time I press it .
    I believe also is a bad booster it’s a reman one from china :crapstorm:
  11. Mar 10, 2023 at 1:21 PM
    Bivouac
    As long as your brakes were good before this adventure started.
    You did adjust the push rod on the reman Booster?? That could be your pedal travel or part of it.
    You have a leak drawing in air as well.
    Might be one of the bleeders it might be one of the lines at the master cylinders .
    You can draw air and not leak fluid.Which can have your reaching for the Gas can.
    Good luck!
  12. Mar 10, 2023 at 2:21 PM
    taco03Trd
    Carlos
    Riverside ca
    push rod I eyeball from my old booster try to leave the same distance. But I’ll try to adjust it again .
    Went I bleed my lines the MC work fine cuz it was pushing air out at my calipers an fluid was going out also .
    Crazy ima put my old booster an see what happens next just to rule out defective booster
    thanks .
