New Breather Assembly from ARB
Discussion in 'Off-Roading & Trails' started by Silver02Taco, Feb 4, 2014.
  1. Feb 4, 2014 at 2:04 PM
    Silver02Taco
    Silver02Taco [OP] #DevilHornGang
    Will
    San Jose, Ca.
    2002 Xtra-Cab 4x4, V6, SR-5, TRD Off-Road
    A few things happened, but it's not done yet.
  2. Feb 4, 2014 at 2:05 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Las Vegas, Nevada
    2003 Tacoma TRD 4X4
    Apparently it's $72...
    Could just relocate all of the breathers yourself with $30 worth of tubing and clamps...
  3. Feb 4, 2014 at 2:05 PM
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Safety Meeting
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
    cool idea but $72......
    damn, beat me to it
  4. Feb 4, 2014 at 2:07 PM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm
    i was going to post a thread about this but i figured someone would...
    so what's the word on this, worth it or not?
  5. Feb 4, 2014 at 2:14 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Harbor Freight 110v welder garage fab parts.
    10 bucks of tubing, a bit of RTV sealant and relocated mine in the cab.
  6. Feb 4, 2014 at 2:17 PM
    Silver02Taco
    Will
    San Jose, Ca.
    I know about the breather mods I've seen folks doing here, as mentioned, for a lot less then this kit is going for...
    But do those mods alleviate vacuum pressure as well, or just prevent you from sucking water in thru the breather (in the stock location) itself?
  7. Feb 4, 2014 at 2:19 PM
    SoCaltaco65
    wait vacuum pressure? what?
    its to keep the dirt and water from being sucked into the comp and ruining the locker.
    also, just do the diff mods, they work.
  8. Feb 4, 2014 at 2:23 PM
    ChamYota
    ChamYota Crash Bandicoot Or Groot, Just Depends
    Cam
    Clemson,South Carolina
    05 PreRunner and 2004 Lexus IS300 Sport Design
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    there's still going to be some guy who will buy this anyway..
    Aw well, i spent a little under 30$ and I'm good as gold.
  9. Feb 4, 2014 at 2:27 PM
    tacotundra
    tacotundra Well-Known Member
    They are on the right path ( give arb credit) You can hook up 4 trans axles ( front, rear,transmission and transfer case)..
    Tho for a kit like that i would want a valve in place to keep water from entering the unit itself (like a air dryer on Pneumatic) . Moisture alone can work it way down to gears without going off road over time....
  10. Feb 4, 2014 at 2:40 PM
    Silver02Taco
    Will
    San Jose, Ca.
    From the "Design and Development" section of the PDF from ARB:
    "A differential / axle breather serves the important purpose on a 4WD vehicle of venting the air pressure in drivetrain assemblies such as the differentials, transmission and transfer case. Under normal operations, these assemblies heat up and
    the air inside expands, increasing the pressure and thus the need to be vented to atmosphere is created. When the drivetrain
    assembly cools down the air inside contracts and creates a vacuum"
    :notsure:
  11. Feb 20, 2014 at 7:02 AM
    SoCaltaco65
    oh, got it, Vacuum and Pressure
