New bulb in turn signal...still fast click with no light
Discussion in 'Technical Chat' started by smolo2000, Jan 1, 2009.
  1. Jan 1, 2009 at 11:57 AM
    smolo2000
    smolo2000 [OP] Member
    02 Tacoma regular cab 4WD
    Hey -
    My left turn signal blinks very rapidly (except with emergency lights) and I'm not getting anything to light up in the front.
    I've replaced the bulb and still have a rapid-clicking turn signal with no light coming from the front (right works just fine)
    Any suggestions?
  2. Jan 1, 2009 at 12:17 PM
    Tman
    Tman Well-Known Member
    Woodstock, Georgia
    08 Silver TRD
    Stock (for now)
    Check the lamps/holders for corrosion build up .. a real problem in those and they add more resistance to the circuit..causing the flasher to weird out on you.
  3. Jan 1, 2009 at 12:29 PM
    Stu
    Stu Well-Known Member
    G'Ville, NV
    Taco TRD OR
    Not much yet, got a pretty good sound system w/ my custom sub box. Plan on adding more lights & a tool box.
    Could be the other way too, a short to the frame in the front turn sig wiring.
  4. Jan 1, 2009 at 1:01 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    is the rear light working??
  5. Jan 1, 2009 at 1:05 PM
    smolo2000
    Read light is working but blinks at the rapid pace.
  6. Jan 1, 2009 at 1:06 PM
    smolo2000
    what's the best way to fix? new turn signal fixture?
  7. Jan 1, 2009 at 1:31 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    Once I know the socket and bulb are clean and working I always use dielectric grease in those small bulb sockets, actually in all sockets, keeps corrosion and water out and a bulbs working.
  8. Jan 1, 2009 at 9:07 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    try putting a new fuse in. i have seen a fuse go bad and the lights will blink fast as hell. may be just a bad connection though.
  9. Jan 1, 2009 at 10:29 PM
    VooDooTrip
    VooDooTrip Defector
    Gilbert, AZ
    01' BSP S/C S-Runner
    S/C, URD fuel Upgrade, 2.2 Pulley, URD crank pulley, Truetrax locker, custom exhaust, plx, scangauge, D/P mod, amsoil drop in, 18x9.5 stern hyperblacks, ACA projectors, Grillcraft blackmesh, Performance Products valance, R/C Tails, B&M Short shifter, QA1 Coilovers all the way around, upgraded strut rod bars with heim joints, poly bushings everywhere lol, 1st model Streetacos bolt on four link!
    short to ground, meaning you have an exposed wire touching frame. or you could have another bad bulb.
  10. Dec 21, 2013 at 9:40 PM
    Mrogers33
    Mrogers33 The way is open, the time is now
    Columbus, OH
    03 doublecab 4x4 grocery getter
    Old thread i know, but having this same exact issue as Op. Been raining for the past week so cant really do electrical when its wet. Will check the fuses in the AM
  11. Dec 25, 2013 at 1:24 PM
    Mrogers33
    Columbus, OH
    Update for any similar user issues, new bulbs and fuses checked still rapid blinking no front signal, turns out wire became so brittle it is broken and hanging out the back of the light housing, does this require a whole new harness?
  12. Dec 31, 2013 at 12:22 PM
    Mrogers33
    Columbus, OH
    X2
  13. Dec 31, 2013 at 12:34 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2000 Prerunner TRD
    bilsteins, 2010 Tacoma 17" alloys w/265's, driveshaft mods, 1.25" hubcentric spacers.
    new harness, hardly, you can do a splice, but bear in mind if the insulation is bad you should go as far back on the harness as possible, then when fixed, tape the crud out of it for safety sake...
