New Bump stops?
Discussion in 'Suspension' started by SoCalBlack08, Dec 11, 2011.
  1. Dec 11, 2011 at 11:47 AM
    SoCalBlack08
    SoCalBlack08 [OP] Well-Known Member
    CA
    08 PreRunner DC
    So I was reading about how a 3" top plate spacer makes the shock bottom out before it hits the bump stops and possibly snapping it so, out of curiosity, I was wondering if longer/bigger bump stops like these or these would help with that. If it will which would be the right ones to get?
  2. Dec 11, 2011 at 11:49 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    That would solve the bottoming out issue, but would not solve the bigger problem with top plate spacers, which is that they allow your suspension to droop 3" further down that it was designed to do, which binds your ball joints.
  3. Dec 11, 2011 at 11:50 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    limit straps
  4. Dec 11, 2011 at 11:53 AM
    KPT
    09 Prerunner
    I don't think I've ever seen a truck with top plate spacers and limit straps but I'm sure it's possible.
  5. Dec 11, 2011 at 12:26 PM
    SoCalBlack08
    CA
    08 PreRunner DC
    dont those limit the shock when the suspension droops down and the bump stops limit it when its compressed?
  6. Dec 11, 2011 at 1:24 PM
    KPT
    09 Prerunner
    Correct. And if there are no limit straps, the down travel is limited by whatever loses its travel first, the shock or the ball joints on the control arms. With top plate spacers, the ball joints become the limiting factor.
