New Bushings for Light Racing UCA's.
Discussion in 'Suspension' started by pAP, Mar 9, 2012.
  1. Mar 9, 2012 at 8:47 PM
    pAP
    pAP [OP] ==========
    NJ
    11 Tacoma SR5
    ARB locker and OBA, All Pro front & rear bumper, All Pro IFS skid & modified t-case skid, Custom Trans Skid., 4x Innovations sliders, Custom tire carrier/bed bars, Warn Winch, Fox 2.5" Front coilover, Walker Evans 2.5" rear Shock, All pro Leaf, All Pro U-bolt flip, Baja Designs lights, PIA 510 lights, TRD exhaust cut back, Doug Thorley Pipe Bomb
    This should be the fix. Just pulled mine apart tonight. You will need a sawzal and a steady hand to get the old bushings out. Full write up when I am done.
  2. Mar 9, 2012 at 9:54 PM
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    2009 4x4 DC TRD Sport
    The only mod is a hole in my wallet!!!!!
    thank for the heads up....i bought a set of used LR UCAs and i'm going to get the new bushing before i install!!!! :)
  3. Mar 9, 2012 at 9:56 PM
    KalamaKid
    KalamaKid Well-Known Member
    Socialist Republic of Oregon
    same shit as everyone else
    Subbed
    Mine are starting to squeak more and more these days
  4. Mar 10, 2012 at 1:42 PM
    pAP
    pAP [OP] ==========
    NJ
    11 Tacoma SR5
    The ucas are being PC'd as we speak. I will have the new bushings installed tomorrow am and on the truck. :popcorn:
  5. Mar 10, 2012 at 1:50 PM
    udy2554
    udy2554 NORTHERN RED-NECK
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    Mine are about 16 months old with 25,000 miles on them. So far no squeeking or any other noises or looseness.:notsure::pray: I don't wheel alot, but they have seen alot of salt through 2 winters.
    Am I just lucky, or should I be expecting problems soon...?
  6. Mar 10, 2012 at 1:55 PM
    PICKSTACOMA
    PICKSTACOMA Well-Known Member
    Landon
    Penhook, Virginia
    06 Tacoma 4x4 dbl cab lb 4.0
    ARE MX Truck Cap, Flowmaster American Thunder Exhaust, K&N Cold Air Intake, Weather Tech( Digital Floor Mats,Bug And Side Window Deflectors), Scangauge II, Clearvision Solux Headlight/Foglight Bulbs, Redline Hood Struts, FJ Cruiser Foglight Switch, Illuminated 4x4 Switch, Rain X Latitude Wipers, Brighter Back Up Lights, Dome/Map LED's, Cup Holder LED's, Engine Bay Lights, Foglights On Anytime, Leather Seats With Front Heating Pads OME Lift With DAKAR Springs And LR UCA's, Rear Diff Breather Mod, A/C Drain Mod, Husky Mud Flaps, ECGS Bushing Kit
    Any order information yet?
  7. Mar 10, 2012 at 9:00 PM
    smuggiesrider
    smuggiesrider Well-Known Member
    CR
    Vermont
    Silver 10 Trd Sport DC 6spd
    Satoshi grille, ARE cap, Rubber Bed mat, TRD Quick-shifter, N-Fab step rails, Wet Okoles seat covers, Husky Floor Mats, Stubby antenna, AFE Pro dry Filter, Thule rack w/ Cargo box, Sportz SUV Tent, Custom fit Air Mattress for Bed, TRD cat-back exhaust, de-badged and Sockmonkey'd. Hella Black Magic 500s, Toytec ULK, Dakar OME leafs, LR Uca's.
    X2 :D
  8. Mar 11, 2012 at 12:14 PM
    pAP
    pAP [OP] ==========
    NJ
    11 Tacoma SR5
    And Done! Had to strip and paint them... they were a bit rusty and beat up after removing the old bushings. Its a relatively easy job. The biggest thing is you need a real steady hand when cutting the old bushing ring out or else you end up cutting the UCA bushing housing. I will have all the pictures and write up of the install later on.
  9. Mar 11, 2012 at 12:15 PM
    pAP
    pAP [OP] ==========
    NJ
    11 Tacoma SR5
    Give SPC a call. You can order directly through them.
  10. Mar 11, 2012 at 2:29 PM
    smuggiesrider
    CR
    Vermont
    Sorry to sound so noooob
    SPC? Specialty Products Company?
    Thanks, retard :rolleyes:
  11. Mar 11, 2012 at 2:47 PM
    pAP
    pAP [OP] ==========
    NJ
    11 Tacoma SR5
    Yes. That's correct. They develope and fabricate the Light Racing UCA's.
  12. Mar 11, 2012 at 5:53 PM
    pAP
    pAP [OP] ==========
    NJ
    11 Tacoma SR5
    Tanx. Funny thing is, my steering wheel needs to be clocked now. I dint jostle anything else and set the camber and caster exactly the same as I had it before. O well... Back to Daves... good thing we like him over there.
  13. Mar 11, 2012 at 6:58 PM
    pAP
    pAP [OP] ==========
    NJ
    11 Tacoma SR5
    I just updated the first post with the How to.
  14. Mar 12, 2012 at 6:53 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    Nice, Chris! I'm going to order a set for mine.
  15. Mar 12, 2012 at 7:47 PM
    #35
    pAP
    pAP [OP] ==========
    NJ
    11 Tacoma SR5
    do it! :D
  16. Mar 12, 2012 at 10:54 PM
    #36
    sytfu510
    sytfu510 INSTAGRAM: sytfu510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit DMZ LT Kit TRD Supercharger SCS Wheels BAMF
    dam just installed mine a couple weeks ago. Guess I'll order the kit and install it at a later time.
  17. Mar 13, 2012 at 5:04 AM
    #37
    pAP
    pAP [OP] ==========
    NJ
    11 Tacoma SR5
    You may never need the kit. I would only replace them if the ones you have go bad. I got 70k+ miles out of mine.
  18. Mar 13, 2012 at 6:31 PM
    #38
    pAP
    pAP [OP] ==========
    NJ
    11 Tacoma SR5
    FYI- The replacement bushings are now on SPC's site. It seems there are two different UCA's so there are two different part numbers, you may want to check with SPC as to which one to order if you don't know. The part numbers are 25466 and 25476. You can plug them into this web page > SPC They also have the installation instructions listed as well > Install Instructions A lot better than mine. :eek:
    They also have the replacement boots available as well. That part number is 25477.
    The Bushing kit ended up pricing at $25 and the ball joint boots are $6 for the set with NO shipping charge on them!
  19. Mar 13, 2012 at 7:04 PM
    #39
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Thanks for the update! bushings and boots for me then. my boots are all torn up :eek:
  20. Mar 15, 2012 at 7:23 PM
    #40
    DR Da_da
    DR Da_da Infrequent Member
    Northeast FL
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    Man, I have a new set of LR UCAs sitting here ready for me to install them. I'm debating whether to get the new bushings or simply install the UCAs as they are. On one hand I'd like to know it's done and that I won't have to mess with them in the future. However, I'm not too confident I'd be able to cut the old bushings out without marring the UCAs. Had I only waited a few more weeks to buy . . . I hear they're now shipping with the new bushings already installed. :mad:
    By the way, it appears part #25476 are the replacement bushings for 2005-current LR UCAs and part #25466 is for 1996-2004 LR UCAs.
