New Bushings for Light Racing UCA's.
Discussion in 'Suspension' started by pAP, Mar 9, 2012.
  1. Sep 19, 2013 at 8:43 PM
    #121
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Theres your problem right there!
    Well no wonder I can't fix my cupping issue. I can wear em smooth (and out) fast enough on the rear of the truck though once I get this fixed.
    http://www.youtube.com/watch?v=BriRcqwAgZU&feature=share&list=UUKbfyhKk_LY2mT-q0IuVbxQ
    They lasted just shy of 2 years, this is just one side, drivers, other side seemed fine, couldn't get any play.
    To be fair, I'm hard on shit and while they are their redesigned bushings they're not spec ride. The first set lasted 8 months lol.
  2. Sep 19, 2013 at 9:03 PM
    #122
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
  3. Sep 19, 2013 at 9:12 PM
    #123
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
  4. Sep 28, 2013 at 2:55 PM
    #124
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    Well..
    Which way does the line on the pivot sleeves go (I only have one line)?! I put them facing outwards. No idea...
    It took me all of 10 minutes to get the UCA out.
    Took me a long as time to get that old bushing out.
    Took me no time at all to get it all back together and in.
    Stupid shitty old bushing.
  5. Sep 28, 2013 at 3:41 PM
    #125
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    I also packed the ball joint with some moly grease, the amount of factory grease in there was overwhelming... (not) but at least it was clean and no play in the joint.
    Only did one side.
  6. Sep 30, 2013 at 1:59 PM
    #126
    Alapai1
    Alapai1 Well-Known Member
    Kory
    Mobile, AL
    2011 DBLCAB Taco TRD Sport 4x4 lifted
    Toytec Ultimate Lift kit with Bilstein Adjustable coilovers
    I encountered the same exact thing. i replaced the uca bushings with the new spec ride ones and within a couple miles i heard the squeak again. how crappy. i wonder if it is because i tourqed the nut while the truck was on the lift? anyone have an idea?
  7. Sep 30, 2013 at 2:13 PM
    #127
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Did you use the supplied grease ?
  8. Sep 30, 2013 at 2:25 PM
    #128
    Alapai1
    Kory
    Mobile, AL
    i used plenty of the supplied grease
  9. Sep 30, 2013 at 2:43 PM
    #129
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Did you put grease on the sides of the bushings, where they ride against the washers? I have installed these myself, and have not had any issues.
  10. Sep 30, 2013 at 2:51 PM
    #130
    Alapai1
    Kory
    Mobile, AL
    i did not. i could have sworn the directions stated to wipe excess grease away but after looking again i see that i am wrong. if i loosed the nut and would silicone aerosole grease do the trick?
  11. Oct 2, 2013 at 8:39 AM
    #131
    Alapai1
    Kory
    Mobile, AL
    i just noticed that my spec-ride bushings are tappered on the inner lip. all of your guys pics dont have a the tapper. could they have sent be the spec ride bushings for another toyota? i cant find any good pics of other toyota spec ride bushing to compare mine to.
  12. Oct 3, 2013 at 9:52 AM
    #132
    Alapai1
    Kory
    Mobile, AL
    i think ive found my issue. my ball joints a making the noise not the new spec ride bushings. probably just need to buy the spc tool to separate the joints then clean and re grease them. anyone know if moly is ok to use on ball joints instead of regular chassis grease?
  13. Jun 3, 2015 at 6:49 AM
    #133
    replica9000
    replica9000 mildly retarded...
    Blackstone Valley
    2008 AC Sport 6spd
    Sorry to resurrect an old thread.
    My new bushings are in. I need to remove the old ones. Can I simply drill them out? I have the typical drill bits, and some hole saw bits. I'm still working on my tool collection, so a drill is my only power tool at the moment.
  14. Aug 30, 2015 at 7:03 AM
    #134
    schleygo
    schleygo Well-Known Member
    Daniel
    Ft Worth TX
    07 Dbl Cab Radiant Red
    Bilsten 5100s, Eibach Coils, 2" toytec AAL, LR UCAs, SC5 Matt Bronze
    Mine have 10k miles on them and driver side is already doing this like in the youtube vid. Time to order up new bushings =(
  15. Sep 12, 2015 at 3:59 PM
    #135
    schleygo
    Daniel
    Ft Worth TX
    Ok, about to tackle this. One question...........on above instructions, it shows you used 4 washers total per side. One on the inner and outer of each bushing. SPC's installation instructions say just to use them on the outside. What further confuses me, my spec ride bushing replacement kit came with 4 washers........
    SPC Instructions:
    Install the SPC control arm to the vehicle. note washer arrangement in the illustration – place one large washer on the bolt before insertion, and
    the second large washer just before the nut - then torque to manufacturer’s specifications. noteS: 1) the stock ‘dished’ washers are not
    re-used. 2) Unlike oe rubber bushings, SpecRide bushings pivot freely and can be torqued without applying vehicle weight.
    Is this right?
  16. Sep 12, 2015 at 4:06 PM
    #136
    11TRDTX
    11TRDTX Tennessee's whitest & craziest Puerto Rican
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    Yes. I literally just did mine today. I applied the grease around the edges where those washers ride to ensure no squeaking.
  17. Sep 12, 2015 at 6:05 PM
    #137
    schleygo
    Daniel
    Ft Worth TX
    Yes you followed SPC's washer instructions by using 2 per UCA or........
    Yes you used 4 washers per UCA?
  18. Sep 12, 2015 at 6:20 PM
    #138
    11TRDTX
    Memphis, TN
    2 washers per UCA. One on the bolt head side, the other before the nut
    schleygo likes this.
  19. Sep 12, 2015 at 6:26 PM
    #139
    schleygo
    Daniel
    Ft Worth TX
    Thanks a million. Here goes nothing.................................
  20. Sep 17, 2015 at 9:48 PM
    #140
    Dropitmore
    Dropitmore Panda Man
    Andy
    Long Beach, CA
    2013 TRD Sport - DCLB
    Accessory King
