New CA smog law for 2013
Discussion in 'General Automotive' started by whippersnapper02, Dec 21, 2010.
  1. Dec 21, 2010 at 10:05 AM
    whippersnapper02
    whippersnapper02 [OP] Well-Known Member
    Christian
    Yorba Linda, CA
    10 MGM TRD OR 4wd Auto DCSB
    Banks Monster Exhaust, Pop n Lock tailgate lock, Hook-Ups tie down brackets, USA Spec Ipod adaptor, WO seat covers, color matched grill with Grillcraft insert, Tuffy locking bed box
    So I just read that 2000 and newer vehicles in California will not need to pass a sniffer test starting in 2013. They will only have a diagnostic check through the OBD 2 port. If it doesn't pass then you go in for a sniffer test. Sweet. We can mod all we want and it will be fine as long as the CEL stays off.:D
  2. Dec 21, 2010 at 10:09 AM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
  3. Dec 21, 2010 at 10:29 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    The sniffer test was never the problem for newer modded vehicles. Most would pass no problem. It was the ridiculous "visual" inspection. Basically if they couldn't find a CARB sticker on your shit it would fail regardless of what the sniffer test says. Its pretty fuckin stupid. if you are below the level it shouldn't matter what you did to it, fancy sticker or not.
  4. Dec 21, 2010 at 10:33 AM
    whippersnapper02
    Christian
    Yorba Linda, CA
    Agreed. CARB certification is just another way for the state to ge money. The article didn't say anything about future visual inspections.
  5. Dec 21, 2010 at 1:04 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Cool. Link to source?
  6. Dec 22, 2010 at 1:03 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
  7. Dec 22, 2010 at 1:31 PM
    Trever1t
    Trever1t Well-Known Member
    Bay Area CA.
    '06 Basic Tacoma
    I am pretty sure the visual will still be enforced and like already mentioned it's not the sniffer that is a big deal, it's the visual.
  8. Dec 22, 2010 at 1:34 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    Yup:
    "The visual inspection will remain a component of California smog checks."
    All well. Pay the fucker off.
  9. Dec 22, 2010 at 1:43 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    10 PreRunner AC Sport Rally 5 Spd
    Tail gate hose clamp, Front Windows 50% tint, fog lights, 894 backup light mod, LED license & interior.
    Hopefully it will be cheaper now as more places will be able to perform the smog check because expensive machinery is not required. I like it.
  10. Dec 22, 2010 at 1:49 PM
    97T
    97T Resident T100 guy
    Melt
    Littleton, CO
    97 T100 xcab 5spd 2wd
    soundstream 550.2 amp, 2 eclipse 10" subs, 4% tint rear window, 20% sides, 6" sunstrip, clear bumper lenses, avital 4103 alarm with keyless, BF Goodrich Rugged Terrain T/A 235/75/15, 15X7 6-5.5 0C Unique 298 rims
    doesnt affect me, newest vehicle ive ever owned was a 99 and i now have a 97
    luckily i dont smog unless i sell a vehicle, my stuff is all registered in Lake County which doesnt require biannuel smogs
  11. Dec 22, 2010 at 2:01 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    03 tacoma extracab v6 5spd trd 4x4
    CARB is a perfect example of what is wrong with modern government. Even if they started out with good intentions (reducing polluting emissions) they have abused their power to try to force people to keep their vehicles exactly as they came from the factory. Those bullshit visual inspections have nothing to do with improving air quality. If your car passes the sniffer, that's all that should matter.
    The CEL test makes sense because if an OBDII car is emitting enough to fail the sniffer test, it's almost guaranteed it has a CEL.
  12. Dec 22, 2010 at 2:05 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    They will probably pop you if you don't have the factory map! God I love this state....
    NOT
  13. Dec 22, 2010 at 3:28 PM
    Trever1t
    Bay Area CA.
    '06 Basic Tacoma
    Just to play Devil's advocate I will say that this is untrue. Just because a vehicle can pass the sniffer under controlled conditions doesn't mean it isn't a problem with emmisions. Long tubes, adjusted VE maps, etc. may not cause an issue at low rpm (like on the roller at a smog check) at higher rpm and during acceleration a modified vehicle is probably a gross polluter.
    That said, I'm looking for a 'friend' in the business ;)
  14. Dec 22, 2010 at 3:41 PM
    whippersnapper02
    Christian
    Yorba Linda, CA
    Doubtful. I don't think their equipment can read what tune you have.
  15. Dec 22, 2010 at 3:45 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    08 Taco
    I had an incident with a guy at a smog shop a while back. He failed the visual on my 98 jetta because of the intake I had on it. It was a Neuspeed intake, and I had the carb sticker. He failed me even with having the carb sticker. His shop burned down a couple weeks later.
    j/k it didn't burn down. would have served him right though.
  16. Dec 22, 2010 at 4:04 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    There are ways around the plug in test.
    When I had my turbo accord, come emissions time, I would disconnect the wastegate so I wouldn't make any boost, put my factory injectors, egr valve, evap canister, and factory ecu back in the car. Drive it for a few days to let the ecu run through all the readiness checks. The car would pass the plug in test just fine, even though I was running 2.5" straight exhaust from the turbo-back no cat only had a muffler which was pretty much straight through..you could see right through it. I used the spark plug no fouler trick on my rear 02 sensor to fool it into thinking I had a cat.
  17. Dec 28, 2010 at 1:01 AM
    shampoop
    southwest WA
    i understand the devils advocate part, but your points are wrong. Headers don't have a negative impact on emissions. They also do test your car at idle and at running rpm. They don't test at 7000rpm for any cars for a reason. They don't care what it puts out at 7000rpm. Also, a tuned ecu won't fail a visual inspection anyways. If a car is a gross polluter, it will show during the sniffer tests they perform. They test under the conditions that the car spends 99% of it's life at. They don't care about the 1%.
  18. Dec 28, 2010 at 11:16 AM
    97T
    Melt
    Littleton, CO
    gotta disagree with you there, when i had my 96 acura integra b18b1, i still passed but my numbers were higher with the carb legal dc sports 4-2-1 ceramic header i had. Eventually took them off cause dc parts are complete garbage and the fuckin thing cracked, furthermore i had gotten a state ref ticket for a non carb compliant intake and put the stock airbox and header back on so i would pass, i passed with flying colors and the apexi n1 catback exhaust i had was determined to be legal .... after all of this bullshit with being pulled over all the time by CHP, i have vowed not to own another modified honda as long as im still living in calfiornia (hopefully not much longer)
  19. Dec 28, 2010 at 11:21 AM
    whippersnapper02
    Christian
    Yorba Linda, CA
    Really? I threw on a set of DC ceramic 4-2-1 headers on my 97 Civic EX with the D16Y8 engine 10 years ago and they are still on the car with no leaks and cracks. My aunt drives it now though.
  20. Dec 28, 2010 at 11:27 AM
    97T
    Melt
    Littleton, CO
    from what i understand the cermaics were the most likely to crack ... some people like you are able to have no problems, and i was screwed after 2 years.
