New CaliRaised LED Bar...but..'Check Charging System'
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lzenonian, Oct 21, 2019.
  1. Oct 21, 2019 at 2:49 PM
    lzenonian
    lzenonian [OP] Excited Toyota Owner since 1994
    Loran
    Bellingham, WA
    2019 Toyota Tacoma OR in Calvary Blue
    Starting....
    Installed the CR LED bar behind and below the grill of my very new 2019 Tacoma Off Road this weekend. Couldn't start this morning because positive terminal was loose (not off, just loose). I tightened both positive (LED wire attached to + terminal) and negative terminals, the ground post (negative LED attached there as well) and the relay for the wiring harness. Truck started right away after tightening maintenance.
    But now display system says 'Check Charging System' but goes away when Truck is started.
    1. I have not drained my battery, its great.
    2. All wiring done according to instructions.
    Questions:
    1. Will the warning go away after a lapsed period of time?
    2. Do I need to reset something, like a CEL?
    3. Or nothing?
    Truck has 407 miles.....
    Thoughts?
  2. Oct 21, 2019 at 2:52 PM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Normal operating procedure. Enjoy your truck.
  3. Oct 21, 2019 at 3:00 PM
    lzenonian
    Loran
    Bellingham, WA
    Starting....
    Will it go away? I have OCD issues...
  4. Oct 21, 2019 at 3:02 PM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    If it’s only there when you start its fine. If it’s there while your driving then you have a problem
    lzenonian[OP] likes this.
  5. Oct 21, 2019 at 3:02 PM
    snickers
    Close your eyes during that time frame. Try to count the floaters in your eyeballs. That will occupy your OCD.
    lzenonian[QUOTED][OP] likes this.
  6. Oct 21, 2019 at 3:03 PM
    Sn4rlax
    Sn4rlax Well-Known Member
    2016 Red Taco 4x4 V6
    Mine has always said Check Charging System when I turn to ACC, but goes away when I turn it on.
    Trd_omar, daddy_o and lzenonian[OP] like this.
  7. Oct 21, 2019 at 3:03 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    Welcome to the era of CANBUS, something is wired where it shouldn't be
  8. Oct 21, 2019 at 3:06 PM
    Taco Tuesday Morning
    Taco Tuesday Morning Active Member
    19 tacoma trd or quicksand
    "Check Charging System" always displays when the vehicle is not running. First day I bought the truck I had the same question, thought something was wrong, but the dealer gave me the wave off "you kidding?! Get out of here." So I left and never thought about it again.. until today.:)
  9. Oct 22, 2019 at 6:43 PM
    LSUfan1975
    LSUfan1975 Well-Known Member
    Eric
    Washington NC
    2019 SR5 Dbcb MGM
    Disagree. My truckhad behaved this way since day one.
    lzenonian[OP] and daddy_o like this.
