New camburg +2 kit mid travel???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jdiola, Jul 12, 2021.
  1. Jul 12, 2021 at 8:50 AM
    jdiola
    jdiola [OP] Well-Known Member
    jay
    Echo park los angeles
    13 tacoma dcsb off road
    Ovtune, anytime locker mod, pelfrey hybrid bumper, pelfrey rock sliders baja designs s8 and sqaudron pros, group 31 interstate battery with TW memeber coupe trd battery strap, osram 100/90 watt headlight bulbs, hkb voltage booster, meso 3 pod 3rd brake light, archive hammer hangers at the helm motorcycle holder/bed stiffiner prinsu rack gfc superlite rotopax 2.5 gas 2 water sua deaver hd springs with icon hydro bumps 12” fox 2.5 dcs w/ accutune on archive shock relocation ext icon cdc front coil overs jdfab 2.25 lt w/currie axles fox 2.5 front bumps jdfab double shear uca jdfab spindle gusset bypass shock hoop with icon s2 falken wildpeak 265/75-17 carhart seat covers
    Anyone have any info on this new kit from camburg? From instagram its a +2 kit that uses stock shock length? The lca has front ball joint moved forward a bit and has a sealed ball joint maybe?
  2. Jul 12, 2021 at 11:30 AM
    sprucemica
    sprucemica 2013 DCLB Limited 4.0L 4x4 - Spruce Mica
    Do you have a link?
  3. Jul 12, 2021 at 1:38 PM
    jdiola
    jay
  4. Jul 12, 2021 at 1:42 PM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
  5. Jul 12, 2021 at 3:34 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Looks very cool.
    They call it both in the video, due to using the "shocks you already own".
  6. Jul 12, 2021 at 5:59 PM
    JoeTacoma02
    So it's a mid long travel :D
  7. Jul 12, 2021 at 11:02 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
  8. Oct 2, 2021 at 9:28 PM
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
  9. Oct 2, 2021 at 9:48 PM
    Oreo Cat
    It’s on the site now
    TacoEspecial[QUOTED] likes this.
  10. Oct 2, 2021 at 9:49 PM
    Oreo Cat
  11. Oct 2, 2021 at 9:59 PM
    Oreo Cat
    The bump stop setup is an additional $1850 for kings.
    $4900 for 4x4 & billet arms
    I’m not a shock expert but it says 13” with “extended travel coilovers”
    does that mean the longer 8 inch coils from one of the other +2 LT kits?
    Or are extended travel coilovers more basic like for stock length control arms?
  12. Oct 2, 2021 at 10:03 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Go full LT
    Mech_Eng likes this.
  13. Oct 2, 2021 at 10:31 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Just go to www.jdfabrication.com and start with there lower control arm mount assembly and replace the weak factory mounts. No sense in bolting expensive arms to the factory crap mounts.
  14. Oct 2, 2021 at 10:52 PM
    Oreo Cat
    It claims 13 in of travel wouldn’t that count as full long travel since it’s equal to JDs travel numbers and more than the other +2?
  15. Oct 3, 2021 at 9:04 AM
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    How do you adjust bump stop with a slapper setup?
  16. Oct 3, 2021 at 12:01 PM
    Oreo Cat
    It really doesn’t look like you can with this
  17. Oct 3, 2021 at 12:28 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    (note the factory bumpstop use) That wacky slapper setup thing is there to likely provide end support in the stroke, considering they are using stock length shocks which means the extra lever arm of the extended length will need some help to support the truck.
  18. Oct 4, 2021 at 9:10 AM
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    Are slapper setups noisy?
    Do you hear some sort of slap every time it makes contact?
