New Canadian TSB for driveline vibrations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BennyTRD, Feb 10, 2014.
  1. Feb 10, 2014 at 10:09 AM
    BennyTRD
    BennyTRD [OP] Active Member
    Sask, Canada
    '11 TRD Sport 4X4
    After dealing with my local Toyota dealer over the last 6 weeks trying to diagnose driveline vibrations in my 2011 TRD Sport, there is finally a new TSB for us Canadian guys that we can utilize. Although the US version of this TSB has been a round for quite sometime, up here we could never use it as a course of action for getting this issue fixed. Now, finally, Toyota Canada released the same TSB on Feb 7th. So if you guys are having driveline vibrations, get your dealer to search for the new TSB and hopefully these issues are over.
    My truck is going in Friday morning to start the procedure, and I'll try to update this post with a link to the Canadian TSB if I can get my hands on it.
    For reference the US TSB is TSB 0249-12.
  2. Feb 10, 2014 at 10:13 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  3. Feb 21, 2014 at 6:43 PM
    BennyTRD
    Sask, Canada
    '11 TRD Sport 4X4
    Well, got the ball rolling finally. Picked up my '11 from the dealer after they did the first procedure in the TSB, which is the Rear Transmission Mount. And as I predicted, I still have vibrations. So, for the 6th trip to the dealer trying to sort this issue out, it is going back in on Tuesday to get the rear leafs replaced as the second part of the TSB.
    Will update again after this is complete.
  4. Feb 22, 2014 at 6:31 AM
    itsakeeper
    itsakeeper Well-Known Member
    nova scotia
    2012 SR5
    got a copy of it you can post or a link ?
  5. Feb 23, 2014 at 5:58 PM
    BennyTRD
    Sask, Canada
    '11 TRD Sport 4X4
    I'll see if I can get a copy of it, but the paperwork I have from my dealer quotes TCI-4089.
  6. Feb 23, 2014 at 6:42 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    FYI... the new US TSB for driveline vibes was released on Feb 3rd... so you canadians got it 4 days later.
    That said, its likely to be 100% the same exact tsb.
  7. Mar 15, 2014 at 3:59 PM
    BennyTRD
    Sask, Canada
    '11 TRD Sport 4X4
    Well my dealer has been not following the TSB to the letter yet, but in addition to the Rear Trans Mount they changed out, they replaced the complete driveshaft, CB and U Joints. Still have a slight vibe between 60-80 km/h. So back in it goes again for the rest of the TSB including new springs and axle shims. Hopefully this lengthy saga will be over soon.
  8. May 8, 2014 at 3:12 PM
    BennyTRD
    Sask, Canada
    '11 TRD Sport 4X4
    Finally after a 5 week wait on parts, everything is complete. Toyota had suspended the Canadian TSB as they had trouble getting the required parts for it. Now, after the transmission mount, steering wheel dampener, complete new drive shaft and carrier bearing, new rear springs and axle shims, I finally have no more vibrations. I hope that's the end of my issues with this truck.
  9. May 8, 2014 at 4:38 PM
    buzzed
    buzzed Active Member
    Ron
    Saint John, New Brunswick
    DCLB Silver Streak Mica
    What were the vibrations you were having? I'm hoping to take this TSB to the dealer to help correct my takeoff shudder. Do you still think the TSB is TCI-4089?
    Congrats on your success!
  10. May 8, 2014 at 4:49 PM
    BennyTRD
    Sask, Canada
    '11 TRD Sport 4X4
    TCI 4089 is what all my paperwork says, so I would mention that to them and see what they say. I was getting vibes between 40-60 and 100-110, nothing on take off however.
  11. May 8, 2014 at 4:58 PM
    buzzed
    Ron
    Ok, thanks. Mine's not too bad once rolling, but takeoff shudder is driving me nuts.
    Not sure if I will bother calling the dealer. Sounds like you were having a different issue.
  12. May 13, 2014 at 7:07 PM
    docjan
    docjan New Member
    Manitoba, Canada
    06 Tacoma SR5
    i'm having shudders/vibrations that would start at 40 kph, before 60 kph and before 80 kph. it happens at low RPM (1500 and lower), its not noticeable if the RPM is high or in overdrive. I was told by the dealer that it could be in the transmission. I went to a transmission shop to have it tested and he said to try replacing the u joints first as he believes its not the transmission that's causing the vibration. i replaced 1 bad u joint 4 months ago. i may have to replace all 3 u joints and the CB and hope it'll eliminate this vibration
  13. May 14, 2014 at 11:22 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    I can find these old ones
    0. T-TCI-3882-Obs: '05-'13 Tacoma: Driveline Vibration Between 24 - 40 km/h (Obsolete)
    11. T-TCI-3018-Obs: '05-'08 Tacoma: Driveline Vibration Between 24 - 40 km/h (Obsolete)
    I am right in there now
    and cannot find T-TCI 4089 whatsoever....not saying it doesn't exist but techinfo cannot access it. I checked english and french and 2011,,2012,,2013,,2014
    of 338 Canada service bulletins for all years Tacomas.....
    they stop at 4060
    Canada Service Bulletin
    : 338 document(s) found.
    326. T-TCI-3974: '14 Modeles Applicables Toyota: Positionnement Des Pneus Avant La Livraison Du Vehicule Neuf
    327. T-TCI-3975: '14 Modeles Applicables Toyota: Installation Des Tapis Protecteurs Pendant Le Service Avant-Livraison
    328. T-TCI-3976: '14 Modeles Applicables Toyota: Installation De L'Antenne Pendant Le Service Avant-Livraison
    329. T-TCI-3980: '03-'13 Modeles Applicables Toyota: Bruit Provenant De La Partie Superieure/Inferieure De La Lunette Arriere/Du Pare-Brise
    330. T-TCI-3982: '12-'13 Modeles Applicables Toyota: Fonctionnement Anormal Du Systeme De Navigation Pour L'Affichage Audio (Type Non Dd)
    331. T-TCI-3984: '13 Modeles Applicables Toyota: Manuels De Reparation Pour L'Annee-Modele 2013 - Toyota
    332. T-TCI-3989: '05-'13 Tacoma: Bruit De Gemissement Du Differentiel Arriere Entre 80 Et 97 km/h
    333. T-TCI-4000: '01-'14 Modeles Applicables Toyota: Techstream - Procedure De Reprogrammation Flash De L'ECU
    334. T-TCI-4009: '10-'13 Tacoma: La Barriere De Pare-Brise Est Lache Ou Visible
    335. T-TCI-4012: '06-'10 Modeles Applicables Toyota: Emplacement Du Numero De Serie Sur Les Boites Automatiques
    336. T-TCI-4035: '10-'14 Modeles Applicables Toyota: Diagnostic De Systeme De Climatisation Apres Defaillance Du Composant
    337. T-TCI-4049: '12-'13 Tacoma: Bruit De Sifflement De Vent De La Calandre
    338. T-TCI-4060: '14 Tacoma: Liste De Verifications Pour Le Service Avant-Livraison
  14. May 14, 2014 at 11:31 AM
    BennyTRD
    Sask, Canada
    '11 TRD Sport 4X4
    I'll double check my paperwork later on this evening, but mine does reference TSB 4089 I'm pretty certain.
  15. May 14, 2014 at 11:40 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    freaking weird. my eyes are buggered from trying all possible search options and i can only find the two obsoleted ones....(and the current USA one)
    if you can confirm it (or actually find a copy) ...
  16. May 14, 2014 at 1:41 PM
    buzzed
    Ron
    Out of curiosity, I called another dealer in the next town, and simply asked if they'd heard of TCI-4089. The service advisor hadn't, but after a few minutes he managed to find it. Said it had to do with driveline vibrations. I didn't get into specifics - just asked him how recent it was, and he said Feb.7, 2014.
  17. May 14, 2014 at 1:53 PM
    BennyTRD
    Sask, Canada
    '11 TRD Sport 4X4
    That's the one yes, it came out early February.
  18. May 14, 2014 at 2:03 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    then my techinfo subscription is not working, or it is in some hidden area
    -------------------------------------search 4089 entire toyota site
    : 0 document(s) found.
    No documents were found containing 4089.
    -------------------------------------search 0008 entire toyota site
    Service Bulletin
    : 2 document(s) found.
    1. EL009-07: 00-08 Applicable Models: Programming OEM Wireless Door Lock Remote Transmitters
    2. T-SB-0008-14: '05-'14 Tacoma: Driveline Vibration
    : 1 document(s) found.
    1. T-TCI-2933: '00-'08 Applicable Models: Programming Oem Wireless Door Lock Remote Tran
    I am being ROBBED!
  19. May 14, 2014 at 5:26 PM
    BennyTRD
    Sask, Canada
    '11 TRD Sport 4X4
    Here is a pic of the paperwork referencing TSB 4089.
  20. May 14, 2014 at 5:39 PM
    BIG HUNY
    BIG HUNY Member
    Rob
    Thornton, ON
    08 DoubleCab TRD
    Not to be funny.... But I had lived with my vibration for years. Changed tires, u- joints etc to no avail.
    Last fall I threw on a 3" lift and 285/75 MT/Rs.
    Now I can't feel the vibration!!!! It could be the change in overall gearing or simply that i cant hear it over the tire noise!
    Regardless, I'm happy.
