New carrier bearing question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoCats, Oct 20, 2016.
  1. Oct 20, 2016 at 10:56 AM
    TacoCats
    TacoCats [OP] Active Member
    07 Tacoma Off Road
    when a new one is installed,is it safe to say that there should be a little play in it when you move The driveshaft? All my ujoints are replaced but getting a low vibration at about 60 miles an hour is where the sweet spot is, anything above that like over 70, it goes away, it doesn't do it at 50, thanks guys.
  2. Oct 20, 2016 at 11:04 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    the rear shaft up to the carrier bearing will move a little because the carrier bearing has a rubber bushing. You shouldnt have any vibration, unless it was put back together improperly or theres other bearings going out. Or the carrier bearing is twisted...
    TacoCats[OP] likes this.
