New Chevy Colorado mega-thread
Discussion in 'General Automotive' started by KenLyns, Jan 19, 2013.
  1. Aug 27, 2014 at 9:36 AM
    #1441
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I was thinking the same. The 4.7 doesnt make any more hp than the 4.0 (4runner version anyway, so it would be the same tune respectively im sure for the taco) and its a v8 so its gonna weigh a bit more (i realize its belt not chain but still gotta be heavier) weight to power ratio is gonna be close, too close to justify. Just put a blower on and crank out the same numbers as the 4.6 even. Givin that would be a $4000 option if offered.
  2. Aug 27, 2014 at 11:07 AM
    #1442
    J Gibson
    J Gibson Well-Known Member
    J
    Knoxville, TN
    '12 DCSB,4wd,TRD Sport, tow pkg, MGM
    katzkin leather, toyota step bars, pro grill, advent overhead DVD player, cargo extender, bed mat, husky liners, impulse digital brake controller, avs bugflector, tinted windows, Firestone ride-rite air bags, ARE camper top with tool doors, ScangaugeII, ProEFX tow mirrors, ImMrYo rearview mirror lift bracket, Salex glove box and console organizers, 2020 Tacoma Pro styled wheels, 265/70 r17 Michelin MS2 tires, LED map lights, drivers seat extended and raised, ram ball tech deck installed, blacked out badges, tinted taillights, upgraded climate control knobs, ultimate headlight upgrade with Osram superbrights and wiring harness along wit OEM pro headlight housings.
    From post above......
    "I can't think of ANY truck or car that went so long without a significant change in it other than the Tacoma"
    The Volkswagen beetle went what 40 years? maybe longer counting the Mexico only production in the later years.
  3. Aug 27, 2014 at 11:19 AM
    #1443
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    Ford Ranger went 19 years.
    C3 Vette - 14 years
    C4 Vette -12 years
    I'm sure I could dig up some more.
  4. Aug 27, 2014 at 12:42 PM
    #1444
    yota243
    E.J.
    north Alabama
    304 hp and 334 tq with trd s/c, and i would imagine would be the same price as a v8 option with more horses and tq. add the 2.85 pully and pass the newer improved 4.6 numbers.
  5. Aug 27, 2014 at 12:59 PM
    #1445
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    The 4.7 doesnt make any more power than the 4.0L? The 4.7L 4runners have higher tow ratings and are faster than the 4.0Ls. My brothers 2004 AC Tundra V8 has smoked many a 2nd gen Tacoma from stop lights. And I regularly towed 10k and hung in 5th in my 05 DC Tundra, you couldnt do that if you had the 4.0L in the exact same body. The 4.0L clearly falls in line behind the 4.7L.
  6. Aug 27, 2014 at 1:14 PM
    #1446
    yota243
    E.J.
    north Alabama
    agree to disagree with pretty much everything in that statement
  7. Aug 27, 2014 at 1:36 PM
    #1447
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Yeah, I agree about the displacement statement but after weight and the additional mass of the additional parts in a V8 over a V6, I'd have to agree that I'd rather have the S/C 4.0L over a 4.7 L motor in the Tacoma. When talking about displacement, sure I'd buy a 5.7 L as being a huge jump over the 4.0 L, but for our little trucks all you need is the blower.
    I could say the same thing about the S/C 4.0 L that you said about the 4.7 L. Bolt on a new pulley, new fuel pump, new intake, new exhaust, and do a little easy tuning and I'll fly past any 4.7 L 4Runner short of one that's been race built or has a turbo. That turbo will cost far more than my S/C if done right.
    The 4.7 L wouldn't do anything that little bit of boost doesn't already do. The blower should of been a stock option on the TRD Tacoma's. If they had of installed them on even 20% of the trucks I bet the option could of cost as little as $2.5K
    In my observations it's only 40+ y/o guys that can't understand why the Ecoboost engines and similar designs will be the way of the future. They still remember the big blocks there daddies have and can't get over the fact that low displacement motors with boost will be replacing V8 motors. V8's in 1/2 tons, especially the antiquated motor in the "new" Tundra, are a thing of the past.
  8. Aug 27, 2014 at 4:54 PM
    #1448
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Really? What about the formula 1 cars making 600 HP from a 1.6L v6 or those rally cross cars that have 0-60 times under 2 seconds from a 2.0l 4cy that also makes 600 HP.
    There is a lot of replacement for displacement. There isn't much point anymore to make huge v8 when we can get the same amount of power from a smaller displacement and even less cylinders with better efficiency.
  9. Aug 27, 2014 at 4:58 PM
    #1449
    liveload
    liveload Active Member
    Colorado Springs
    07 Tundra 5.7L 4x4 Dbl Cab
    The other side of the forced induction argument is increased cost and complexity which in turn create a higher cost of ownership. There's no way around that, no matter how many Fords you blow up trying to finish the Baja 1000. I stick with the 4.6L as a better option. Chain driven, more powerful than either the 4.7 or the 4.0 and it doesn't need forced induction to be a fine motor.
  10. Aug 27, 2014 at 5:04 PM
    #1450
    gray223
    SE Missouri
    2014 Tundra Limited
    Very good point.
  11. Aug 27, 2014 at 5:59 PM
    #1451
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Guess we should go back to carburetors and leaded gas then:rolleyes:. Seriously, while I agree the Ecoboost is not 100% there yet, motors like it and turbo diesels will be the future from an efficiency standpoint. Lighter, faster, stronger, and one day reliable enough to silence the critics. Just like 99 percent of technology changes there's going to be growing pains.
  12. Aug 27, 2014 at 6:15 PM
    #1452
    yota243
    E.J.
    north Alabama
    Defenately SOHC FTW. carbs, distributers, throttle cable. Much better. Just saying my dads 77 f250 with a 351 has 110 more cubic inches than my 4.0 but 80 hp less. Displacement is most definitely not everything. Even the new silverado non tow pkg comes with a 3.08 rearend, so morr displacement and "more technologically advanced" motor but wont out preform smaller motors because of the tall gears.
  13. Aug 27, 2014 at 6:34 PM
    #1453
    sammy87
    sammy87 Well-Known Member
    co
    10 TRD SPORT 4X4
    Isnt the light truck market hurting pretty bad? I mean for not much more you can get a full size. I loved my Tacoma, but now with a SUV only about once every few months do I need a truck and its usually for just a quick trip. I don't think I could go back to a truck.
  14. Aug 27, 2014 at 6:38 PM
    #1454
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    More sightings of the new Colorado on public streets, looks good in black. Front fascia is low, of course for mpg's but would have to be removed for any wheeling.Canyons_c43bb6b79b0dd309aea7cecc6dce3a5c65483b37.jpg
    6F21E390-73AD-40F5-ACBA-57D8E388095D_zps_2633748e330f78c6cd6cc8e496ae84f30d905352.jpg
  15. Aug 27, 2014 at 6:52 PM
    #1455
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    That Z71 looks agressive. I kind of like it. Too bad that whole bumper probably has to come off to get good clearance like you said.
  16. Aug 28, 2014 at 8:13 AM
    #1456
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    I didn't realize my comment would start so much of an engine discussion. I was just saying I wouldn't mind the 3.6 Pentastar in a Jeep truck if they ever resurrected the Commanche (Brute)
    I'm really liking the look of the new GMC truck... I think if I ever get tired of this Tacoma that's the one I'll be looking at. I really don't have a need for it but if I ever need a full 4-door instead of an Access Cab I think their 4-door with a diesel will be in my future if Toyota doesn't figure out its shit and get a diesel together.
  17. Aug 28, 2014 at 8:20 AM
    #1457
    BuddyS
    BuddyS Well-Known Member
    Maryland
    2013 TRD Sport 4x4 MT
    Or better yet, steam engines! I agree with you, Sterdog -- today's (and tomorrow's) higher-tech engines are and will likely prove to be just as reliable as anything else bought in the last 20 years. I had a 2001 Audi A4 with a 5-valve per cylinder turbo engine that went 100,000 miles without a hiccup. And that was chipped, too.
  18. Aug 28, 2014 at 8:23 AM
    #1458
    snowmanwithahat
    I'm really liking the look of the new GMC truck... I think if I ever get tired of this Tacoma that's the one I'll be looking at. I really don't have a need for it but if I ever need a full 4-door instead of an Access Cab I think their 4-door with a diesel will be in my future if Toyota doesn't figure out its shit and get a diesel together by then.
  19. Aug 28, 2014 at 10:07 AM
    #1459
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I think any potential Tacoma buyer should drive a Frontier and a Colorado. While most will still go with the tacoma, for now, it's never a bad idea to see what else is out there.
  20. Aug 28, 2014 at 10:55 AM
    #1460
    taco206
    Mill Creek, WA
    Don't hate on steam. Steam runs the world, do you know how nuclear or coal power plants work?
