New clutch in my 1996 3rz 4x4 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by 02TACOMA4WD, Dec 26, 2012.
  1. Dec 26, 2012 at 3:22 PM
    02TACOMA4WD
    02TACOMA4WD [OP] Well-Known Member
    02 Tacoma TRD 4x4
    I just got my marlin crawler HD clutch and flywheel shipped to me. I have been searching everywhere for a DIY install guide, but I can't find one.i feel that i am mechanically inclined enough and I would like to do the install myself rather than paying a shop to do it. If someone could point me in the right direction it would be much appreciated.
    This is all that I have found ( Im hoping to find something that goes more in depth with the actual installing of the clutch and flywheel, rather than just dropping the tranny )
    http://m.youtube.com/#/watch?v=UHNNDdxYeT8&desktop_uri=/watch?v=UHNNDdxYeT8
  2. Dec 26, 2012 at 3:30 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  3. Dec 26, 2012 at 3:57 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    Thanks for sharing these videos! I'm gonna start tomorrow morning. I'll keep the thread updated on how everything is going. If anyone else has any tricks or tips feel free to share :)
  4. Dec 26, 2012 at 3:59 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    do you have a tranny jack? your going to want something.
  5. Dec 26, 2012 at 4:01 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I was able to get mine out with a floor jack and a 2x4. Don't recommend it unless it's the only thing you have.
  6. Dec 26, 2012 at 4:10 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    I'm doing it at my grandpas. I'm set with all the tools. I'm going to be using two 3 ton floor jacks and if I need to I can strap the tranny and transfer case to them.
  7. Dec 26, 2012 at 4:21 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    I'm thinking about replacing my rear main seal also. I have an oil leak and it looks like it is coming from between where the transmission and engine mount together.
    Scroll down and look at the pictures of the guy replacing the main seal.
    http://www.ttora.com/forum/showthread.php?t=145146
    I think it would be worth it. The seal is only $20 so better safe than sorry
  8. Dec 27, 2012 at 4:56 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I've replaced the rear mains on the last two clutches I've replaced. Just be careful with the seal. It's a little tricky to get back on.
  9. Dec 27, 2012 at 5:38 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    Half way done!
  10. Dec 27, 2012 at 6:57 PM
    TherealScuba
    TherealScuba Well-Known Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Not a 95, and frankly, there is a huge difference between the truck in the videos and a Tacoma, but they were a good watch and will show a good strategy to anyone looking to DIY a clutch.
    OP: Definitely replace the rear main while you're in there.
    I couldn't imagine having to rip the trans out only a few thousand miles after replacing a clutch because the rear main gives up the ghost.
  11. Dec 27, 2012 at 7:38 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    I did the rear main! I'm having trouble with lining the tranny back up. Any tips?
  12. Dec 27, 2012 at 7:52 PM
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Is the truck on the ground or in the air?
    Ground I assume since you said you were using 2 floor jacks.
    I've had issues before lining it up, but what I do is get behind the transfer case and put my feet up on the tcase with my knees bent while grabbing the output flange to help.
    Just use your feet to wiggle the rear of the tcase enough till the input shaft slips in.
    Its a trick an older wiser friend of mine taught me. :)
  13. Dec 27, 2012 at 8:22 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    I still can't get this tranny in!!! More tips please
  14. Dec 28, 2012 at 10:44 AM
    97yota4wd
    Eric
    Mesa, AZ
  15. Dec 28, 2012 at 10:45 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Did you use the tool to set the clutch plate before you torqued the pressure plate down?
  16. Dec 28, 2012 at 11:11 AM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    I got the tranny back in and everything works!! The new clutch is so much better compared to my old one hahah
