New Clutch Recomendations for a '02 4x4 2.7L
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stuardoslls, Jun 29, 2010.
  1. Jun 29, 2010 at 6:09 PM
    Stuardoslls
    Stuardoslls [OP] Well-Known Member
    Stuart
    Hawthorne, CA
    2012 Double Cab 4x4 TRD Offroad Package
    Just Rims and Tires: FJ Cruiser 16" wheels w/ 265/75/16 BFG KO2's
    My clutch just started slipping a little bit, and I figure I should replace it before it goes out completely..... any recomendations?
    Just to make sure:
    It slips at about 2,500 rpm when I give it gas in 3rd and 4th gear... anything else it could be? :confused:
  2. Jun 29, 2010 at 7:07 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Most likely clutch. Make sure you get the whole clutch kit. Stage 4 preferably...:D
  3. Jun 30, 2010 at 7:48 PM
    Stuardoslls
    Stuart
    Hawthorne, CA
    Any recommnedations on brands I should consider?
  4. Jun 30, 2010 at 8:06 PM
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
  5. Jul 1, 2010 at 12:58 PM
    Sirlight
    Sirlight 1337 h4x0r
    Orange County, CA
    2004 PreRunner Xtra Cab
    STOCK
    Go for the full kit replacement. OEM equivalent or a little better is good. No need for some ultra heavy duty clutch as i dont think you are putting down gobs of power to necessitate it. How long did the OEM one last ? :)
    Clutch disc, pressure plate, flywheel, throw-out bearing. Kit usually comes with the clutch alignment tool as well. May want to look into a diff plug as well for when you yank the drive shaft ( if you are gonna do it that is )
  6. Jul 8, 2010 at 10:08 AM
    Stuardoslls
    Stuart
    Hawthorne, CA
    Thanks for the help. I think the Marlin Crawler is going to be he way to go... I plan on doing a 3"lift and maybe slighty larger tires so I dont think I need much more..
    I just bought the truck 4 months ago... Its a 2002 and it only has 44,000 miles on it... That doesnt seem like very great life on a clutch does it?
  7. Jul 8, 2010 at 6:16 PM
    RAT PRODUCTS
    Farmington, MN
    Nope, sounds like someone's been beating that truck to hell. I was able to do insane burnouts in my 2wd taco and it still lasted 144,000.
  8. Jul 8, 2010 at 6:18 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    the previous owner has no clue how to drive a manual. they probably like to hold the truck on inclines with the clutch:rolleyes:
  9. Oct 8, 2010 at 8:31 PM
    Stuardoslls
    Stuart
    Hawthorne, CA
    Hey everyone......Finally ready to get the new clutch............Thinking about getting the Marlin crawler clutch, any other recomendations? Has anyone used the Marlin crawler clutch? any feedback.. would help me out a lot ...Thanks
  10. Oct 8, 2010 at 8:38 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I've heard nothing but great things about it.
  11. Oct 8, 2010 at 8:48 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I haven't replaced mine yet, so these are just other brands I've heard tossed around. Not that any of these are "better" than one from Marlin Crawler, which actually sounds pretty good.
    Clutch Masters
    Spec
    Centerforce
  12. Oct 8, 2010 at 8:49 PM
    afd23a
    The Dynamo of Dixie
    x2
    I've heard good things about the Marlin Crawler and ClutchMasters but some bad things about centerforce clutches if not installed correctly.
  13. Jan 8, 2011 at 7:39 PM
    Stuardoslls
    Stuart
    Hawthorne, CA
    So I've had my clutch for a couple of months now and I figured I would give a quick update for others refference. The new clutch is great. Ive noticed a big difference in the performance. It grabs under all circumstances. Ive done some pretty rough offroading and it has never slipped even when its gotten hot and has taken abuse.
    What inspired the update was something funnier from earlier today. I was pulling out of work made a left and some guy in an M3 hit the corner they way you figure an M3 should be driven. In order for him not to rear end me I gas the tacoma in 1st gear and slammed second, guess what.... the little 4 banger chirped 2nd gear and then went on to chirp 3rd gear..... proof that the clutch will not slip.....
    I would reccomend a marlin crawler to everybody
  14. Jan 8, 2011 at 8:16 PM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
