New clutch time. What are my options?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Von Himmel, Jun 19, 2013.
  1. Jun 19, 2013 at 9:26 PM
    Von Himmel
    Von Himmel [OP] Active Member
    James
    Pendleton
    01 TRD SR5
    So I have an 01 3.4 trd offroad. After 104,000 miles it is time for a new clutch but I don't know what to buy or where to buy it from. Any tips?? I don't want to spend a ton of money but also don't want something that wont stand up to the abuse that I know I will heap upon it.
  2. Jun 19, 2013 at 9:28 PM
    Conman117
    Conman117 AWESOME MEMBER
    Nathan
    BC, Canada
    98 Brap-coma
    Blue LED dash lights
  3. Jun 19, 2013 at 9:32 PM
    Von Himmel
    James
    Pendleton
    01 TRD SR5
    What sort of price is it? How many miles or how long have you had it?
  4. Jun 19, 2013 at 9:43 PM
    Conman117
    Nathan
    BC, Canada
    98 Brap-coma
    It should be around $300.
    I've had it for 6 months (around 6000 miles).
  5. Jun 19, 2013 at 10:13 PM
    Von Himmel
    James
    Pendleton
    01 TRD SR5
    Awesome man! Thanks a lot!!
  6. Jun 20, 2013 at 3:04 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    I second the Marlin Crawler clutch kit
    I've got the 1,200lbs one - had it for right around 6k too, actually
    Love it
    Also, their customer service is outstanding
  7. Jun 20, 2013 at 1:13 PM
    toastyjosh
    toastyjosh Well-Known Member
    northern New mexico
    95 dark green taco
  8. Jun 20, 2013 at 2:41 PM
    arifleman
    arifleman Well-Known Member
    Pacific NW
    2002 TRD 3.4L Ext Cab
    RockAuto is another good source for a variety of auto part needs. I like that you can choose from a number of parts to fit your particular usage needs. I especially like them for brake jobs and such. Decent prices. http://www.rockauto.com/
  9. Jun 20, 2013 at 4:43 PM
    Seventh
    Seventh Insert witty title here
    Boston, MA
    2001 Reg Cab 4x4
    Subbed.
  10. Jun 20, 2013 at 5:36 PM
    garyp
    garyp Well-Known Member
    Gary
    Germantown TN
    97 Taco
  11. Jun 20, 2013 at 6:52 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    Do the heavy duty marlins put any more strain on the hydraulics?
  12. Jun 20, 2013 at 7:13 PM
    Conman117
    Nathan
    BC, Canada
    98 Brap-coma
    I don't know. If anything, my clutch pedal feels softer :notsure: Its weird
  13. Jun 20, 2013 at 7:31 PM
    Murph
    Murph ski-doo ride the best screw the rest!
    Co Springs
    2000 Extra Cab TRD O/R
    3" lift. American racing 15'' rims. 33x12.50 BFG A/T tires. tool box. ARB bumper, mile marker winch, kc highlights. No carpet inside sprayed with bed liner. Kicker door speakers. Alpine head unit.
    I'm installing a new clutch in my truck this weekend. After checking here and the local auto parts store, I went with the marlin kit since its 300 just like the auto parts stores :rolleyes:.
  14. Jun 24, 2013 at 5:42 AM
    Half028
    Half028 Member
    Kenny
    El Paso
    98 Tacoma 3.4 V6. 246K and counting
    I bought a clutch on E-bay a week ago. You have a anything from 90's to mid 300's. Worth checking it out.
  15. Jun 24, 2013 at 6:39 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    I got the TG 1,600 Clutch for $280 iirc from east coast gear supply.. Its basically a marlin just a little stronger hold but my pedal also feels softer but when you engage gear the first time you will know whats up! Ive had mine for around 3 montsh and maybe 1,000 miles since ive been on the road working, but no complaints so far!
  16. Jun 26, 2013 at 11:25 AM
    Von Himmel
    James
    Pendleton
    01 TRD SR5
    Thanks for all the info! Ordered the Marlin and I'm putting it in in a week or two. Any tips for the instal or is it pretty straight forward.I've only done one clutch before and nmot a Toyota but. It seems easy
  17. Jun 26, 2013 at 5:20 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Pretty easy, I used like 4 tools total, nothing to it. Only real advice other than the straight forward stuff is to get the top bellhousing bolt from inside the cab where the shifters are
  18. Jun 26, 2013 at 6:49 PM
    Von Himmel
    James
    Pendleton
    01 TRD SR5
    Excellent. Thanks for the advice!
  19. Jun 27, 2013 at 5:19 AM
    Murph
    Co Springs
    I had to borrow a few tools for the install on my 2000 taco. I didn't have a blind finger bearing puller for the pilot bearing. I also had to get a 10mm flare nut wrench for the hard line going into the slave cylinder. And I borrowed two one foot extensions (3/8) drive so I could remove the upper bell housing bolts. It really is an easy install.
  20. Jun 27, 2013 at 11:46 AM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    I used a bolt and packed grease inside of the pilot bearing then beat the bolt in and the grease forced it out.. Can also use paper towels.. As for the slave cylinder I just unbolted the 2 12mm bolts that held it in place and left it there, no need to unhook Hard line.. But yes very easy & I did it in 4 hours pretty much by myself other than aligning it on both sides all off the ground, no post lift or anything. Also OP if you have air tools we them! Especially for the driveshaft bolts with a 14mm wrench and for the crossmember and I also used it on some of the bell housing bolts.. 3/8 impact that is but I hand tightened everything once it was back together
