new clutch?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cohbsteq, Dec 17, 2013.
  1. Dec 17, 2013 at 3:15 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Love mine has a good break over point is the only way I can describe it. Where the clutch pulls.
  2. Dec 17, 2013 at 6:37 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    Go with the Marlin Crawler. It is a very good clutch. If you off road at all don't buy some cheap aftermarket clutch. .
  3. Dec 17, 2013 at 9:01 PM
    Cohbsteq
    Cohbsteq [OP] Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    I went to the mechanic today and he said my clutch seems fine fr now so I guess ill have to deal with that freaking noise for a couple thousand more miles !! :mad:
  4. Dec 18, 2013 at 9:03 AM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    Don't quote me on shop prices. That's like asking "what does a prostitute cost?" Bout a $100 an hour, sometimes $60 though :mad: sometimes $150+ :D
    Whenever I've gone to a shop, Mr. Mckanic goes to the bathroom, pulls something out of his ass, and tries to sell it to me. I was once quoted $250 to install (1) lug stud in one of my rear wheel hubs.
    These ain't no Corollas. In a FWD car, you can get a trans out in less than a half hour sometimes. And they only weigh ~80lbs.
    This doesn't compare to a hulking 4x4 transmission that weighs more than I do. Much, much, much much much more work removing a rwd trans, especially 4x4.
    It's your choice ultimately. To deal with the noise, or to not deal with it. I suspect cost is a large factor. At some point, the bearing will seize. That's what they do when they are no longer lubricated properly. Make noise, wear down out of spec, and seize.
    That burning smell might be your clutch if you're not so friendly to it
  5. Dec 18, 2013 at 9:09 AM
    2000GTacoma
    Snow Hill NC
    With a transmission jack and a few tools it is actually rather easy in my opinion. Remove the drive shafts, cross member, slave cylinder, electrical connections, then unbolt the bell housing and slide it all back and down.
  6. Dec 18, 2013 at 9:24 AM
    fast5speed
    Washington D.C.
    Easier said than done. With a lift and a trans jack, sure, no biggie. But doing it in your driveway is a whole nother world. An the reality is most people don't have access to lifts.
    For me, reinstalling the trans is such a pain in the ass, even with 3 sets of hands. It's hard to know where to place the jack, as the transmission is very unbalance. It's also quite the challenge to line everything up properly your first go-round
  7. Dec 18, 2013 at 9:27 AM
    2000GTacoma
    Snow Hill NC
    True. We used a jack and put a ratchet strap around it and tightened as tight as we could to keep it from going anywhere. I agree in a driveway it would not be fun.
  8. Dec 18, 2013 at 9:53 AM
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
  9. Dec 18, 2013 at 10:27 AM
    fast5speed
    Washington D.C.
    AHHH! that's a good idea! When we did the clutch in my friend's Geo Tracker 4x4 we kinda used ratchet straps and looped it through the holes in the floor and used that as resistance to pull the straps up on. looking back it's like -->:eek:
    I've forgotten what you might have said earlier. Could you elaborate on this smell a bit? It is probably a leak that is working its way onto your header (most likely actually), but on some cars it can be other things. In several cars it is an issue for the blower motor box to become full of leaves and debris (as the intake is usually vertical and opens around the windshield cowl). When you turn your blower fan on, the resistors create heat and sometimes burn some of the leaves in the box.
  10. Dec 18, 2013 at 11:16 AM
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    the only way i can really describe it is a hot smell like something being burnt off but it onoly loasts about 5 mins and then stops.
  11. Dec 18, 2013 at 11:26 AM
    VAYoder4167
    VAYoder4167 Well-Known Member
    Frank
    Lynchburg, VA
    Lifted 04 toyota tacoma sr-5
    Magnaflow dual catback exhaust, 5100 bilsteins all around with 1" body lift and stock coils, 33" BF Goodrich sitting on a set of 15" Alloy Ion wheels
    So after all that and since you did it yourself you probably saved yourself a good chunk of money for other mods. You said it took you about 5 hrs? I've done quite a few transmissions as well as diesel rebuild on a mechanics skill scale how bad was it?
  12. Dec 18, 2013 at 1:58 PM
    2000GTacoma
    Snow Hill NC
    I really don't know what level it is on. Really not bad. Unbolt a few things, take your time, and it came right out. I would say someone that has changed a clutch before could do it. However I don't feel an inexperienced person should attempt it without some guidance.
  13. Dec 18, 2013 at 2:04 PM
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    i just got quoted 400$ in labor to get it done then the price of the clutch i choose does that sound about right?
  14. Dec 18, 2013 at 2:07 PM
    2000GTacoma
    Snow Hill NC
    Yeah depending on your area. I would figure around $350 to $500. It took me a little over 5 hours so figure 6 hours at a shop rate.
  15. Dec 18, 2013 at 2:33 PM
    #35
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    oh ok cool so its about right.
  16. Dec 19, 2013 at 6:12 AM
    #36
    VAYoder4167
    Frank
    Lynchburg, VA
    Ok thanks a lot I'm pretty sure it will be no problem. I've just go to wait on the marlin crawler to be back in stock.
  17. Feb 17, 2014 at 8:59 AM
    #37
    cynicalrider
    cynicalrider #NFG
    Jersey
    Hate to revive an old thread but has the Marlin Crawler clutch been out of stock since this point? I want to get it myself but it's not looking good if it's been out of stock for this long.
  18. Feb 17, 2014 at 9:07 AM
    #38
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    the throw out bearing squeal is typical of toyota's. Mine did it after i replaced mine with a new one..just about everyone's does it that i have met with a manual.
  19. Feb 17, 2014 at 9:08 AM
    #39
    Blackdawg
    Monte
    Wyoming/St. Louis
    Email them and ask..no idea. I know it was out last summer too as i had to resort with the TG ceramic clutch kit instead..very happy with it though.
  20. Feb 17, 2014 at 9:20 AM
    #40
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    i replaced mine with oem and got rid of the squeel... i couldnt wait for the marlin one
