new coil springs
Discussion in 'Suspension' started by bigdaddytaco, Sep 7, 2011.
  1. Sep 7, 2011 at 8:17 PM
    bigdaddytaco
    bigdaddytaco [OP] Well-Known Member
    jared
    sylva nc
    2000 tacoma
    ARB bumper 3 inch oldman emu lift piaa fog lights
    i have a old man emu 3 inch lift with a arb bumper and a wench and the front is starting to sag would a new set of coil springs raise itup a little bit
  2. Sep 7, 2011 at 8:24 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    If I had a dime every time someone talked about their wench ;)...what coils are on it now? I'd recommend the 883 coils for your application but even then they might sag with all that weight
  3. Sep 7, 2011 at 8:28 PM
    bigdaddytaco
    jared
    sylva nc
    2000 tacoma
    they are the old man emu heavy dutty springs but have been on ther for 5 years or so.and i just saud the wench because that is one of the main reasons for my sag.im just looking for some good heavy duty springs for a 3 inch lift that will last
  4. Sep 7, 2011 at 8:34 PM
    malander
    max
    01 limited trd 4x4
    It would help if you knew the part number on them but iirc OME had some issues with sagging springs a while back. I'm sure 883s or 822s would fix this, although id recommend 883s for the higher spring rate.
  5. Sep 7, 2011 at 9:01 PM
    bigdaddytaco
    jared
    sylva nc
    2000 tacoma
    i was looking at the eibach 620 woud those work
  6. Sep 7, 2011 at 9:03 PM
    malander
    max
    01 limited trd 4x4
    They should although I don't know how well they will ride with OME shocks. There shouldn't be any problems but you never know when mixing and matching coils and struts
  7. Sep 8, 2011 at 7:20 PM
    bigdaddytaco
    jared
    sylva nc
    2000 tacoma
    dose anyone know if these coil springs will work
  8. Sep 8, 2011 at 7:22 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    883's over the eibachs for your app.....they will go better with your shocks and i believe are a tiny bit stiffer then the eibachs to help hold the weight..
  9. Sep 8, 2011 at 7:25 PM
    bigdaddytaco
    jared
    sylva nc
    2000 tacoma
    thanks man i think thats what im gonna get
  10. Sep 8, 2011 at 7:31 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Wench:
    Winch:
  11. Sep 8, 2011 at 7:35 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    I was about to post...
  12. Sep 8, 2011 at 8:00 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Ha beat ya to it!!
    na na na nana
  13. Sep 8, 2011 at 8:19 PM
    malander
    max
    01 limited trd 4x4
    I believe the 883s are around 588# springs
