New coils or just 5100's
Discussion in 'Suspension' started by Carlo, Mar 17, 2010.
  1. Mar 17, 2010 at 5:29 PM
    Carlo
    Carlo [OP] Well-Known Member
    CA
    2010 Taco Magnetic Grey
    5100's all around, front at 0 with Ebiach springs up front; Wheelers 3 leaf AAL rear, Spidertrax
    I have a set of 5100's on order and was planing on setting them at 1.75 as my 2010 AC non TSB is sitting 2'' high in the rear. Now, I am thinking about ride quality and wonder for a couple hundred bucks would it be worth it to get a set of new coils? And, which one? I am only looking for about 1.5 inches of lift and dont plan to do anything to the rear. I am running 265/75/16's on stock wheels and like the set up just fine. Mainly looking to level and good quality ride on road/off road.
  2. Mar 17, 2010 at 8:23 PM
    ZonKs
    ZonKs Can speak french in Russian.
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    I have 5100's set to 1.75 and TRD off road (stock) coils. The ride is fantastic. Your rear (the trucks) will sag eventually, trust me. You will want at least the rear TSB if you are going to set the 5100's to 1.75. Mine is level with the TSB.
  3. Mar 17, 2010 at 9:48 PM
    Carlo
    CA
    I dont have the TRD, just the stock SR5 4x4. Maybe that has something to do with it being 2'' higher in the rear already.
  4. Mar 18, 2010 at 12:09 AM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    Well when I had the TSB springs installed and I had a 2 inch lift my rear still sat higher. So I would say the perfect setup for you, since I have had this as well is just get the 5100s and put a set of eibach coils in there for a 1.6 inch lift. It will sit almost perfectly level and ride nice.
  5. Mar 18, 2010 at 6:51 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Your best bet is 5100's with stock coils or OME coils with OME shocks. But since you already have the 5100's on order, stick with the stock coils. They are practically valved for stock applications.
  6. Mar 18, 2010 at 6:54 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    get the billys and try them out. They should be fine since your not maxing them out. If you want more lift later on you can always either put them on a higher setting or add some eibach or OME coils. Non of which are expensive.
  7. Mar 18, 2010 at 8:33 AM
    Carlo
    CA
    Ok, if I keep the stock coils, and set at 1.75 do they settle at all?
  8. Mar 18, 2010 at 10:47 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
  9. Mar 18, 2010 at 7:27 PM
    spiceman
    spiceman Well-Known Member
    Hawaii
    '07 4x4 DC OR, Desert Sand Mica
    Window Tint, Sockmonkey bed decals, Eibach 1.6" coils, 5100s front (set @ .85) / rear
    Here are Eibach Coils with 5100s set at .85 and a stock rear (no tsb). It still has about .75 inch of forward rake and the ride is smooth.
  10. Mar 18, 2010 at 9:22 PM
    Taco4x4NC
    Taco4x4NC Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    Any Vibs? I have the same set up sitting here in my house. Still wondering if I should add it? Worried about vibs...on a brand new truck if I add the above components. thoughts?
  11. Mar 19, 2010 at 12:03 AM
    spiceman
    Hawaii
    No vibes, it rides real nice and leveled out the truck. The coils only gave about an inch of lift with the 5100s set at zero. I got about 1.75 inches when I bumped the 5100s up to .85.
