New computer no sound
Discussion in 'Technology' started by DCW, Dec 30, 2011.
  1. Dec 30, 2011 at 9:36 AM
    DCW
    DCW [OP] Well-Known Member
    David
    Reno, Nevada
    2011 TRD DC Off Road
    TRD exhaust, front skidplate,5100s@1.75
    I got a new Hp for X-mass hooked up boston speakers and no sound what did I do wrong?
  2. Dec 30, 2011 at 9:38 AM
    acdronin
    acdronin Well-Known Member
    Speakers self-powered?, Plugged in? Go into Control Panel, click on sounds, click on volume or mixer, raise volume levels?
  3. Dec 30, 2011 at 9:40 AM
    DCW
    David
    Reno, Nevada
    I checked that but no luck I am not that computer savy. what else can I try
  4. Dec 30, 2011 at 9:41 AM
    DCW
    David
    Reno, Nevada
    Paper work said to hook to the green output on the back.
  5. Dec 30, 2011 at 9:44 AM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    plugged into the correct ports? my speakers only work with corresponding audio ports.
  6. Dec 30, 2011 at 9:45 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    tint, dents, scratches, two blown speakers and trying to pay her off...
    sometimes my computer will act funny about when it wants to put out sound. check your "sounds" application and if that doesn't work, turn on itunes and play a song or something, and take a pair of headphones and push them in the headphone jack and pull them in and out a couple times. . . dumb sounding fix i know, but it works on my dell sometimes.
  7. Dec 30, 2011 at 9:46 AM
    DCW
    David
    Reno, Nevada
    Speakers are self powered I plugged them in I checked the volume snd levels and nothing
  8. Dec 30, 2011 at 9:52 AM
    acdronin
    Try playing a sound file and check with headphones, if you get sound then it's not the PC, are the speakers turned up? If you have different color jacks coming from the speakers, try switching them around.
  9. Dec 30, 2011 at 9:53 AM
    Delandgixxer750
    Delandgixxer750 Well-Known Member
    Todd
    Deland, Fl.
    2008 Taco X-Cab 6-speed 4x4
    K&N Air intake, ProComp Xtreme A/T 32" 3" Lift Flowmaster 40 Exhaust
    Are the USB speaker?? any if so did windows install driver if not do you have the driver.
    Also go to your control panel, hardware & sound, manage audio devices and see if the speakers are in there if not you need to install them windows should but may not have a driver for them, if windows has no driver & you have no driver go to www.windrivers.com
    If you are in audio devices make sure they are set to default device if not click on the speakers and set has default, give it a try let me know
    Delandgixxer750
  10. Dec 30, 2011 at 9:53 AM
    DCW
    David
    Reno, Nevada
    Not even getting anything from a cd?
  11. Dec 30, 2011 at 9:56 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    audio driver installed? Does audio work without the speakers?
  12. Dec 30, 2011 at 9:57 AM
    Delandgixxer750
    Todd
    Deland, Fl.
    Is this a laptop or a desktop check your device manage and see if you have any conflicts
  13. Dec 30, 2011 at 9:59 AM
    DCW
    David
    Reno, Nevada
    desk top Hp Pavilion with beats audio if that helps?
  14. Dec 30, 2011 at 10:03 AM
    DCW
    David
    Reno, Nevada
    No audio without or with the speakers
  15. Dec 30, 2011 at 10:07 AM
    acdronin
    Look up HP support, type in No Sound into search, it sound like a configuration issue
  16. Dec 30, 2011 at 10:12 AM
    acdronin
    Didn't think of that, sound card driver, i'd look in Hardware in the control panel and see if the computer sees it, if not i would download the card driver from that card's manufacturer.
  17. Dec 30, 2011 at 10:21 AM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    OK, forget the external speakers for now.
    Get the onboard Beats Audio system working first.
    Either something is turned off or muted in your controls or the driver is properly installed.
    My sister has one of these HP's with Beats Audio and it fired right up.
    I can't remember whether or not there was a setup necessary for Beats Audio.
    Go to Control Panel > Device Manager and see what's up.
    BTW, best onboard laptop sound (w/o earphones) that I ever heard.
  18. Dec 30, 2011 at 10:24 AM
    jflan
    Vancouver, WA
    No, I would go to HP's download site for the driver.
    Beware of third party driver download sites.
    Sometimes you have to go to the card mfr's site but the driver might not have been tested in the platform (your computer make/model).
    Check all your audio controls first, before monkeying with the driver.
    Could be something simple.
  19. Dec 30, 2011 at 10:26 AM
    acdronin
    He will have to pull off the sides of the PC to find out what kind of card he has if the computer doesn't see it.
  20. Dec 30, 2011 at 10:34 AM
    jflan
    Vancouver, WA
    Not always.
    Sometimes you can run a system inventory utility like Everest Free Edition.
    I thought this was a lappy ?
