New Control Arms for 2" Lift and 33s"
Discussion in '3rd Gen. Tacomas (2016-2023)' started by baltimorebirds2, Dec 1, 2022.
  1. Dec 1, 2022 at 9:05 PM
    baltimorebirds2
    baltimorebirds2 [OP] tacomama
    Brooks
    Maryland, United States
    2018 MGM Tacoma TRD Sport DCSB 4x4
    TRD Pro 17” Wheels, Toyo Open Country AT3 33s” (255/80/R17), Hooke Road Offroad Roof Rack, LEDs (Low Beams, High Beams, Fog Lights, Interior Lights, Reverse Lights, License Plate Lights), Diode Dynamics SS3 Sport Fog Lights (Yellow), Sequential Turn Signals, OME Nitrocharger Plus, OME 4004's & HS 0.5 Spacer for 3" Lift, JBA UCA, Icon RXT Option 2 Leaf Springs 2.25" Lift, Yukon Clamshell Bushing, Alpine ILX W-650 Stereo, Infinity Primus 6004a Amplifier (140w*2), Sound Ordnance M75-4 Amplifier (75w*4), Infinity Kappa 693C Component 6x9 Speakers, Infinity Kappa 63XF 6.5 Speakers, TRD Shift Knob, Black Emblem Overlays, TRD Grille Badge, OEM Door Sill Protectors, Driver’s Seat Jackers, Pop and Lock Power Tailgate Lock, AJT Designs start button and trim, 4x4 knob, shifter trim, and cupholder trim, MESO Customs Vent Rings and Door Handle Covers, Gasshole, Drop Stops, AC Drain Mod, Bed Lights, Rough Country Roll Up Tonneau Cover, Window Tint, KDMAX Tune
    Hey all, hope all is well.
    Back in June, I put some toyo at3 33s" (255/80/17) tires on some new trd 4 runner wheels. I coupled that with some ome nitrochargers, 887 coils, and an icon AAL kit.
    It crossed my mind again though, do I really need new higher caster control arms, for my 2" lift coupled with 33s"? I mean the tires give some lift too but I'm not entirely sure if they negate the actual suspension lift or not because aren't the taller tires lifting up the suspension to be in a more relaxed position? Not quite sure.
    The alignment shop I had didn't say anything from what I remember, so I suppose the caster alignment was good?
    However, I feel like my truck is wandering a little on the highway, almost as if the steering gets kind of sensitive or just wanders a little if I'm not holding onto the wheel enough. Or, I'm overthinking it and it's just the wind blowing around a rather tall truck lol.
    So would you guys say there is a noticeable enough difference to warrant an upgrade to something like JBA's upper control arms? Would I notice that much of a difference or am I better off just saving my money?
    Any input is appreciated.
    Brooks
  2. Dec 1, 2022 at 9:36 PM
    Bishop84
    Bishop84 Well-Known Member
    More caster means more stability and comfort at higher speeds. Your caster was likely in spec near the bottom end.
    I would recommend it, but its not necessary.
    The 3" spacer lifts need it the most, but a 2" will notice a change, especially with a good alignment shop.
    The thing is with stock arm lifted alignments, you usually get higher camber (0.9 degrees ish) to get the caster barely in spec (1.5ish), so if you get better geometry, you can get closer to zero camber and higher caster (2-3).
  3. Dec 1, 2022 at 9:47 PM
    baltimorebirds2
    Brooks
    Thanks, I appreciate the info. So if I understand what you’re saying, you can get barely within the “acceptable” factory caster spec with stock arms, but you won’t get the ideal amount that you could with aftermarket arms that would potentially improve driving characteristics and such?
    Correct me if I’m wrong :D
  4. Dec 1, 2022 at 9:48 PM
    Bishop84
    Basically yes, we prefer to align lifted trucks with arms.
    SPC makes adjustable arms, but they have a decaying reputation as of late, JBAs are my favorite and they look sweet.
  5. Dec 2, 2022 at 7:53 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  6. Dec 2, 2022 at 8:05 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Bigger tires do not "negate" lift or put the suspension in a more relaxed position.
    Wandering could be caused by the truck having less caster than stock, or by the AT3 tires, or a combination thereof. Bigger off-road tires behave worse on pavement than stock tires. Aftermarket UCAs will improve this somewhat by adding more caster.
  7. Dec 2, 2022 at 8:32 AM
    baltimorebirds2
    Brooks
    I’ll look for the sheet when I get home next week, but I don’t think the shop I went to printed it…
    Can definitely feel the wind sometimes, I mean maybe it’s always been wind since it’s usually at like 70 or 80+
  8. Dec 2, 2022 at 8:33 AM
    baltimorebirds2
    Brooks
    I guess tire pressure could be relevant too, I mean I’m at 35 and think it makes sense for a 255/80/17 under normal circumstances, unless you guys have better experiences with the same tire size but different pressure
  9. Dec 2, 2022 at 8:38 AM
    gudujarlson
    Minnesota
    I've run my LT255/85r16's at various pressures and never noticed any difference in wandering. Air pressure does make a noticeable difference in ride quality, rolling resistance, and cornering, but only when varied by 25+% psi. I run mine at about 37psi most of the time.
    71tattooguy likes this.
  10. Dec 2, 2022 at 8:47 AM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
  11. Dec 2, 2022 at 9:37 AM
    gudujarlson
    Minnesota
    For what it's worth, I have a similar setup (skinny 33's and 1-2" lift), have had alignments with both 2 and 4 degree caster, and I didn't notice any difference in the handling between the two. The second alignment did however solve the slight rubbing issue I had.
