New CV axles, Differential fluid leaking from fill plug
Discussion in 'Technical Chat' started by brown84, Oct 18, 2014.
  1. Oct 18, 2014 at 8:46 AM
    brown84
    brown84 [OP] Member
    Colorado
    09 TRD Sport DC Long Bed
    3" OME suspension lift
    Hi,
    I just had both CV axles replaced on my 09 DCLB. Is it normal for fluid to be leaking out of the fill plug? I've driven it two days and was wondering if it is excess fluid from the repair, or if the front diff is continuing to leak.
    Here's a picture:
    Thanks in advance.
  2. Oct 18, 2014 at 8:58 AM
    BamaToy1997
    Bill
    Navarre, FL
    I suggest cleaning that area off with a good brake clean, or good degreaser. Then watch it over the next day or so. It could be that the area was never cleaned properly when the CV axle was replaced. The leak shows that it could even be coming from the seal at the differential housing, if it is not just residual that hasn't been cleaned.
  3. Oct 18, 2014 at 9:17 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    ^^^THIS. Don't say it's leaking until you've checked it properly. This is why Doing It Yourself is the best way. So you see what is going on
  4. Oct 18, 2014 at 9:33 AM
    brown84
    brown84 [OP] Member
    Colorado
    Thanks. I cleaned it up and will check it the next few days. It's a bit worrisome after the time and money spent at the shop.
