New CV joints with lift??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lodi781, Dec 3, 2016.
  1. Dec 3, 2016 at 7:41 PM
    lodi781
    lodi781 [OP] Alexander Supertramp
    shelton CT
    25 Tacoma Tacoma off road 6sp MT
    Has anyone here upgraded their CV joints when they lifted their truck? I have an 08 with a 3" OME lift, and about 30k into owning the lift, the two problems I had was blowing U-joints and I've had to replace the CV joints once on each side. Now I put the lift on at 60K, so the CV's went around 110K. I guess it can be argued they might have gone anyway, although I don't think so.
    So question stands, does anyone here just replace the CV's with custom ones when they lift? I think tom woods makes them, among others. Just curious.
  2. Dec 4, 2016 at 7:13 AM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    I don't do lifts, but I can tell you that when I traded my 2007 in with 137,000 miles the CV joints (and everything else) were fine.
    SB
  3. Dec 4, 2016 at 7:22 AM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    One thing that I would recommend is that you may want to install an ecgs bushing to replace the needle bearing in your front diff while you are doing the CV's this time around. If you haven't had that needle bearing go yet, you probably will soon with the 3" lift up front.
  4. Dec 4, 2016 at 7:28 AM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    It also helps if your in the 2nd gen category. But no your cvs with 3" should be fine.
  5. Dec 4, 2016 at 7:30 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    My CV's went at around 110K also. Not bad considering ,my lift went on at 30K.
  6. Dec 4, 2016 at 7:49 AM
    lodi781
    shelton CT
    I'm considering a new tacoma or 4runner. I don't mind the 4runner stock, but if I get a tacoma, I may put a lift on it, hence why I posted in the 3rd gen.
  7. Dec 4, 2016 at 7:52 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    just make sure its a proper lift that doesnt pinch or put the cv's at a bad angle...
  8. Dec 11, 2016 at 3:00 AM
    Antman000021
    Antman000021 New Member
    I just installed a Bilstine 3 inch lift with a add a leaf on the rear. Now my rear drive shaft is blowing grease out the u-joints. "note the drive shaft center support has excessive movement" (carrier bearing). the truck itself has less than 80K. is it possible that there is a miss alignment on the rear axel?
  9. Dec 11, 2016 at 7:15 AM
    Broccoli
    Airdrie Alberta
    Did you install the drop bracket for the 3" lift?
  10. Dec 11, 2016 at 10:04 AM
    Antman000021
    The lift came with new coils new shocks (4ea) spacers for the front diff and two add a leafs for the rear.
  11. Dec 11, 2016 at 3:22 PM
    Broccoli
    Airdrie Alberta
    You may need to get a drop bracket for your carrier bearing. Its possible the angle is too great and thats why it crapped out. But hopefully someone more experienced can comment or even correct me.
