New design eBay snorkel
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoJohn4x4, Oct 18, 2018.
  1. Dec 20, 2018 at 11:02 AM
    #381
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    the intakes are different, but the elbow that goes into the fender and the tube that goes back are the same part number, I just looked them up
    pray4surf and eon_blue[QUOTED] like this.
  2. Dec 20, 2018 at 11:03 AM
    #382
    eon_blue
    Azusa, CA
    Might not be too difficult then to modify it to work, I don't know if anyone in this thread has done it with a 2.7l yet but someone has to be the first!
  3. Dec 20, 2018 at 11:16 AM
    #383
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    I guess we will find out
    :sawzall:
    :mudding:
    FirstTimeFirstGen likes this.
  4. Dec 20, 2018 at 2:51 PM
    #384
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Mine is a 2.7. The ARB is supposed to fit both so I’m thinking this should work, too. I don’t know when I’ll get time to put it on though.
    foxrcing07[QUOTED] likes this.
  5. Dec 20, 2018 at 4:14 PM
    #385
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Now that I pulled the trigger, I'm wincing at the thought of drilling a hole in the fender, and in the A piller for the rivets. The cherry has been popped on my rig (my expression for when a rig isn't cherry anymore and all bets are off when thinking about cutting, welding, modding etc) but still, drilling through OEM paint just doesn't sit right with me.
  6. Dec 20, 2018 at 4:16 PM
    #386
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear SPC Upper Control Arms Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod RCI Skid Plate CBI Ditch light brackets 1.25” Wheel Spacers 2” Front Leveling Kit
    Drilling into the A pillar is the only part that makes me nervous. Fenders are easy to replace and color match.
    Gunshot-6A likes this.
  7. Dec 20, 2018 at 4:26 PM
    #387
    eon_blue
    Azusa, CA
    yeah the rivets in the a-pillar are a bit nerve wracking...at least the fender is easily replaceable if you needed to, but the a-pillar not so much lol. Some are using industrial strength mounting tape there instead, but I just bit the bullet and used the rivets. They hold very tight, no movement at all which is nice
    DW85 likes this.
  8. Dec 20, 2018 at 4:43 PM
    #388
    Brake Weight
    I used this to hold the large door trim/panels on a black ‘06 GX. They would fall off every summer in South MS but survived a couple weeks of WTX dry summer heat as well a MS summer. Apparently some good isht. Looks like it would hold as good as the paint does for sure.
    https://www.jbweld.com/products/plastic-bonder-syringe
  9. Dec 20, 2018 at 4:58 PM
    #389
    TacoJohn4x4
    TacoJohn4x4 [OP] Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    I wouldn’t worry about UV damage. Might last longer than you owning the truck.
    Buy it now and worry about it later. Worst case is you can always sell it and make your money back. If it sells out again it will only go up when it’s back in stock. I’m guessing close to the other off brand one, $160?
    I wouldn’t worry about some small holes in the a pillar. Finder are easily replaceable. Now that I’m running 33” I cut and bent my pinch weld. I’m thinking of trimming my fenders or if need be even do the cab mount chop. I’ve already did some cutting when I first installed my ALLPRO bumper. I also have weld on sliders. Move forward and don’t look back. The future is never guaranteed and things are always changing.
  10. Dec 20, 2018 at 5:09 PM
    #390
    BlackSportD
    Los Angeles
    Thats why I mention OEM paint- I just have a weird appreciation for it, more so than the next guy obviously. IRT to other things, I have weld on sliders, not one hesitation- holes in my OEM skid, zer0 f*cks. My front bumper is crooked from hitting a hillside (getting a higher angle Relentless)- larger injectors and multiple piggies no one else has run (or at least post about) - so yeah... just OCD about OEM paint I guess...
    IRT to your 33", are they still rubbing after the pinch weld mod? Or you want to run larger and thus the cab cop? Am already doing the pinch mod for my 31", but wondering about 33".
  11. Dec 20, 2018 at 6:07 PM
    #391
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    Yes I understand what you mean, nothing beats OEM paint.
    I did the pinch weld mod and got my caster aligned. Having your caster align helps a lot too. No more rubbing for street use. I haven’t taken it off road yet but I’m sure it will start rubbing on some of the obstacles. I might not need it but I don’t mind cutting my truck anymore. It’s like getting a tattoo, once you start it’s gets easier and more addictive.
    eon_blue and BlackSportD[QUOTED] like this.
  12. Dec 20, 2018 at 7:31 PM
    #392
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Pulled the trigger at $128. Estimated delivery January 10-29.
    foxrcing07 likes this.
  13. Dec 20, 2018 at 10:22 PM
    #393
    BlackSportD
    Los Angeles
    They are real conservative with that ETA, ordered mine earlier this week, it arrives tomorrow.
    SwampYota likes this.
  14. Dec 20, 2018 at 10:26 PM
    #394
    SwampYota
    Jon
    Floor mats
    Good to know, thanks!
  15. Dec 21, 2018 at 4:24 PM
    #395
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    I put it in a 2.7l
    zero modification needed
  16. Dec 21, 2018 at 4:42 PM
    #396
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    Sweet I just ordered 2
    one for me and one for my brother
  17. Dec 21, 2018 at 5:26 PM
    #397
    eon_blue
    Azusa, CA
    Huh, wonder why they don't advertise it for 2.7l then...they're missing out on potential customers
  18. Dec 21, 2018 at 5:30 PM
    #398
    SwampYota
    Jon
    Floor mats
    Just got tracking. Shipping today estimated delivery next Wednesday, 12.26.2018.
  19. Dec 21, 2018 at 8:18 PM
    #399
    BlackSportD
    Los Angeles
    Well that shipped fast.
  20. Dec 21, 2018 at 8:33 PM
    #400
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Now that I’ve potentially found a stock air intake for my 99 these look for tempting just cause #overland
