New design eBay snorkel
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoJohn4x4, Oct 18, 2018.
  1. Jan 14, 2019 at 11:03 AM
    #541
    Knoxdavid34
    Knoxdavid34 Stranger with candy
    David
    Nashville
    02 Prerunner 4x4
    TRD Off Road sticker. Not the whole package, just the sticker.
    I still like the old sock idea. Lol
    eon_blue[QUOTED] likes this.
  2. Jan 14, 2019 at 11:05 AM
    #542
    eon_blue
    Azusa, CA
    lol yeah I saw that video where the Australian dude used cooking oil and coated an old sock with it, then put it over the snorkel head. I could see doing that on a trail where you're not driving fast. I'm still learning the best way(s) to put these tricks to use, and when. I've found that it's nice peace of mind to spend an extra $20 on a cheap air filter and keep it in the cab with me while on the trails just in case I need it.
  3. Jan 14, 2019 at 11:10 AM
    #543
    Knoxdavid34
    David
    Nashville
    02 Prerunner 4x4
    That was mostly sarcasm but it is a good trick to know if you forgot/lost your filter and notice a lot of dust accumulating in the air box. I just bought on of those pre filters like you see on heavy equipment. It looks stupid so I leave it the tool box. If I'm ever in a convoy on a dirt road, I can pop it on really quick. That why I'm not restricting any airflow and filtering out the dust.
  4. Jan 14, 2019 at 3:48 PM
    #544
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Drilled the holes today. Wont be able to finish up until tomorrow though. Will say this, after drilling the holes - not bad at all. Starting and during the drilling, NERVE WRACKING AS HELL. lol
    One thing, even with the template lined up edge to edge and NOT overlapping, it seems as if its sitting a little bit further away than it should. Can't look at it more now but will take a closer look at the main hole tomorrow. Probably nothing - I'll know more once I test fit with all the hardware a little tighter.
    Oh and HOW IN THE HELL do you reach that top bolt above the air tube? lol you all were not exaggerating about that one... :rofl::rofl::rofl:
    Pics to follow.
  5. Jan 14, 2019 at 4:10 PM
    #545
    eon_blue
    Azusa, CA
    I didn't, lol. I just left that one be, the snorkel is on there tight and has no wiggle/play to it at all so I just figured I'd leave it. I couldn't work my hand up in there for the life of me. One of these days I might try again, or ask my wife to do it since she has tiny hands lol.
  6. Jan 14, 2019 at 4:17 PM
    #546
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    These snorkels dont modify the air box or anything smog related. If a smog tech flags you solely for the snorkel hes wrong. Idk if theres really anything you can do but as far as I know as long as you dont modify anything between the air filter box and the last cat, you havent modified anything smog related and are CA smog compliant.
  7. Jan 14, 2019 at 4:27 PM
    #547
    Area51Runner
    oh and another thing, never did realize just how THIN our fenders are. Crazy.
    eon_blue likes this.
  8. Jan 14, 2019 at 6:26 PM
    #548
    Knoxdavid34
    David
    Nashville
    02 Prerunner 4x4
    That took longer than anything else during the install. I held it between my index and middle finger with my hand flat. After dropping it several times and spending way too much time trying to find it in the gravel, I finally got a thread to bite. That nut is a bitch!
    Area51Runner[QUOTED] likes this.
  9. Jan 14, 2019 at 11:34 PM
    #549
    TacoJohn4x4
    TacoJohn4x4 [OP] Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    You can use the step drill to make 1-2 out of the 3 bolt holes bigger. That will help with alignment. Don’t worry about making those bolt holes bigger since the washer/nut is what holds the snorkel base in place.
    Don’t stress over that upper top bolt :)
  10. Jan 15, 2019 at 4:29 PM
    #550
    Area51Runner
    So a quick update and an IMPORTANT NOTE to anyone with a planned install -
    DO NOT bother drilling that top bolt hole!
    Pointless unless:
    • You plan on removing the fender to thread it on or,
    • You are Slender Man
    Just drill out the 2 on each side of the air tube and the 3 on the a-pillar.
    After half the morning of trying to get my arm in the right position and threading that locknut, my arm and knuckles are shredded. Save yourself the torture... SKIP IT.
    Also, note - the stock air intake tube has two bolts which need to be removed. The antenna also needs to be unbolted and pulled down out of the way (makes attaching the air hose easier and/or shredding your arm if you want to try for that top nut). These 3 bolts are 10mm.
    You will definitely need a sharp hole saw and drill bits. I picked up the Milwaukee others have mentioned
    (https://www.amazon.com/Milwaukee-49-56-0193-2-Inch-Hardened-Hole/dp/B0017WTULA)
    If you don't have one, you'll also need an arbor since it does not come with one
    (https://www.amazon.com/Milwaukee-49-56-7250-Hole-Large-Arbor/dp/B004AGGKWC)
    First drill bit I grabbed for my pilot holes was a little worn and skipped on me lol. Nothing serious and covered by the snorkel base but definitely make sure your gear is ready for the job. Rookie mistake, I should've saw it coming. If you have a spring loaded/automatic center punch for marking drill sites, use it. This should help with/eliminate drill bit wander (https://www.amazon.com/d/Center-Punches/Automatic-Center-Punch-Adjustable-Tension/B07BJMYRFQ)
    While the included hose clamps do the job, might consider replacing them with better quality clamps. I noticed the two I received for the hose kind of cheaped out on me when tightening down.
    Other than that, good to go.
    EDIT: you can do the top mounting hole. To give yourself enough room, just unbolt the fender at the bottom of the wheelwell. This should give you some extra room. Be careful not to pry it back to far of course.
  11. Jan 15, 2019 at 4:34 PM
    #551
    eon_blue
    Azusa, CA
    I was considering getting a set of those hose clamps that require a specific kind of key to tighten/loosen, as a way to prevent some a-hole from walking by with a screwdriver and removing the snorkel head. Sucks but it's something I have to be wary of living in a major metropolitan area
  12. Jan 15, 2019 at 4:38 PM
    #552
    Area51Runner
    Surprisingly, the snorkel head clamp tightened up fine. No issues. Chalk it up to the cheap price lol.
    You definitely have a point though. Worried about the same thing. I ended up positioning it kind of facing the driver side and pointing towards the tire. Someone wants to take it, they'll have to jump up on the hood or have a step ladder to get angle on it.
    Trowbocop and eon_blue[QUOTED] like this.
  13. Jan 15, 2019 at 4:57 PM
    #553
    eon_blue
    Azusa, CA
    That's a good idea, I'll do the same thing...I have one of those angled screwdrivers so I can work it into a spot where someone can't get to it with a normal one
  14. Jan 16, 2019 at 9:01 PM
    #554
    Area51Runner
    Little feedback on this one - because of the angle of the snorkel side of the bracket, you will not be able to use this riveter. The head will get in the way and you will not be able to seat it completely down on the rivet. The other riveter I had needed a six million dollar man death grip. All because of that damn angle of the bracket - heavier duty riveters are out.
    This results in a loose rivet :annoyed: which will have to be drilled out
    After prepping all over again, I think either rivet nuts or self tapping screws will be the next step. I was able to track down some nylon inserts like the ARB version has so might try those before moving to the rivnuts/or screws.
    If I had to do it all over again, I would've just positioned the bracket and used self tapping ss screws in the first place. Problem solved. :censored:
    MY1STGENTACO likes this.
  15. Jan 16, 2019 at 9:12 PM
    #555
    MY1STGENTACO
    MY1STGENTACO Well-Known Member
    MORA
    NEW MEXICO
    2001 Toyota Tacoma
    OME 3" LIFT 882'S NITROCHARGERS ALL AROUND
    Thanks a lot Mike!! This will help tons when I decide to buy this snorkel (that’s if it comes back in stock) and also if the price doesn’t jump that much.
    Show us some pics ! When you get the chance.
  16. Jan 16, 2019 at 9:18 PM
    #556
    Area51Runner
    I would still pick it up when it comes back in stock. Sure it has its hiccups but then again, you have to look at the price point. If you do, look at (in addition to the items in the Products Discussed section at page bottom):
    Heavier duty hose clamps for the air hose (x2)
    Self Tapping Stainless Steel screws/bolts for the bracket---> A Pillar
    Silicone for the a pillar holes and a low odor/sensor safe silicone for the airhose to factory intake tube
    *if going to attempt the rivets, make sure you have a nice sharp new handheld (like the ones you can pickup at Lowes/Home Depot) riveter on hand. Might work for just those 3. The one I first tried I had put through its paces on a Snugtop Shell refurb. Needless to say, it wasn't up to the challenge.
    Good luck and will do on the pics, as soon as I finish the damn thing lol (tomorrow hopefully)
    Trowbocop and MY1STGENTACO like this.
  17. Jan 17, 2019 at 8:20 AM
    #557
    Knoxdavid34
    David
    Nashville
    02 Prerunner 4x4
    I guess I have a million dollar man death grip because I used a shitty harbor freight hand held. It wasn't super easy, but you just man up and squeeze the hell out of the SOB while pushing into the bracket and it will tighten up. Also take smaller bites. The closer your hand is to a fist, the stronger your grip will be.
    I have both styles of riveters. One in the garage (the cheap harbor freight), and one the work truck (the "heavy duty" Amazon one). Both have the same size head and either would have worked. I didn't get my rivet flush against the bracket but I didn't need to. Just get most of it onto the hole. The way a rivet works is it squeezes two pieces of metal together by pulling the mandrel head through the rivet, expanding the back of the rivet to a size larger than the hole. This pulls the rivet head towards the mandrel head and because neither is larger enough to get through the hole, and squeezes the 2 pieces of metal until the mandrel pops leaving two joinded pieces of material. Because of this, even if you come in at and angle and the head is not completely flush, it will pull the head flush in the end.
    What I usually see that causes loose rivets is not giving firm steady pressure. If you wiggle the rivet gun while it is pulling on the mandrel, that weakens the mandrel and it will cause it to break prematurely before the head is pulled flush.
    I really didn't like the idea of using sheet metal screws. There isn't enough material there to get a screw to really "bite". When it come to connecting a part to thin metal, like the pillars on our truck; a rivet, rivet nut, or a through bolt is the the best option. In fact I think I recall some people talking about using a piece of rubber, foam, or something to stop a rattle between the pillar and bracket. Did you guys you use screws or rivets?
    Also a dab a blue thread lock will keep the bolts from coming loose later if you decide to go with rivet nuts.
  18. Jan 17, 2019 at 11:34 AM
    #558
    eon_blue
    Azusa, CA
    I used the same Harbor Freight rivet gun, you're right it was a bitch to squeeze the rivets on but it worked nonetheless. I had to use a step ladder to get a good angle on it even though I'm 5'11 but otherwise I could see it being nearly impossible. They were a bitch to get on but now that they are, they hold it nice and snug
    Knoxdavid34[QUOTED] likes this.
  19. Jan 17, 2019 at 4:39 PM
    #559
    TacoDeAlex
    TacoDeAlex TTC #0177
    Alex
    Houston, Texas
    2003 DC 4WD
    This is what I get for not being on TW for awhile. Totally missed out on this. I much prefer the way this and the arb snorkel are designed as opposed to the hilt versions. Anybody know when the next stock will be ready? :help:
  20. Jan 17, 2019 at 5:04 PM
    #560
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    I emailed ebay seller 2 days ago. Got a fast reply. All they said was make sure to place item on your watch list and you will be notified when item is back in stock. Other wise they don't have any dates on next batch.
    Time to wait I guess.
    Trowbocop likes this.
