New Discounted New & Used Parts @ Marlin Crawler
Discussion in 'Marlin Crawler' started by Marlin Crawler, Aug 1, 2022.
  1. Aug 1, 2022 at 2:45 PM
    Marlin Crawler
    Marlin Crawler [OP] Well-Known Member Vendor
    Fresno, CA
    We've been rearranging and cleaning our two warehouses and have added many new & used discounted parts to our site!
    Check each item for more details. View the full listing here: MarlinCrawler.com/discounted-parts
    First come, first serve!
    [​IMG] [​IMG] [​IMG]
    - 21 spline 4.7 Comp Input Gear -- Bilstein 24-186636 -- Bilstein 24-187183 -
    - Bilstein 24-232173 -- Bilstein 33-170794 -- Bilstein 33-230375 -
    - Bilstein 33-230399 -- Bilstein 33-247724 -- CV Joint Double Cardan Cores -
    - G & W Series Bell Housing -- HD Transfer Case Mount -- Land Cruiser 3-speed T/Case Input Seal -
    - Land Cruiser Split Case Output Shaft Nut -- MOOG EV800529 Tacoma Tie Rod End -- Marlin Crawler 4.0 Transfer Case Adapter Plate -
    - NEW L52 Shift Handle -- Nachi 6306N Bearing -- New 225C-135A Detroit Locker for GM 9.5" 14 Bolt -
    - New Clutch Master Cylinder Land Cruiser -- New Clutch Master Cylinder Land Cruiser -- New Clutch Master Cylinder Land Cruiser -
    - New Clutch Master Cylinder Land Cruiser -- New Clutch Slave Cylinder Land Cruiser -- New Clutch Slave Cylinder Land Cruiser -
    - New Clutch Slave Cylinder Land Cruiser -- New Disc Brake Pads for Lexus and Land Cruiser -- New Disc Brake Pads for Toyota Cressida and Pickup -
    - New Disc Brake Pads for Toyota and Lexus -- New Disc Brake Pads for Toyota pickup, 4Runner, and Land Cruiser -- New FJ60 Brake Rotor -
    - New H55F Transmission Main Shaft -- New MOOG ES80895 -- New Nitro Gear MKTV6-B -
    - New Nitro Gear T100-456-NG -- New Nitro Gear T7.5-411-NG -- New Nitro Gear T8R-456R-NG -
    - New Nitro Gear T8S-456RT-NG -- New T360 3.0 Chain Case Adapter -- New USA Standard ZK REV-B -
    - New USA Standard ZK-TLC-A -- OEM High Pinion 4.11 Ring & Pinion -- OEM V6 4.11 Ring & Pinion -
    - Procomp 321518 Shock -- Procomp OE14125 Struts with P-Pack -- R150F (3.0L 3VZE) Bell Housing -
    - R154 Bell Housing -- Shifter Boot Ring -- Steering Stabilizer kit -
    - Stock FJ80 Drive Flanges -- Tacoma 3.4 Pressure Plate and Disc -- Tacoma R150F Bell Housing -
    [​IMG] [​IMG]
    Transfer Case Shfiter Block-off Plate -- VSS for 3.0 Chain Transfer Case
    We have already sold and removed over 20 products from the site, including some used 4.70:1 gear sets, 23-spline Turbo input gears, and a couple Dual Case adapter kits that were missing some pieces. Subscribe to our Newsletter to be the first to hear about offerings like this!
    MarlinCrawler.com/newsletter
  2. Aug 8, 2022 at 2:27 PM
    Marlin Crawler
    Fresno, CA
  3. Aug 12, 2022 at 3:36 PM
    Marlin Crawler
    Fresno, CA
  4. Aug 16, 2022 at 8:18 AM
    Marlin Crawler
    Fresno, CA
    Got some new 2" wheel spacers for all you Toyota and GM owners out there!
    These were purchased for a customer who then changed plans.
    6x5.5 pattern, lug centric. M12x1.50 class 12.9 studs
    - 2" Wide Wheel Spacers Only $45! -
