New Dometic CFX3 Coolers
Discussion in 'Deals & Coupons' started by Dometic, Jan 16, 2020.
  1. Jan 16, 2020 at 2:30 PM
    Dometic
    Dometic [OP] Well-Known Member Vendor
    2016 Tacoma
    NYCTaco52, JSmith501, erice and 2 others like this.
  2. Jan 22, 2020 at 4:52 PM
    Dometic
    2016 Tacoma
    Slides for the CFX3 models
    Key upgrades from the CFX line of slides
    • Lighter but same strength
    • 3” more extension in same footprint
    • New release mechanism - a lot more reliable and removes slop when slide is latched
    • Dust cover to keep sand out
    • Moved mounting holes for easier installation
    • Improved packaging to keep the slides in great shape until you install
    • Made in USA
    Slide for the CFX3 28-35
    Slide for the CFX3 55IM
    Slide for the CFX3 75-95
    Slide for the CFX3 100
    Generally all are very similar in design except for the size of the slide and the cooler it matches up with.
    Availability
    You'll find additional product information and pre-orders open for the slides mid-March 2020.
    Click here to visit our Accessories page
    Note - As of Jan 22, 2020 we still have slides for the CFX series up on our site under the Accessories area.
    DOMETIC
    mobile living made easy
    shop.dometic.com
    Use promo code TacomaW20 for $25 off your order of $75+
    Bastek likes this.
  3. Feb 25, 2020 at 10:03 AM
    Dometic
    2016 Tacoma
    I'd shared some noise level specs in another thread and thought they'd be useful here as well.
    These are the dB levels on all the models in our CFX3 line when they are running:
    CFX3 35 44 dB
    CFX3 45 47 dB
    CFX3 55IM 48 dB
    CFX3 75DZ 50 dB
    CFX3 95DZ 50 dB
    CFX3 100 50 dB
    To compare:
    60 dB would be a conversation in restaurant, office, background music, or an air conditioning unit at 100 feet.
    50 dB would be a quiet suburb, conversation at home or large electrical transformers at 100 feet.
    40 dB would be a library, bird calls (44 dB), or the lowest limit of urban ambient sound
    30 dB would be a quiet rural area
    DOMETIC
    shop.dometic.com
  4. Feb 26, 2020 at 9:14 AM
    Dometic
    2016 Tacoma
    Over a lot of conversations, we've heard a lot of questions related to fridge use and energy consumption; in particular, how long can you run a fridge without ending up in a "no-start" situation.
    There are a lot of factors involved in determining this: type of battery or batteries, condition of the charging system, wiring to the fridge, how often you open the fridge, actual electrical consumption that the fridge requires, etc. While we may not be able to determine the condition of your wiring or charging system, we can help with info on what the CFX3 line of fridges consumes power-wise.
    In the above graph, we've measured each of our CFX3 models running at typical fridge (39 degrees F) and freezer temperatures (5 degrees F) and how external ambient temp impacts energy consumption. Given that the hottest temps will be in the day, you can rest assured that power consumption at night will be much lower regardless of what temp you set.
    While the above graph will help you decide what CFX3 you might be interested in and how your power system will support, you'll also have access to our updated app. Not only does it help you control and monitoring everything on your cooler, it even tracks power consumption. You'll quickly get a feel of how it works with your battery, batteries, or a stand-alone power source like our PLB-40.
    DOMETIC
    shop.dometic.com
    asudevil likes this.
  5. Mar 12, 2020 at 4:27 PM
    Dometic
    2016 Tacoma
    I got a question from a forum member and thought it would be helpful to share here as well.
    The question was how long would the CFX3 75DZ run if using the Dometic PLB40 energy supply and the ambient temp was 75F?
    Given that the PLB40 has 40Ah of capacity, ambient temperature is constant at 75F, and the 75DZ consumes .8-.9 Ah/h (rounding up to 1Ah/h just for simplicity) holding internal temp to 39F, you should get around 40 hours of use - little more/little less depending on how you have it packed, how many times you open it, etc.
    If you were running the internal temp at 5F, the 75DZ would be consuming about 2.7Ah/h, so the run time with the PLB40 would be around 14-15hrs. Plenty for overnight, and you are on the move and charging the next day.
    The best part of the PLB40 is that you can use it in-line (switched power from the vehicle to the PLB40 then to the cooler). As you drive, it charges the PLB40 and also powers the cooler. When you stop, it just pulls from the PLB40, so you aren't drawing down your main battery.
    If you haven't seen this video it might be helpful...
    And a good walkthrough by Main Line Overland...
    For more info on the PLB40 click here
    DOMETIC
    shop.dometic.com
  6. Apr 1, 2020 at 5:43 PM
    GC1990
    GC1990 Well-Known Member
    Graham
    Tampa, FL
    2017 TRDOR ACLB
    Might be a stupid question but are those estimated power draws based on the lowest setting between the two zones? For example, in the first scenario at 39F, that would be both sections at 39F... But in the second scenario it could be 5F in one zone and the same or higher temperature in the other correct? Is each section of the cooler individually baffled from the compressor so that in fridge/freezer mode one section receives more cooling than the other? Sorry if that doesn't make sense, trying to compare it to how my home fridge works!
  7. Apr 16, 2020 at 6:14 PM
    Dometic
    2016 Tacoma
    Sorry for the delay in getting back to you.
    The estimated draw testing was done with both zones set to the same temp.
    As for how the zones are separated and cooled let me get back to you on this. I'll reach out to the product team to ask and get accurate detail since I've not personally seen a deconstructed view of the system.
    DOMETIC
    shop.dometic.com
  8. Apr 16, 2020 at 8:32 PM
    brywebb11
    brywebb11 Active Member
    Bryson
    White Tacoma TRD Offroad Access Cab
    When will the CFX3 55IM come back in stock? I'm guessing the whole COVID thing is slowing stuff down... any idea as to when it will be back though?
  9. Apr 17, 2020 at 8:12 AM
    Dometic
    2016 Tacoma
    In a call earlier this week, I heard that there was some additional stock of CFX3 models coming in. Unfortunately, even with the new shipment, all the 55IMs have already been spoken for. We're hoping that by the end of month/early next, we'll have more in stock.
    DOMETIC
    shop.dometic.com
  10. Apr 20, 2020 at 8:26 AM
    Dometic
    2016 Tacoma
  11. Apr 20, 2020 at 8:47 AM
    brywebb11
    Bryson
    Awesome! Thank you for the update!
  12. Apr 20, 2020 at 1:24 PM
    Dometic
    2016 Tacoma
    I wanted to follow up on how the cooler sections work.
    There is one compressor and one controller. There are two evaporator systems, one for each compartment. A solenoid diverts coolant to each compartment depending on the feedback it is getting from the temp sensor in each zone.
    Each of zone is controlled. This is different than other types of dual zone fridges where there is one large compartment with a removable divider. With these you can’t easily dictate the temp in each compartment - you can only use trial and error.
    Hope this helps!
    DOMETIC
    shop.dometic.com
    GC1990[QUOTED] likes this.
  13. Jul 6, 2020 at 5:54 PM
    Azdvo
    Azdvo DuneFreq
    Shawn
    Yuma, AZ
    2020 TRD 4x4
    Eibach Pro Lift - Toyo AT3's 285/70/17
    Interested... looking into these now.
  14. Jul 6, 2020 at 6:14 PM
    YMMPRO
    YMMPRO Well-Known Member
    Northern Alberta, Canada
    2018 Super White Tacoma Pro
    TRD Intake / Falken Wildpeak AT3W
    Any idea when covers for the new models will be available?
    Bastek likes this.
  15. Jul 8, 2020 at 1:06 PM
    Dometic
    2016 Tacoma
    Our web store is showing covers being in stock for all CFX3 models right now. Inventory seems to be moving quickly for these so jump over and get an order in as soon as you can.
    PS - don't forget to use the coupon code below o_O
    DOMETIC
    shop.dometic.com
  16. Jul 8, 2020 at 1:07 PM
    Jpmurph
    Jpmurph Well-Known Member
    17 DCLB TRDOR
    YMMPRO[QUOTED] likes this.
  17. Jul 8, 2020 at 3:58 PM
    YMMPRO
    Im in Canada and it says coming soon on the site
  18. Jul 10, 2020 at 9:05 PM
    cactushead
    cactushead Well-Known Member
    San Diego
    2017 MGM DCSB 4x4 TRDOR
    Front hitch, 5100's, 885's, Snugtop XV, Slimline II, Sumos, bed platform, AAL, interior LED lights in cab and bed, exterior camp/backup LED's, Rigid DOT Fogs and D2 Pro Spots, Mega Ultra +130 bulbs, heavy-duty fog light, spot light, and low beam wiring harness, Weathertech mats, Re-routed dif breather and A/C drip line, dash cam, front and side cameras, anytime rear camera and nav, Blue Seas fused bus bars to cab and bed, heavy-duty bus bar w/Anderson quick disconnects under the hood for powering winch, solar, air compressor, and other accessories.
    Will one of the new CFX3 slides work with an older CFX 45?
  19. Jul 11, 2020 at 11:25 PM
    kevjitzoo
    kevjitzoo Well-Known Member
    Kevin
    Seattle, WA
    2019 Toyota Tacoma TRD Offroad
    Any pictures of a 55im in a 3rd gen tacoma passenger cab?
  20. Jul 13, 2020 at 9:03 AM
    Dometic
    2016 Tacoma
    Do you mean a CFX40? If so, this one is what you'll need - CFX3 SLD3545.
    We're hoping to finally have them up on the web site and ready to order around July 30th.
    When you are able to order be sure to use the promo code below. It will save you a few $$ on the slider :thumbsup:
    DOMETIC
    shop.dometic.com
