New Drive Shaft
Discussion in '2nd Gen. Tacomas (2005-2015)' started by paulismydog, Sep 30, 2024.
  1. Sep 30, 2024 at 8:04 AM
    paulismydog
    paulismydog [OP] Member
    Good Morning. 2007 5 lug, regular cab, regular bed. My local shop says I need new drive shaft. Vibration when in gear but stopped. Also vibration above 45 mph. Will check motor mounts before doing driveshaft. Quote is $900 for new driveshaft and install. They are a great shop but having replaced ujoints myself I am assuming I can install this myself. Can get get new oem shaft delivered for 400. My question is: do new drive shafts usually have new ujoints and mounts pre installed? Or do I need to get new ones and install myself? I’ve searched but have gotten no definitive answer. I am asking because if I have to deal with ujoints myself I may just have shop do it. Thanks. Bob
    SethM likes this.
  2. Sep 30, 2024 at 9:23 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    drive shaft usually comes complete with u joints and center bearing
    paulismydog[OP] likes this.
  3. Sep 30, 2024 at 9:44 AM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    Will come complete and balanced. Depending on brand ujoints will not be great quality. Most likely oem ujoints will not fit. I replaced my driveshaft with and ebay part was difficult to find exact size u joint. Have been running for 2 years with ujoints being replaced after about a year due to failure. You can definitely replace the driveshaft yourself with a ratchet strap and a couple jackstands.
  4. Sep 30, 2024 at 10:08 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Is that your chief complaint? Vibration when stopped? I dont see how a driveshaft can cause vibrations when fully stopped. If the wheels aren't turning neither is the drive shaft..
  5. Sep 30, 2024 at 10:19 AM
    paulismydog
    That and vibration above 45 mph. I will check motor mounts before I order driveshaft. Thanks.
  6. Sep 30, 2024 at 10:19 AM
    paulismydog
    Thank you.
  7. Sep 30, 2024 at 10:19 AM
    paulismydog
    Thank you.
  8. Sep 30, 2024 at 10:20 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Likely motor or transmission mounts. Not very likely the driveshaft.
    EDIT: The vibration around 45 mph might be the driveshaft, but not while stopped. You may have more than one issue here. If the rubber in the center support bearing is toast, your transmission mount or motor mounts might be toast as well.
    The center support bearing can be replaced much cheaper than an entire driveshaft.
    EDIT #2: If you have a 5-lug regular cab, you probably have a single-piece driveshaft and no center support bearing.
    Still leaning toward motor and tranny mounts.
  9. Sep 30, 2024 at 10:22 AM
    paulismydog
    Thanks.
  10. Sep 30, 2024 at 10:31 AM
    SethM
    Seth
    Los Angeles ca
    Vibration while not moving? Sounds like something else? A pulley? Harmonic balancer?
  11. Sep 30, 2024 at 11:03 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Missfiring??????? Fuel system??????? Electrical???????
    SethM[QUOTED] likes this.
  12. Sep 30, 2024 at 11:09 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    For shits and giggles pop the number four coil out (because it’s easiest to get to) and see if the tip is covered in oil or dry.
  13. Sep 30, 2024 at 1:53 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I'm 70 years old in March and have been working on cars since I was 14 years old. This is my experience and is not absolute.
    I've never had to replace an engine / transmission mount.
    I've never seen where a mount replacement fixed a vibration issue.
    I don't understand why they suggested a complete drive shaft replacement when it can be easily rebuilt with new universal joints and center bearing. The exception is if it were damaged by an impact to the shaft or a damaged yoke... Did the shop say why other than you just need a new one?
    Clearwater Bill, Knudsen and SR-71A like this.
  14. Oct 1, 2024 at 2:56 PM
    Knudsen
    Knudsen Well-Known Member
    Jon
    2008 Access Door TuRD
    To bet installed: bling grill, headlights, fog lights.
    I’m 10 years behind you and agree with all you said. I had an MGB I ran hard that had a motor mount with the rubber completely separated. Replaced it. Had to make a special wrench. Couldn’t tell the difference with the new mount installed.
    Jimmyh[QUOTED] likes this.
  15. Oct 1, 2024 at 3:09 PM
    Clearwater Bill
    Billy
    Largo Florida
    If your descriptions are accurate and complete, someone is fishing for your wallet.
    Jimmyh likes this.
