New Duratracs and vibrations/wandering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Buzzoff, Mar 19, 2010.
  1. Mar 19, 2010 at 4:40 PM
    Buzzoff
    Buzzoff [OP] Don't go ninja'in nobody don't need ninja'in
    The Nickel/5th Ward
    09 Tacoma DC TRD Speedway Blue
    Blacked out windows, 5100's@1.75", KMC XD Hoss795 16x8
    Just got some new GY Duratracs 265/75/16 on my 09TRD DC about an hours ago. I had the stock BFG Rugged Trails 265/70/16 on it and have the 5100's set at 1.75.
    Prior to the Duratracs the truck drove perfect. Got new tires on and on the way home there was some vibration in the steering wheel and some wandering on the road. Tire are at about 38 psi all around
    Would this be an alignment issue, a balance issue, or what? Thanks in advance
  2. Mar 19, 2010 at 4:41 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    well first of all 38psi is too much, but you probably just need rebalencing.
  3. Mar 19, 2010 at 4:43 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i'd get them rebalanced....could have thrown a weight...and definitely lower the tire pressure. and its just me....but i always get an alignment with new tires....just for piece of mind. yours may not need it....a simple rebalancing and tp adjustment may suffice just fine.
  4. Mar 19, 2010 at 4:46 PM
    Buzzoff
    The Nickel/5th Ward
    Thanks, I'll definitely get them rebalanced. What tp would ya'll recommend?
  5. Mar 19, 2010 at 4:46 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i'd start around 32 psi....especially in the front and go from there.
  6. Mar 19, 2010 at 4:58 PM
    NWtacoma
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    recomended tire pressure is on the sticker on your door.
  7. Mar 19, 2010 at 5:03 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    What is the load range of the Duratracs? I'm sure they just need to be re-balanced.
  8. Mar 19, 2010 at 5:06 PM
    Buzzoff
    The Nickel/5th Ward
    C
  9. Mar 19, 2010 at 7:15 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    That's with OEM tires.
    The easiest way to know for sure is the chalk line method. Draw a chalk line across the width of the tire tread, drive a couple hundred feet, and check the see how the line has worn off. If it isn't worn evenly, then your pressure is incorrect. Worn off in the middle but still showing on the outer sides = too much pressure. Worn off on the sides but showing in the middle = not enough.
  10. Mar 19, 2010 at 8:08 PM
    Buzzoff
    The Nickel/5th Ward
    Thanks for the info!!! I'm going to try it tomorrow.
    BTW I let some air out to 32 psi and a HUGE WOW!!! It drives a million times better!!!!
  11. Mar 19, 2010 at 10:51 PM
    Chester
    Chester Well-Known Member
    Nor Cal
    07 Access Cab TRD-OR M-V6 4x4
    Rear Spring TSB,Locker Mod,In bed cargo lights,Fully de-badged,TRD Seat Covers,Trailer Harness Relocation,Painted wheels,Extra tie-downs,5100's,Biceman lighting,09 stereo with sirius & isimple ipod interface,Rear diff breather mod,K&N Air Filter
    Mine does this also,I thought some of it was due to the tire shop putting all the weights on the inside
  12. Mar 20, 2010 at 7:35 AM
    fau8823
    fau8823 Well-Known Member
    Tom
    Hampton Roads, VA
    2010 Tacoma Sport 4x4
    Tint-20%, Kenwood 2 meter radio, firestik 2 meter antenna on a BAMF tailgate mount, Extang Solid Fold , Pioneer bhs-3500 HU, clazzio leather seats, Scangauge II
    When you get a chance, let me know how those tires are affecting your gas mileage. I loved the look, but thought the tread and weight would kill my mileage. I went with the hankooks (lighter). Thanks!
  13. Mar 20, 2010 at 8:15 AM
    Buzzoff
    The Nickel/5th Ward
    Sure will. If I am correct the GY's are 45 lbs/each and the Rugged Trails were 37 lb/each. Also from what I have heard the speedometer was a little off with the BFG Rugged Trails and the 265/75/16's get it closer to being true...I dunno:notsure::notsure:
    I keep track of my mileage everytime I gas up and had been around 20.8 MPG....I'm certain it will definitely go down for the above said things but hopefully not much.
  14. Mar 20, 2010 at 10:02 AM
    dexterdog
    Oly WA
    2012 F150
    Switching to a 265/75/16 tire definitely brings the speedo closer to the actual speed. My GPS and speedo are now pretty close to the same.
  15. Mar 23, 2010 at 8:27 PM
    Buzzoff
    The Nickel/5th Ward
    Just an update on the MPG from my Duratracs. With the stock BFG rugged Trails 265/70/16 I was usually getting around 20.8-20.9 MPG. I drive 114 mile round trip a day, 95% highway, and with a very light foot...60-70MPH with an occasional 75 here and there.
    With the new Duratracs 265/75/16 I filled up today and was amazed that it was at 20.3 MPG. I still need to get them re-balanced and possibly an alignment but I was VERY happy. The looks are awesome and there is a little hummmm at around 60MPH.
  16. Mar 23, 2010 at 8:39 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Another factor is the larger more spread out tread on the tire = less contact with pavement = squirrely feeling. This will get much better in 100miles or so once the tread evens out a little.
  17. Mar 23, 2010 at 8:41 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    i agree by goign with your door jamb sticker, its a good rule of thumb to use as thats based on your trucks weight. i run 30psi in my 265/65r17s front and rear though the door sticker says 29 with 247/75r16s and it rides great.
  18. Mar 23, 2010 at 9:43 PM
    ZonKs
    ZonKs Can speak french in Russian.
    Glendale, CA
    =p
    Damn, mine dropped a few MPG with my 265/75/16 BFG AT's. I get around 17.8 now.
  19. Mar 23, 2010 at 9:46 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    i dont think 38 is too much man, i run 45psi dd on my 265/75/16 and get a mpg better
    i had balancing issues went to discount tire said fix it or buy my tires and i will buy new ones and maybe not from you. they ended up fixing my vib after 20k miles. instead of putting the weight on the inside of the wheel they put them on in the stock fashion on the lip of the rim and it fixed my shakes :) hope this helps
