new EGR issues
Discussion in 'Technical Chat' started by dustinclm, Mar 14, 2011.
  1. Mar 14, 2011 at 1:48 PM
    dustinclm
    dustinclm [OP] Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    so i took off my egr valve off yesterday and cleaned it with some seafoam deep creep...when i put it back on and went for a drive i can hear this loud ticking noise when accelerating (when i get to about 1700+ rpms i hear it). it does not sound like a leak, too distinct. its not audible when idling and or holding a constant speed. could there be something inside the EGR valve be tapping? is this bad?
  2. Mar 14, 2011 at 1:50 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    sounds like the egr gasket is leaking
  3. Mar 14, 2011 at 1:52 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    This ^^^^ always replace the gasket. It's always a good idea to replace any gasket in your exhaust system when removing and re-installing.
    Back in my old Honda I kept getting a system too lean code thrown and it was driving me nuts, I replaced the 02 sensor, dizzy cap and rotor, plus wires, plugs, cleaned the EGR system, clean the IACV, and a billion other things. it took me 6 months of failing emissions due to not being "ready" to finally pinpoint that I had a vacuum leak due to a leaky EGR valve gasket on my intake manifold. $5 gasket later problem fixed and the car passed emissions about 2 days later after it ran through readiness checks.
  4. Mar 14, 2011 at 1:58 PM
    dustinclm
    Thibodaux, La
    i thought it was a leak for sure but i put gasket sealer over everything, unless i missed a spot....i guess i can go check again. would i have to order the gasket from toyota or can i get it at an autoparts store?
  5. Mar 14, 2011 at 1:59 PM
    DIYPV
    DIYPV Member
    02 PreRunner 2.7
    second motor 20.5k on it
    does it sound like the PCV valve ball popping back and forth?
  6. Mar 14, 2011 at 2:19 PM
    dustinclm
    Thibodaux, La
    i couldnt tell you what the sounds like or where that is. its a distinct tapping, like a clicking (my girlfriend even noticed it), doesnt sound like air leaking, only when over 1700+ rpms when accelerating. i was thinking it was something like the egr valve opening and closing rapidly
    where is the PCV valve and how would i test that/fix it?
    i never had this noise until i cleaned the EGR.
  7. Mar 14, 2011 at 3:22 PM
    dustinclm
    Thibodaux, La
    could this just be something due to that it was just cleaned from being stuck open? bad solenoid? i hope it is a leak but i cant feel it when i look for it and only hear this when im accelerating, im getting a new gasket tomorrow though. any other ideas out there?
  8. Mar 15, 2011 at 12:25 PM
    dustinclm
    Thibodaux, La
    ok update...so i replaced the gasket and had my g/f hold the truck at 2000rpm and did not hear a ticking noise. drove down the road and heard the ticking noise. then found a small leak in one area around the gasket. i put my finger over it and the rpms jumped up a little. sp i put some gasket sealer over it. if i still hear a ticking noise once that is dry, then it isnt a leak and i am lost on this one. ticking ONLY when driving...
    Still have a ticking noise....air leak is pretty much ruled out. I can hear it if I'm in park and rev up the motor. it's only when driving/accelerating. anyone out there who knows more than me, please help me figure out what this could be. no lines are unplugged and all I did was clean the EGR valve to get it in stuck. could it be the valve opening and closing, and nothing actuall wrong?
  9. Mar 15, 2011 at 4:08 PM
    dustinclm
    Thibodaux, La
    took out the pcv valve and ran some Seafoam through it. I shook it and could still here the ball inside rattle so that's still good I guess but I highly doubt it's the culprit.
    I don't know where or what else to check. or why it's only audible when I'm driving and not when I have someone rev the engine and I look under the hood
  10. Mar 15, 2011 at 4:09 PM
    dustinclm
    Thibodaux, La
    maybe chris 4x4 could help on this one haha
