new emblem in grill
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sunruner19, Dec 13, 2007.
  1. Dec 13, 2007 at 12:27 PM
    sunruner19
    sunruner19 [OP] Senior Senile Member
    Bill
    Great Sacandaga Lake region Northville NY, South Y
    09 Tacoma 4WD
    supercharger, ARE series 2 lid.
    I decided to change the front emblem cause it looked like a mexican sombero.
    I bought the Harrier emblem off of ebay which was made to fit a lexus and not a Tacoma. Therefore, some slight modification with a dremel was going to be needed to do this installation. Matching the Harrier emblem (smaller) up to the Toyota emblem, (larger) there is about an 1/8 difference between the two, other than that, exact same shape.
    I removed the original emblem and then cut out the inside of the grill to about a 1/4 inch of the original emblem opening. Then I took the Toyota emblem and proceeded to cut that out also to the inside edge of the outer ring, removing the "sombero". This will serve as a frame around the Harrier emblem and give me the original mounting clips to hold it into the grill. I then glued the Harrier to the ring and installed it. Here is a pic of the final result. If you look carefully at the bottom pic, you will see the outer ring of the original emblem. total time was approximate 2 hours being the first time. It should take less than an hour to do if I had to do it again.
    [​IMG][/IMG]
    [​IMG][/IMG]
    If your wondering what that black box is on the top of the license plate, obviously your not from the northeast. This is what we call an EZ-PASS used to pay tolls on the thruway, and also so that the cops can track you wherever you are. Sorta like a LoJack run by the state.:cool:
  2. Dec 20, 2007 at 1:05 PM
    SteelCity
    SteelCity Wherever I May Roam
    Charleston, SC
    06 Radiant Rd DC LB PreRunner SR5 V6
    Optima Red/Stinger Terms, DT Headers, Empire O2 sim, Bluetooth, USASpec PA12TOY, Redline Struts, Extang Tonneu, OEM Bed Mat/front Skid/Roof Rack, Grillcraft Grille, Susp TSB, Toytec 1/2" front spacers, Raammat/Ensolite, Sony GTs, Curt Hitch, Tranny cooler, Wet Okoles, AFE Pro-Dry Drop in, Muth Sig Mirrors, Temp/Comp RVM, Silverstar HLs/Fogs, Royal Purple Diff/PS Fluid, Detroit Truetrac LSD, Hellwig rear sway bar, SG II, Filter Mag, 265/75/16 Nitto TGs
    I like it! That looks pretty cool. How much did the emblem run you? Saw one on Ebay for $75 OBO.
  3. Dec 20, 2007 at 6:04 PM
    sunruner19
    Bill
    09 Tacoma 4WD
    Same one as on ebay for $70.00 That was the best offer he would take. Arrived in 5 days, which isnt too bad. Shortly after this picture of the truck was taken, the truck suffered severe damage to the drivers side upper windshield pillar, hood, dr side fender, mirror and door. Huge chunks of ice fell on the truck from the roof of a building next to the truck within a minute of me exiting truck. We estimate the weight of one chunk at over 20lbs and definetly a killer if it landed on someones head. Owner of building denies any responsibility and claims act of nature. I guess its not politically correct to say act of god anymore.
    I assume if my truck slid on ice and hit him, that would be an act of nature too ! I wonder if temporary insanity is an act of nature or an act of god
  4. Dec 20, 2007 at 6:45 PM
    SteelCity
    Charleston, SC
    Wow - looks like about 30 pounds! Sorry to hear it happened. I suppose it would look suspicious if you "slide" into him right after that happened to your truck.
  5. Dec 21, 2007 at 6:15 AM
    sunruner19
    Bill
    09 Tacoma 4WD
    Bottom line is this.....In NYS, not sure if this is true anywhere else, the owner of the building is not responsible, according to the insurance companies. I posed this question to them after they told me this:
    If I got hit by the ice, and either suffered a massive brain injury or even death, who would be responsible?? Ans: Its an act of nature....WOW!
    To add further to this.....If my truck slid on ice and hit his building, I have to pay, my fault and not an act of nature.
    Well its my act of nature to urinate on his property then, sue me.
  6. Dec 21, 2007 at 9:58 AM
    Don G
    Don G Old Goat
    Southern Tier New York
    "08" Tacoma Access Cab TRD Sport 4X4
    Hey Sunruner I like the new emblem! !! I don't like the OEM one either! !! Also I don't much like the Ice on your Taco ---_-OUCH! ! !!!! :D
    Don G
  7. Dec 21, 2007 at 10:59 AM
    SteelCity
    Charleston, SC
    Interesting. Here in the south it's pretty clear cut as there's no snow. People just plow into each other outright.
  8. Jan 12, 2008 at 10:58 AM
    sunruner19
    Bill
    09 Tacoma 4WD
    I have to add this comment to the grill emblem installation that I did a few weeks ago. There is a slight curve to the Harrier emblem that the original toyota emblem does NOT have. You will have a slight gap on either side about the thickness of a pigs hair. One way to overcome this is to glue the harrier to the cutout toyota emblem one side at a time with a soft jaw clamp. Onces that sets, glue the other side. The cutout toyota emblem is flexible enough to fill this gap which when snapped into the grill, will hide any gaps. This mod is not for the timid and does require a dremel or similar tool to accomplish it. The harrier emblem costs $70.00 so take your time, patience is needed on this one.
    While waiting 17 days for a geico insurance adjuster to show up, the truck once again got hit by ice, this time taking the roof out, and crushing the fender that was previously hit. To add insult to injury, when the adjuster finally did decide to show up, after one helluva threatening phone call by myself to geico, this moron tells me that the damage to the roof was from a previous hail storm! I was about to say something to this moron, but the bodyshop manager said it for me which I am forbidden to print it for fear of being banned forever from the forum. Needless to say, the truck will be fixed and sold. Whoever buys it will be shown pics of the damage so nothing can be said that I hid anything and they will know the history of the truck. I have my eyes on either a 08 trd access cab, or dare I say, the FJ cruiser offroad limited edition in artic white. Hey I am almost 62 now and a little spice in life wont hurt. I could do the unforgiveable and buy a chevy corvette!,:eek:
  9. Jan 12, 2008 at 12:22 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Wow! 20lbs of ice did that?...Seems like taco's are getting cheaper by the year!..Sorry for your misfortune!..I have worked in the rental business for residential and retail. That owner should own up to what happened. What if that hit you or someone elese?...I think the courts would agree. Look up your local laws on business responsibility. Looks like you live where ice is very common. I would think their would be some sort of law.
    Good Luck!
  10. Jan 12, 2008 at 12:49 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Not a fan of that emblem but hey its your truck, i like mine thats why i painted it black to match.
  11. Jan 12, 2008 at 7:54 PM
    sunruner19
    Bill
    09 Tacoma 4WD
    we estimated the ice chunk at about 20lbs. Falling from a roof three stories high or even just one story would do some serious damage to any truck. Hitting a human being at either height would cause serious injury if not death if it landed on a persons head. As far as who is responsible, you have to prove negligence by the owner of the building. The point in this case, as far as my truck goes, I had written permission to park in that driveway as stated in the lease agreement. A employee of the insurance agency that the owner purchased insurance through, stated that the owners insurance company is not liable as its considered a act of nature. The insurance company itself says if i can prove negligence, which i can thru photographs etc, then they will pay all damages. What this all means is that this person, employed by the insurance agency, was talking through her ass and made a false statement to myself and my own insurance company, thinking that I would accept it as truth and not go after the owners insurance company. I seriously believe she is related to george bush, lol! or at least voted for him.
    Bottom line is this.....I was stupid to park there, knowing that when it warmed up, there was a strong possibility that it could happen.
    On the bright side of all this, I purchased a house yesterday, and I am going to build a nice, warm, garage. And I will also stay away from Walmart parking lots too, lol.
  12. Jan 15, 2008 at 1:29 PM
    sunruner19
    Bill
    09 Tacoma 4WD
    Just got word that my Tacoma will be out of the body shop by friday of this week. However, I saw this FJ Cruiser at my Toyota dealer in sandstone and bought it. I decided to give my son the Tacoma for a birthday present. He has had a rough few years and I think this will really cheer him up. It keeps it in the family which is a good thing, so now he will have to take my place here in the forum also. He hates Fords with a passion, i might add, and loves Toyota's. All my kids own Toyota's including my gf. My ex never learned how to drive so until Toyota makes a pedal bike, she is out of luck. Here's a pic of a similar fj cruiser in sandstone that i purchased.
  13. Jan 15, 2008 at 5:54 PM
    Viper-2
    Viper-2 Secret Agent
    Keith
    Charleston, SC
    Prerunner with many mods
    Damn! That emblem was some bad ass luck. :eek:
  14. Jan 15, 2008 at 10:28 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    I heard from a Toyota marketer who visited my business class in college that design was made from the letters in Toyota. If you look at it, you can make out each letter in the design.
  15. Jan 16, 2008 at 5:21 PM
    sunruner19
    Bill
    09 Tacoma 4WD
    well, they say if a seagull craps on your car or truck, its good luck. However, the bird in question here, a Harrier or hawk as it looks to me, is a bird of prey, and whether it craps or attacks you, it very well is bad luck.
    Now to prove whether this emblem is bad luck in general, or just my own bad luck, we will find out shortly as another member of this forum has installed it in his grill too. If something happens to his truck also, within two weeks of the installation as in my case, then I feel we shall have to post a warning, lol, not to install this bird of ill forboddings. I have two other emblems that I have yet to install on that truck, one is the hilux and the other is the vigo.
    My tacoma comes out of the body shop at the end of the week with a new sport hood installed instead of the plain hood it replaces. Both hoods are the exact same price, but the sport hood scoop requires an insert which costs $118.00 extra. This price is what I paid for it since I worked for Toyota and still get my discount. I have no clue what retail is to the public.
    I decided to give my son this truck with the condition he becomes a member here. I will still own the tacoma and just let him use it. If this emblem does indeed prove to be a bad luck charm, I will remove it and reinstall the stock emblem before giving it to him. He has suffered enough bad luck already and doesnt need any additional. I opted for the FJ cruiser in the new sancastle color. The dealership that i worked at didnt stock this one, but their sister dealership did so I went out there to pick it up and drove it back today.
  16. Jan 17, 2008 at 10:55 AM
    Buzz
    Buzz Active Member
    I'd be looking for a new insurance company. I'd be an very unhappy customer unhappy if I had a damaged vehcile and the insurance company took 17 days to get around to looking at it.
  17. Jan 17, 2008 at 6:20 PM
    SteelCity
    Charleston, SC
    I'm the other guy! I emailed sunruner numerous times (who I really appreciate for taking the time to help me out) and finally got the harrier on the truck. Well 2 days went by and it was a cold rain here today when I pulled into the garage. I got out and shut the truck door and the emblem fell onto the floor. I can't seem to make the dang bird stay on the truck so I'm going back to the Taco symbol. Oh well!
