New Engand Fluid Film Sept 22nd 2019 Granby CT + Car/Air Show!
Discussion in 'Detailing' started by surfandturf, Jul 18, 2019.
  1. Sep 14, 2019 at 12:36 PM
    #61
    FRESH OJ
    FRESH OJ Well-Known Member
    Rhode Island
    2017 Tacoma Sport
    I'll be there around 1030
  2. Sep 14, 2019 at 4:04 PM
    #62
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Hey @2001Tacoma, check out this thread since you were asking about FF.
    tacobell007 and 2001Tacoma like this.
  3. Sep 14, 2019 at 4:09 PM
    #63
    Cativelense
    Nuno
    CT
    I'm not sure what time I'll roll up there yet, but whenever I get there I don't mind waiting for an opening. I don't want to put myself down for a time and take a spot that someone might want or need.
    :thumbsup:
  4. Sep 14, 2019 at 4:10 PM
    #64
    2001Tacoma
    2001Tacoma Well-Known Member
    2019 SR I4
    Cativelense - Ill take a look, thnx for the link
    Cativelense likes this.
  5. Sep 14, 2019 at 5:51 PM
    #65
    surfandturf
    surfandturf [OP] Well-Known Member
    CT
    2014 TRD DCLB
    I'll fit you in, everything is getting spaced out so it shouldn't be an issue.
    Cativelense[QUOTED] likes this.
  6. Sep 16, 2019 at 6:09 AM
    #66
    CT18Tacoma
    CT18Tacoma Well-Known Member
    Ray
    2018 TRD Sport
    I'll take the 10 o'clock spot!
  7. Sep 16, 2019 at 9:01 AM
    #67
    Irishcarver
    Irishcarver Well-Known Member
    2015 DCSB TRD Sport Barcelona Red
    I won’t make it unfortunately. Heading to work today and will be gone for a few weeks. I’ll hit you up when I get back to see if you’ve any left for a quick spray lol
    surfandturf[OP] likes this.
  8. Sep 16, 2019 at 11:01 AM
    #68
    ptat
    ptat Well-Known Member
    2019 Tacoma SR5 4WD DCLB
    I can take the 10:45 - 11:00 spot.
  9. Sep 16, 2019 at 6:43 PM
    #69
    GMAN62465
    GMAN62465 Well-Known Member
    Gary
    Fairfield County, Connecticut
    2015 White DCSB Off-Road Plus
    In for sure for this...
    11:15 - 1130 spot please
    Thank you!
    GMAN
  10. Sep 17, 2019 at 6:41 AM
    #70
    2013regularcab4x4
    2013regularcab4x4 Member
    2013 mgm Tacoma 4x4 5 spd
    2017 trd or rims, 265 75 16 bfg at tires.
    I just received a letter from Toyota motor Corp. It states that they will spray a CRC coating on my frame. It then will cover frame replacement, if needed, for 12 years from date of first use. This service bulletin, they are not calling it a recall, will effect certain 2011 to 2017 Tacoma's.
    Not sure if anyone else has received this notice yet?
    Due to this, I have to respectfully cancel my spray for 9am. I appreciate your time anyway.
    tacobell007 likes this.
  11. Sep 17, 2019 at 6:43 AM
    #71
    surfandturf
    CT
    2014 TRD DCLB
    Keep in mind there are many other metal parts that will rust if not protected. Toyota is only spraying the frame. You should do something with the rest of the surface area. I'll take you off the list unless I hear otherwise
    DrFunker, pudge151 and tacobell007 like this.
  12. Sep 17, 2019 at 1:37 PM
    #72
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    This is so true. The list of parts that rust away is very long and fluid film can pretty much get sprayed on everything.
    I make sure to cover all the suspension components, axles, differentials, body mount bolts, the backside of the brake plates, hubs, running boards, the underside of the sheet metal floor of the cabin and bed (my tundra has a steel bed), skis plates, trailer hitch, cross members, every nut and bolt that I can see or reach, inside of the bed quarter panels, inside rocker panels, under the plastic windshield cowl, that dogleg area of the A pillar, inside the doors, engine bay and firewall sheet metal and all the nuts and bolts under the hood, spare tire wheel and chain and lift mechanism, battery terminals......oh and the frame I spray that since I am under there.
    For anyone who isn't sure about getting this done....DO IT!!!!! This is an absolute bargain of a deal and you are getting much much more than just a frame spray. The parts I mentioned above are just examples of what can get rusted out of not treated. Getting this FF spray done will cover 90% + of those areas. Some of the spots will retain the FF for years too unless you powerwash it off.
    The frame coating toyota does is terrible and traps water and leads to more rust. I'm not saying don't get it done, because it does extend your frame warranty, but be sure to get FF treatments done as well to cover everything else and protect the crappy Toyota coating.
    Big bump for a great guy offering one hell of a deal and service to his fellow new englanders
  13. Sep 18, 2019 at 2:20 AM
    #73
    DrFunker
    DrFunker Well-Known Member
    Just got my notice the other day. Still doing the FF. I do not want that shit they put in the frame. Does more harm than good.
    Will hold on to my "golden ticket" until right before it expires. :anonymous:
  14. Sep 18, 2019 at 4:48 AM
    #74
    Cativelense
    Nuno
    CT
    Desperate times call for desperate measures... LOL
    Sorry to hijack the thread, but figured I'd throw this out here as well in hopes someone could hook a brother up.
    Anyone coming to the meet on Sunday that lives near or drives by @bvinal06 in Woodstock CT, that wouldn't mind grabbing the SWEET SOS Concepts skid he has for sale, and bring it with you?! I'll throw in some local craft brews for your troubles. :fingerscrossed:
    pudge151, tacobell007 and bvinal06 like this.
  15. Sep 18, 2019 at 9:11 AM
    #75
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Wait, I take it Melissa doesn't know about this? Remember last time? :rofl:
  16. Sep 18, 2019 at 9:14 AM
    #76
    Cativelense
    Nuno
    CT
    LMAO!!!!!!!!!!!!!!!! She won't even notice it... it'll be under the truck. She won't look under there.
    :D
    tacobell007[QUOTED] likes this.
  17. Sep 18, 2019 at 9:16 AM
    #77
    tacobell007
    Drew
    Western MA
    This is very true
  18. Sep 18, 2019 at 9:20 AM
    #78
    Cativelense
    Nuno
    CT
    I took off the BPF one that I had because it's all beat up... and saw the one that bvinal06 put up for sale, so replacing the old with something new, and BETTER!
    This thing is sitting in the garage, and Melissa just asked me last night what I was doing with it... not sure if it's even worth any $$ since it looks like this.
  19. Sep 18, 2019 at 10:51 AM
    #79
    tacobell007
    Drew
    Western MA
    Someone might want it
  20. Sep 18, 2019 at 10:53 AM
    #80
    Cativelense
    Nuno
    CT
    I'll probably end up putting something out there in the for sale thread, and see what happens.
