New Engine 145,000 miles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mfalbojr, Nov 23, 2023.
  1. Nov 23, 2023 at 11:55 AM
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    Everyone in here talking about new engines and short blocks. No one is trying to figure out what caused it?
    did you change your coolant at or before 100,000mi?
    DMel and soundman98 like this.
  2. Nov 23, 2023 at 11:56 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    For 18K I would sure hope the dealer figured that out for him. Guess we’ll see.
  3. Nov 23, 2023 at 11:57 AM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Check out Monkey Wrench Racing for heads
  4. Nov 23, 2023 at 11:57 AM
    Trouble_The_Tacoma
    Conrad
    They’re in it for the money. For $18k I’ll
    Buy a new truck. They’ll quote him 40hrs and get it done in 15, pocket the rest.
  5. Nov 23, 2023 at 12:01 PM
    Sinister184
    Sinister184 Well-Known Member
    23 Tacoma TRD OR 4x4
    Sounds like OP already signed off on the new engine. Used swap was the answer though. Admittedly I don’t stare at the temp gauge all day, but I’m surprised it overheated that badly.
    Trouble_The_Tacoma likes this.
  6. Nov 23, 2023 at 12:02 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Junk yard engine with less than 100k will set you back $5k
    Labor to remove engine and install another will be $4-6k
    Your thought are WAY off
  7. Nov 23, 2023 at 12:04 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    any man made machine can fail.. i've only seen one Tacoma engine failure at work since the 3rd gen has come out. 90k it threw a rod for literally no reason.. it happens. we put a new used engine in for the tune of 7.2k installed at a dealer... (15k miles on that engine.)with a warranty and it has been running around now for 2 years with no issues.
    oconnor, JmsWms, StayinStock and 2 others like this.
  8. Nov 23, 2023 at 12:33 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    I think people have this mindset on the older generations of Tacomas . This is a completely different engine . Yes it’s more reliable than most vehicles. But unfortunately not anywhere close to what the engine used to be .
    taco57 and Empty_Lord like this.
  9. Nov 23, 2023 at 1:21 PM
    Empty_Lord
    Dan
    Eh. Arguably I’d say powertrain wise they’re as reliable as the old ones. The electronics can pause more issues. Failures in the real world are way less common than forums would make you believe
  10. Nov 23, 2023 at 1:27 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
  11. Nov 23, 2023 at 2:01 PM
    Trouble_The_Tacoma
    Conrad
    You forgot the $13,900 for changing the fluids.
    Junkhead and Chew like this.
  12. Nov 23, 2023 at 2:03 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    TOYOTA FLUIDS!!!
    haha
    Junkhead and 71tattooguy like this.
  13. Nov 23, 2023 at 2:08 PM
    Trouble_The_Tacoma
    Conrad
    While the 4.0 is arguably the best Tacoma (I’m biased), even 6 year old coolant with 145,000mi or not changing the coolant can fry a thermostat or break any engine.
    Still wondering if OP ever changed or was running stock.
    Hugh Jashole likes this.
  14. Nov 23, 2023 at 2:26 PM
    Oreo Cat
    I’ve gotten lucky with the 2 cars I have now, but buying used cars scares me since most people will only ever change the engine oil and Coolant, trans oil, t case, differentials, brakes fluid will still be original at 150k miles
    Junkhead, oconnor and Chew like this.
  15. Nov 23, 2023 at 2:36 PM
    #35
    Empty_Lord
    Dan
    I’ve got a few 200k+ trucks that come in that haven’t replaced coolant.
    Not recommended. But meh. Modern Toyota pink coolant doesn’t break down like the old stuff. My 06 corolla had 400k on its coolant before I changed it. That car was something I never touched shit till something broke. Lol
    what likely has happened is a water pump failure that wasn’t noticed and repaired. That’s the biggest issue with any Toyota cooling system that usually leads to failure of the headgasket when it’s ignored too long
    Junkhead and ace96 like this.
  16. Nov 23, 2023 at 2:47 PM
    #36
    4runnerToTacoma
    4runnerToTacoma Well-Known Member
    22 SR5 V6 Taco, 03 SR5 V6 4runner
    Damn man, this is what 13th thread this week about 2016-2017 models failing apart?
  17. Nov 23, 2023 at 2:49 PM
    #37
    Trouble_The_Tacoma
    Conrad
    Never buy a first year model of any vehicle. Not even Toyota.
    GilbertOz likes this.
  18. Nov 23, 2023 at 2:51 PM
    #38
    fake4x4
    fake4x4 Well-Known Member
    Los Angeles, California
    3rd Gen Tacoma TRD Off-Road DCSB
    Cool stuff
    Swap a LS motor with Dakota cluster for way less
    oconnor and Trouble_The_Tacoma like this.
  19. Nov 23, 2023 at 4:32 PM
    #39
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    I am not sure why it would matter at this point. Curious why it overheated also. But there have been a few here and there that cracked a cylinder and popped a head gasket. 140k on coolant while slightly contributing to it shouldn’t be the sole cause. I believe Toyota Coolant is good to 100 per the manual. Doubt it would cause an engine implosion post that
    Junkhead and Big tall dave like this.
  20. Nov 23, 2023 at 5:34 PM
    #40
    Trouble_The_Tacoma
    Conrad
    100,000 is the upper limit. You should do it sooner or at 5 years.
    As coolant ages it loses its unique abilities and reaches boiling point faster.
