New Engine Block In Tacoma Good Or Bad
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rob01, Jan 4, 2011.
  1. Jan 4, 2011 at 8:03 PM
    rob01
    rob01 [OP] Active Member
    Winnipeg, Canada
    2010 silver Crew cab TDR sport
    Looked at a 2007 Trd Quad cab at a local Toyota dealer and the truck looks pretty clean. But the only problem is a young guy drove it and had a stone chip through the rad and it slowly leaked out and cause damage. The dealer put a new block in. Would you guys stay away from this or having a new block would want you to buy it more. Truck has 26000 miles on it warranty for 19 months. Just wondering how he took care of the rest of the truck.
  2. Jan 4, 2011 at 8:08 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    just block? no heads???????
  3. Jan 4, 2011 at 8:12 PM
    rwilso03
    rwilso03 Well-Known Member
    Russ
    Dayton
    2010 DC SB 4.0L 6spd Barcalona Red
    TRD Exhaust, Engine Ticking Fix, Fog Lights Anytime, Locking Center Storage, 4LO Trac Mod, Rear Spring TSB
    x2. or water pump?
  4. Jan 4, 2011 at 8:18 PM
    jandrews
    '09 FourDubDee TRD OR
  5. Jan 4, 2011 at 8:23 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ... ^^^ ... a 2007 model still has 19 more months on which warranty ... the 36K bumper to bumper or drive train warranty ???
    If it was originally a late new vehicle seller as a 2007 model .... it could be the 36K warranty and that would make it more worth while, IMO.
  6. Jan 5, 2011 at 6:42 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Unless it's being discounted due to it's "status" I would stay away from it. If you're paying full used price, find one that doesn't have a past issue.
    It does seem strange that the block was replaced and not the heads. I would ask for the repair details to check, but again, that's assuming you're getting a discount. Now, if they replaced the block and the heads, then maybe. Still a risk no matter how you look at it though.
  7. Apr 11, 2015 at 2:45 PM
    unskinator
    unskinator Active Member
    Unski
    Delaware
    05 4x4 V6 accesscab 6 on the stick sports
    Was the block replaced because the rod came thru. If so stay as far as you can and look for something else.
  8. Apr 11, 2015 at 3:24 PM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    You need to know if they just replaced the block with your internals or did the install a new or remanufactured short block [ stay away from reman. v6 will not support cylinder bore.] You really need to know the history of the damage and what was installed. If you can't get this info then run don't walk to the nearest exit.
  9. Apr 11, 2015 at 4:04 PM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    Do you think after 4 years he is still on the fence? :eek:
    I'm sure the warranty is up by now.
  10. Apr 11, 2015 at 4:07 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    I bet he can get a killer deal on it now. shit 4 years on the lot? I bet they'll give it away.
  11. Apr 11, 2015 at 4:15 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
