New engine, crooked steering wheel?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SubFrozen, Nov 17, 2009.
  1. Nov 17, 2009 at 12:56 PM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    3" OME Heavy Duty Lift, 18" Chrome Rimes, ARB Front Bumper, K&N Cold Air Intake
    I had a new engine installed in my Taco and now the steering wheel is crooked to the left about 1/4th of a quarter steering wheel turn. That's to get it to drive straight. They said a front end alignment was done on it, so they assume it's tires.
    Prior to the new engine, it wasn't crooked, however, it had to be towed in.
    My Q is, is there a way the towing company could have tweaked it? Dealership said they didn't do anything with the steering wheel linkage during the engine install. Can you do an engine install and not touch the steering linkage?
  2. Nov 17, 2009 at 1:10 PM
    brandob9
    brandob9 Well-Known Member
    Brandon
    Portland, OR
    09 DC Long Bed
    Soundproofed cab, beeps purged, bed lights, extra bed tie-downs and TSB springs.
    I'd ask the guys that installed it if they disconnected the steering column.
  3. Nov 17, 2009 at 1:13 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    +1
  4. Nov 17, 2009 at 1:23 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    I wander if this is something we can do it ourselves?
    take care
    vbibi:(
  5. Nov 17, 2009 at 1:48 PM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    Dealership states column wasn't disconnected to remove and install the engines. Doesn't it kind of have to be? Anyone here know?
  6. Nov 17, 2009 at 1:51 PM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    Don't they need to disconnect the pump/steering column to remove and install an engine?
  7. Nov 17, 2009 at 2:09 PM
    Mr_Torque
    Mr_Torque Buy the Ticket take the Ride.....
    Perkasie,PA
    '07 Tacoma SR5 4WD V-6 6 Spd
    MBRP Exhaust, 17" FJ Steelies w/Firestone AT's, Truxedo Lopro ,Timbren SES, Pioneer FH-X720BT HU & TS-C720PRS Component Speakers, TRD Quickshifter, Bilstein 6112/5160, Light Racing UCA, and Icon Progressive add a leaf.
  8. Nov 17, 2009 at 2:13 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I correct my toe all the time. Just use an adjustable wrench to loosen the bolt on the tire rods closest to your engine and either twist the tie rods towards or away from each other to correct your toe. Start off by measuring the distance from the front of both wheels to each other vs the difference of the back of both wheels to each other, then adjust your toe accordingly. Remember, a little toe-in is optimum to maintain load on your wheel bearings.
