new engine lacking power..?
Discussion in '1st Gen. Tacomas (1995-2004)' started by presto, Feb 6, 2015.
  1. Feb 6, 2015 at 10:21 AM
    presto
    presto [OP] Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    I've been driving my truck around for a few months now with a brand new engine. 4cyl 2.7L 3rz 4wd 1997 extra cab. Most of the engine is new (6,000 miles on it) except for things like valve cover, throttle body, intake manifold, injectors, vapor canister and a few others. The only time i notice a lack of power really is when I'm going up a hill. i can feel it running fine and accelerating up until around 50 mph it will stop accelerating. each time it shifts around 2500 - 3000ish RPM and on the last shift it bogs down to a little under 2500 rpm and won't go any higher /very slowly gets higher until i either get over the top of the hill or it downshifts and revs up to like 3200-3400 rpms cause I'm pressing on the gas a little too hard.
    Edit: before i changed the engine before this i had pretty much the same problem but a little less power cause the engine was blown.
  2. Feb 6, 2015 at 10:24 AM
    BamaToy1997
    Bill
    Navarre, FL
    I have found that the 3RZ has a really flat response in the 2300 RPM range. I had the same problem with my truck. I recently installed an LCE header for it and the flat spot is almost totally gone now.
  3. Feb 6, 2015 at 10:37 AM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Ah that's good to know, I've been considering getting a 01-04 oem headers/exhaust manifold.
    Last time I checked the MAF it seemed fine, it was pretty recently replaced(probably a year old). I hope the engine isn't blown since its only a few Months old haha.
    Thanks for the replies.
  4. Feb 6, 2015 at 11:40 AM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    Great to hear that I'm not alone. Even a slight hill and my truck will wind down and lose rpms and speed if I try to climb at 2000-2400 rpm in 4th or 5th gear. I end up having to downshift to 3rd and run it at 3500+ rpm, unless I want to slow down below 50 mph.
    Interesting to hear that the LCE header fixed this. I have the OEM mini-header on, but I still have the problem. Could an exhaust leak at the manifold/head or at the manifold/downpipe junction cause this?
  5. Feb 6, 2015 at 1:12 PM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Hmmm, mine does fine in 4th @ 2000 rpm going up the hills/ big bridge, just not 5th, it'll start laboring and drop off.
  6. Feb 6, 2015 at 1:15 PM
    Gimmick
    Gimmick Well-Known Member
    Anthony
    Canada
    2017 TRD Offroad DCSB
    I know that feeling. In the 4cyl auto, I feel like it hits 2nd gear and then the rpms fall of the fuckin chart. I wondered the same thing, but chalked it up to #4bangerproblems.
  7. Feb 6, 2015 at 1:17 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    must be all the added weight and tires contributing to the power loss too.
    My old 2rz base model single cab had no issues climbing hills, It had an LCE header, Magnaflow 18 inch muffler on stock pipes and a form of deck plate done.
    it hauled ass even with the AC on i could go from 65-85 in a few seconds in 5th
    Ahhhh plus you're an automatic.. yikes. Those were known to be complete dogs compared to the 5 speed which mine was.
  8. Feb 6, 2015 at 1:18 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    i just feel like i never used to have the problem before when i first bought the truck like 6 years ago.. (original engine..) but i was a new driver at that time and maybe i didn't really have the feel for the RPM's and shifting and stuff and i would always just rev it up high in a lower gear going up hills.. i just remember i would always drive pretty fast everywhere back in the day and i didn't have a problem w/ the engine doing it haha..
  9. Feb 6, 2015 at 1:20 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    hmm yea I'm sure all the added weight has done something.. the tires are only 31's tho but yea still not official stock size..
    EDIT: Two things that i think it could be are the vapor canister, and the fuel pump.
    reason i think it could be the vapor canister is because I've read somewhere that if you "overfill" your gas tank at all even a tiny bit you ruin the vapor canister. i think it could be the fuel pump cause the company i work for just had a different vehicle with a sort of similar problem.
  10. Feb 6, 2015 at 1:35 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    4 cylinder automatic problems dude. When I had my 2011 I was always downshifting and driving like a race car up steep grades, it was kinda fun actually. But, any truck will do this, even us V6 guys when you add weight to em. Heavy tires really change everything. With my 2011, I went from the stock 4 ply Dunlops to the same size tire with Goodyear silent armors, only 10 ply instead of 4 and that changed everything with the way the truck drove and accelerated because of the extra weight. It was well worth it though having a tire that I could drive down a gravel road with and not worry about punching a hole in. I had only had my 2011 for about a month when I popped the right rear tire on a gravel road, one tiny little pebble lodged between the treads was all it took. Needless to say those tires went bye-bye in a hurry. I live in Montana so 70% of my driving is on old dirt roads.
  11. Jan 15, 2024 at 5:39 PM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    9 years boys! how time fly's.
    found this thread searching for similar issues and looks like most of you guys have it too. in fact I have the same if not a bit worse of a gremlin but mine is intermittent! comes and goes some days i hop in and she's rippin than other days its like an old tired dog exactly as you all describe and i can hear pinging when the motor is lugging I've been chasing this issue for years. not to revive an old thread but here we go
    truck started having odd hard starting and shaky idle at start up and over pressurizing and eating/barfing coolant in 2016 around 178k miles, eventually blew it all out the over flow on the way to work and overheated the motor warped the head and blew the head gasket...than replaced it to a rebuilt balance shaft delete and stage 1 cam from Yota1, should have solved all my problems right? nope same exact issue remained
    since the swap...
    it's had a Doug Thorley header for years that's always leaked at the y pipe...fixed that, and safety wired the bolts, now it'll never come loose again. also the Cat was clogged and rattling. fixed that. (no other leaks besides a rusty muffler left)
    MAF was changed but did nothing....put in a mid grade one from Quest but i cant remember the name.
    swapped the IAC valve with a Toyota OEM part to fix the coolant over pressurizing/idling issue. old valve was sticking and leaking coolant into the intake and causing the hard starts as it burned off the coolant...that only fixed the shitty idle when hot/and on start but coolant system still was over pressurizing.
    changed the EGR valve with Toyota OEM part as a last resort before doing the head gasket and BAM fixed the coolant over pressure issue..
    but still drives like a old wet dog 75% of the time. just cant get out of its own way even on flat ground, passing a car yeah right. and 3rd gear holy shit that's when I hear the pinging most and it gets worse load up the engine and heat it up
    than other days just when I wanna drive this pile off a cliff it just wakes up and drives like a bat outa hell.
    I have a Toyota OEM TPS to drop in this weekend.
    other than that I'm thinking the transmission is messed up? shifting outa sequence. i have a 5 speed im swapping in this spring so well see on that too
    in the mean time anyone else figure out there issue? any other ideas?
  12. Jan 15, 2024 at 7:44 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    None of this is "normal". I recently installed a LCE header and I never had these issues before and the header didn't cause a dramatic change. A bit more low end torque but I would be looking into the volume of fuel delivery if low performance is suspected. But the headers don't really do anything if that is the only modification. The LCE ones are sweet though.
  13. Jan 15, 2024 at 7:47 PM
    MadNachos
    Do a leak-down and/or compression test and go from there.
  14. Jan 19, 2024 at 2:22 PM
    Tac4lyfe
    Tac4lyfe Member
    Malachi
    1999 Tacoma sr5 TRD 4x4 Mystic Purple Mica
    Few as possible, I really enjoy stock Tacoma's! Except small things, and maybe someday a supercharger.
    I drove a 97 2.7l for years. It just don't like dem hills. it was a nice truck too, got it from my brother with 45k original garaged miles. It still didn't like hills.
    intake mods sound interesting, probably worth a shot.
    Or just do the right thing and pick up a yota with a 5vz-fe and problems solved forever! (joking! plz no hate from you 2/7l guys)
  15. Jan 19, 2024 at 2:46 PM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    My 99 does ok because the origional owner had a BO7A rear end put it when new
