New engine or rebuild?
Discussion in '1st Gen. Tacomas (1995-2004)' started by emjidi, May 5, 2013.
  1. May 5, 2013 at 7:39 AM
    emjidi
    emjidi [OP] New Member
    Mary Grace
    Westminster, CA
    '96 Tacoma 5-Spd MT
    I have a '96 Tacoma that overheated and hasn't started since. When I took it to a mechanic, he said that gas isn't getting to the engine and suggested installing a new engine which would cost a little over $3000. What do you think about this price and would it be more cost-effective to rebuild the engine? My friend said he would help me with the rebuild if I chose to go down that route. :confused:
  2. May 5, 2013 at 1:27 PM
    RJ MacReady
    RJ MacReady professional trousersnake charmer
    RJ/Mike Hauncho/HeavyHands
    US OUTPOST North 31-Mayday Mayday! We've found som
    00 4Runner 4WD LTD - Cheatin' Bitch Build 2
    Cheatin' bitch build 2: All stock for now... 99' Tacoma 4wd TRD Cheatin' bitch build 1: BG44K additive, motul 5w40(always), deckplate mod, K&N washable air filter, 2.5" flow master(cut thanks to Airdog), king fronts 2.5", all pro standard leaf pk, stainless steel rear ext brakeline, 5125's 10" travel rears, 4-jasper offroad 6" pod LED spot lights, secret compartment for small bottle of wild turkey, cobra CB, Hi-lift jack w/locking bed mount, hi lift curved bumper lift & road base plate, smittybuilt X20 winch, wab fab F&R bumpers w/ hitch receivers, smittybuilt 4in1 recov tool, 10gal mini flamethrower, 11 lbs dynamite sticks, 13 4-hr snowflares, .50Cal full auto mounted machine gun w/ RPG unit & a shitoad of death metal to fuckstart your brain...everything you need for first contact with a shape-shifting alien entity frozen for over 100,000 years reanimated & immitating all life it engulfs.
    I'd prob rebuild it & go from there. It won't cost $3K if you keep it stock. Theres a few places that actually do installs with warranty in the La Verne/Glendora area.
  3. May 5, 2013 at 10:31 PM
    Bmack04
    Bmack04 Active Member
    Ohio
    04 DC trd 4x4
    deck plate mod, grey wire mod, 5100s front w/OME 881s, 5100s rear w/wheelers 5 leaf, 265/75R16 Firestone Destination A/Ts
    your "mechanic" said that you need a new engine because gas isnt getting to the engine? if u need a new engine due to the fact it overheated real bad, i might believe that. his story isnt added up to me...
  4. May 5, 2013 at 10:34 PM
    Dcpsychobilly
    Dcpsychobilly Well-Known Member
    Aurora Colorado
    04 dbl cab Taco
    Bumpers, skids, lights, cb, trail gear sliders, front lift adj bilsteins, dakar lift leaf springs rear, smittybilt seat covers
    X2
    Another story about a mechanic trying to pocket more money
    Op get second opinion and a real diagnose
  5. May 6, 2013 at 11:18 AM
    emjidi
    Mary Grace
    Westminster, CA
    '96 Tacoma 5-Spd MT
    Thanks for the input guys, ill get a second opinion before I proceed any further.
  6. May 6, 2013 at 11:32 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2 2nd Gen T4R's
    So much Yota I can't explain!
    x2.
  7. May 9, 2013 at 7:17 AM
    06yfz450ridr
    06yfz450ridr Well-Known Member
    Austin
    CT
    HID's
    2jz swap haha thats what im doing when my motor goes, you can pick up the motor, the turbos and ecu etc together for like 1800 and with th 5 speed tranny it will work with some sort of adapter i believe but the tranny would need to be rebuilt to handle that as well as new clutch depending if its auto or standard
  8. May 9, 2013 at 9:50 AM
    colby8100
    colby8100 Well-Known Member
    Colby
    South carolin
    01 Tacoma 1jz lowered
    Lowered,leather interior,system,1jz swap,rims,painted bumpers mirrors ect
    Do not do 2jz swap waste of time and money especially if you have a 4.0 I've done it I dot over 11000$ in mine and I should've done turboed lsx
  9. May 9, 2013 at 9:55 AM
    colby8100
    Colby
    South carolin
    A good gte is going to cost close to 3500 $ you should still tear it down replace gaskets put arp head studs you can build 700hp of of a stock gte you just have to change turbo, header, exaught , fuel injectors, computer, clutch, cams pretty much everything and that far into it go ahead and build bottom end
  10. May 9, 2013 at 9:57 AM
    colby8100
    Colby
    South carolin
    Ps boosted cars are faster if auto because it doesn't blow off in between shifts
  11. May 9, 2013 at 10:31 AM
    Dcpsychobilly
    Aurora Colorado
    04 dbl cab Taco
    Op update?
  12. May 10, 2013 at 7:22 AM
    06yfz450ridr
    Austin
    CT
    HID's
    true but used without a rebuild you can find them decently cheap, and i just love the sound of the 2jz. ahh i need a supra
  13. May 10, 2013 at 9:50 AM
    colby8100
    Colby
    South carolin
    If you want a 2jz and have it cheep and decently quick get a ge vvti engine from junk yard throw it in turbo it with a single turbo the manifold is less than 200 $ you'll probably be fine with reliability under 500hp but torque would be a lot better due to higher compression and vvti
  14. Jul 11, 2013 at 12:32 PM
    2013TuRD
    2013TuRD Well-Known Member
    Bruce
    SW BC
    TRD OFF ROAD
    Have you heard of a diverter valve? AKA blow off valve if it's vent to atmosphere? It allows the turbo to spin with less restriction for the short period of time during a shift. Works great on my turbo Miata.
  15. Jul 12, 2013 at 5:20 AM
    colby8100
    Colby
    South carolin
    Na I don't worry about it. I let off the trans brake and bump the shifter twice and maintain over 30psi through prettt much the whole pass. Plus manual cars have the risk of missing a gear
  16. Jul 12, 2013 at 5:29 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    Would be an impressive engine in a Tacoma. Just an expensive swap. Would need a custom programming I would think for the ECU for the VVTi to work. I would like to see it tho!
  17. Jul 12, 2013 at 6:05 AM
    tacomataco2
    tacomataco2 Well-Known Member
    Eastham Mass
    02 Dbl cab Silver
    Bilstein 5100's, eibach coils, u bolt flip, Dakars/d6xl, Ome shackles, Poly sway bar bush, Poly rack bush, voltmeter, led guage lights, magnaflow stainless catback, stainless cats, deckplate mod, afe filter, tundra brakes,PIAA fogs behind grillecraft, color matched grille, soft topper, Projector retrofit, Allpro bumper , Blitzpro light bars, Alpine/ rock fosgate sound system, 35% tint, Some derped stuff
    1st gen section. No 4.0's here
