New Engine Tick Solved
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Capespencer68, Jun 17, 2022.
  1. Jun 17, 2022 at 4:16 AM
    Capespencer68
    Capespencer68 [OP] Well-Known Member
    Scott
    Massachusetts
    2021 DCSB AG Trail edition
    FYI
    21’ 3.5l 30k
    I had a new low idle, after warmup engine tick around the top passenger side and a intermittent buzzing noise from the drivers side rear Coil/Spark plug area.
    Master Tech diagnosed in two minutes. He pulled a vacuum hose off on the firewall and it went away. The culprit is a vacuum pump. Buzzing sound was the PCV. Vacuum pump on order and PCV replaced. Warranty covered the pump.
    Had me nervous for a bit thinking it was more valve train issues. All is good
  2. Jun 19, 2022 at 7:02 AM
    herrindude
    herrindude 1996 2.4 extra cab auto
    Fairhope al
    2021 dclb sr5
    ARE camper shell
    It is a good thing when a mountain becomes a mole hill isnt it, good for you and the tech that found it.
  3. Jun 19, 2022 at 7:04 AM
    herrindude
    Fairhope al
    2021 dclb sr5
    ARE camper shell
    Thanks for posting this simple fix, i will keep an eye "er" ear out for this.
    Capespencer68[OP] likes this.
  4. Jun 20, 2022 at 2:30 AM
    Capespencer68
    Scott
    Massachusetts
    I was overcome with joy.
  5. Jun 20, 2022 at 4:05 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    I bet!
  6. Jun 20, 2022 at 4:09 AM
    P51Mustang
    P51Mustang Well-Known Member
    Did you have a video of the ticking?
  7. Jun 20, 2022 at 4:12 AM
    hfjeff
    hfjeff Well-Known Member
    Frozen Tundra
    2021 Army Green Off Road
    I have this same little tic on my 2021 AG OR. Kind of bugs me but assumed it was injectors or something that is normal for this motor. Thanks for the tip. With all the horror stories that appear on this forum, it is encouraging to hear there are some great dealer mechanics out there.
  8. Jun 20, 2022 at 6:23 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    The OR and Pro don't have the pump. So that's not what it is. It's probably the injectors cleaning themselves.
    bulalo likes this.
  9. Jun 20, 2022 at 6:30 AM
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    Please explain why, OR's and Pro's do not have this pump. But evidently SR-SR5-Sport and Limited's do.
    Rear locker? :notsure:
  10. Jun 20, 2022 at 6:33 AM
    RX1cobra
    19 OR
    Because our brakes aren't vacuum boosted. They're electric/hydro boosted.
    Smacky2020 likes this.
  11. Jun 20, 2022 at 6:36 AM
    TRD-ED
    Lenoir NC.
    Ok. Why the difference? Something to do with the Crawl control?
  12. Jun 20, 2022 at 6:55 AM
    RX1cobra
    19 OR
    Yup.
    TRD-ED[QUOTED] likes this.
