New engine.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TwisterDan, May 17, 2020.
  1. May 17, 2020 at 6:08 AM
    TwisterDan
    TwisterDan [OP] Member
    Dan
    2009 tacoma
    Hey guys and gals,
    I have a 2009 Tacoma with 240k miles. So I am thinking of putting a new engine in because I love the truck so much. And I need some advice on how to go about this and what to watch out for?
    Twister
  2. May 17, 2020 at 6:13 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Is the current engine bad? Details please.
  3. May 17, 2020 at 6:15 AM
    Clearwater Bill
    Billy
    Largo Florida
    Why?
    What's wrong with the one you have now? It should be good for double that if you've taken care of it.
  4. May 17, 2020 at 6:16 AM
    TwisterDan
    Dan
    2009 tacoma
    Still runs great but burning oil. 4 cylinder.
  5. May 17, 2020 at 6:20 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Wait for another 100K or so. How much is "burning oil"? Or is it just losing it?
  6. May 17, 2020 at 6:22 AM
    TwisterDan
    Dan
    2009 tacoma
    No I don't see any leaks. About a quart a month. Maybe a 1000 miles.
  7. May 17, 2020 at 6:24 AM
    Clearwater Bill
    Billy
    Largo Florida
    Compression and leak down tests been done? This will prove if it's rings or valve related.
  8. May 17, 2020 at 6:25 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Have you done s compression test or anything like that?
    About 500 miles before your next oil change, change the filter only and put some seafoam of marvel mystery oil in the oil. Let that stuff clean out any sludge built up.
  9. May 17, 2020 at 6:26 AM
    TwisterDan
    Dan
    2009 tacoma
    Thanks CB. I haven't tested for those.
  10. May 17, 2020 at 6:33 AM
    TwisterDan
    Dan
    2009 tacoma
    I will definitely look into the mystery oil
  11. May 17, 2020 at 6:45 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    The cost of a leak down test and the possible top end rebuild is far less than a new motor.
  12. May 17, 2020 at 6:46 AM
    TwisterDan
    Dan
    2009 tacoma
    Thanks guy!
  13. May 17, 2020 at 8:21 AM
    Jims85
    Jims85 Member
    Jim
    Milwaukie, Oregon
    85 Truck
    Lots
    Good luck with figuring out what's going on with your engine. I've heard that the rings are wearing out on the 2.7's, and causing the oil consumption.
    I have a 2010 with 120k miles with the 2.7 engine. I've never had to add oil to it between oil changes. It uses zero oil. Knock on wood time!
