New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jan 8, 2024 at 12:48 PM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Anybody have a decent garage heating setup? Im looking for something just to turn on to take the chill off.
    Thinking infrared electric right now.
  2. Jan 8, 2024 at 1:06 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I have a 30k BTU vent free Mr. Heater blue flame. Works great and is efficient. I run it off a 20lb tank that I have outside and a long hose. I have a box fam hung from the ceiling circulating the heat around on low speed.
    PzTank likes this.
  3. Jan 8, 2024 at 1:08 PM
    CTSpruceMica
    CTSpruceMica My driving scares me too
    Dennis
    2014 Spruce Mica
    How long can you get off the 20lb tank?
    PzTank likes this.
  4. Jan 8, 2024 at 1:11 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    I run a 60k btu torpedo propane heater for now. I'd like the 200k one but $100 price difference and I have a pellet stove to use once I get the chimney ran
  5. Jan 8, 2024 at 1:22 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I’m not in the garage every Saturday but when I’m out there I heat it to about 65-70F (insulated) and fill the tank 1 or 2 times a winter.
  6. Jan 8, 2024 at 6:18 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    I was a big duratrac fan and just dealt with the shitty wear for a long time. And having the c-load option was great. But after swapping to the st maxx, I don't think I could ever go back.
    They hooked up in the greasy packed road stuff this past storm so much better than the good years for AT tires
    CTSpruceMica and tacobell007 like this.
  7. Jan 9, 2024 at 2:35 AM
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    I had the ST Maxx on a work van... well, when they were new.
    Great option. Just a tough pill to swallow on the Tacoma due to weight.
    I was toying with a set of Maxxis 255/85s, since I can get them in D range, and save the ATs for this crap basically.
    Or some ST Maxx.
    I dunno, haven't made up my mind, still digging through wheel options, backspacing, blah blah.
  8. Jan 9, 2024 at 4:44 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Do either of you have issues with condensation? When your burning propane without a vent that is 5 gallons of water for every 20 lb tank.
    My reason for leaning towards infrared is my shop is very uninsulated, and pretty big with tall cielings. I feel like if I heated the air it would just go right out. I am also out there probably 3 nights during the week for 3-4 hours then on the weekend 16-20 hrs.
    @tacobell007 your garage isnt insulated right?
    PzTank and tacobell007[QUOTED] like this.
  9. Jan 9, 2024 at 4:47 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    The skinny 33's are easy and there is alot of people around here who have done it and are going to do it.
    If you want no cutting go with stock offset +25 or whatever it is
    If your fine with possibly doing a CMC and pinch weld 0 offset is a good setup IMO
  10. Jan 9, 2024 at 4:49 AM
    tacobell007
    Drew
    Western MA
    No it's not, it's also got plenty of air gaps and the walls before the roof pitch are at 13.5' if I remember right
    I run the heater on high for about 30mins and then point it in my general direction and go down to low setting. Usually just enough that I might get a little too hot with my sweatshirt on while doing underhood work
  11. Jan 9, 2024 at 5:05 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    No issues with condensation. It does fog up the windows and there will be some condensation at the bottom of them but it’s not bad enough to to an issue. I had a propane torpedo heater (60k btu) but it didn’t have auto shutdown and reignition so it was a PIA as I’d be under a car starting to sweat and have to get up to turn it off. Then it would get cold and I’d have to do the same again. Not being insulated is an issue. You’ll use a lot of whatever to keep it warm so radiant is probably the best idea.
    PzTank likes this.
  12. Jan 9, 2024 at 5:38 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    How big is your garage?
  13. Jan 9, 2024 at 5:40 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    That's what I have too - works great. I run it off a 20 lb tank, but I do have a 50 gallon tank next to my garage that's used for one of the fireplaces and the piping goes right through the garage so I feel like I could safely take advantage of that somehow even though the unit says not to.
    I also have a 6000 watt electric unit hanging from the ceiling. That has a hard time heating the space, but it'll maintain it. So I usually heat it up with the propane unit then shut that off and let the electric one maintain.
    If I insulated the garage, it'd be a lot easier, but I really only work out there occasionally in the winter so my system works for now. My garage is 24x24, wide open up to the roof - even just putting foam board on the ceiling to close up the peaked section would probably make a huge difference.
    tacobell007[QUOTED] likes this.
  14. Jan 9, 2024 at 5:45 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    2 car garage. About 24 x 24ish. Ceiling is about 9’.
    edit: the doors are crap Coplay single sided doors with very little insulation.
    PzTank[QUOTED] likes this.
  15. Jan 9, 2024 at 5:49 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    I used to work in an old polebarn about that size- I stitched together several canvas dropcloths and rigged it as a "ceiling" with steel cable and staples, then blew a bunch of cellulose on top of it. Worked great, cost little.
    PzTank and CTSpruceMica like this.
  16. Jan 9, 2024 at 5:56 AM
    js312
    Joe
    New England
    That's a good idea - I had thought about doing the foam board approach but it's expensive and time consuming. Canvas would be a piece of cake.
    PzTank and GarlicFarts like this.
  17. Jan 9, 2024 at 6:03 AM
    tacobell007
    Drew
    Western MA
    Yea I was considering foam board, I just don't want to buy foam board and then in a couple years have John come and spray foam everything. I also have some shop fans I have to put up so I can try to keep the heat down
    Merling and AllTacosFloat like this.
  18. Jan 9, 2024 at 6:20 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Yeah I am thinking the same with sprayfoam, I think I need to reside it first. I'll probably in a few years do that but also have a mini split and a wood stove. Against code but they can kick rocks.
  19. Jan 9, 2024 at 6:30 AM
    Chasespeed
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Yep, that was the plan, but, the JBAs won't work, with pizza cutters and stock wheels.
    So, decisions, decisions....
  20. Jan 9, 2024 at 6:36 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Both Brandon and Matt did I think 1.25" spacers. That nets you just about a 0 offset like my setup. It seems kind of hit and miss whether youll rub at that.
    I took the strut out and fully cycled and pinch weld was 100% necessary and the cab mount rubbed a bit during compression but probably wasnt necessary. If you need help just let me know.
    AllTacosFloat and Brownmatthall like this.
