New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Apr 16, 2024 at 7:35 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    The valve I got isnt available anymore. I dont have pictures but its simple once you find the parts. You just need to find a valve with the below specs. Youll also need various fittings
    Normally OPEN
    120 V Ac I assume
    Matches your current drain size (probably 1/4 npt).
    Also if you are using a switch make sure it can handle the compressors current. Mine draws over 15 so I could not use a normal light switch.
    crashngiggles[QUOTED] likes this.
  2. Apr 16, 2024 at 8:00 AM
    rustyfromskowhegan
    rustyfromskowhegan Well-Known Member
    2013 AC 4x4
    How hard is it to swap out muffler and tailpipe plus intermediate pipe/resonator?
    My 2.7 is sounding like the fast and furious and I hate it. From what I can tell it would involve removing nuts & bolts from flange behind the cat, disconnecting muffler and tailpipe from hangers, and installing new stuff. Am I missing anything here? I’d being doing this in the dirt driveway and am expecting I might have to grind off the nuts and bolts at the flange connection. Would probably buy the exhaust hanger pliers that makes separating them easier. Parts are cheap on rock auto and I wouldn’t have to get rides to work or take time off if I did it on the weekend.
  3. Apr 16, 2024 at 8:08 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    1. I think it's going to go a lot faster than you think it will.
    2. Give a couple exhaust shops a call and get an estimate. You might be surprised how cheap it would be to have someone do it.
    CTSpruceMica likes this.
  4. Apr 16, 2024 at 8:17 AM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    On a 2.7, it is not bad to remove the exhaust, just depends how far you want to travel up. The muffler/tailpipe is one assembly, then the catalytic converters are the mid-pipe, and finally the manifold/header. Also depends how rusty the hardware/flanges are!
  5. Apr 16, 2024 at 8:23 AM
    CTSpruceMica
    CTSpruceMica My driving scares me too
    Dennis
    2014 Spruce Mica
    https://popsexhausti.com/
    This is the go to place near me...I only mention it here because...look at the link.
    People I've sent it to are afraid to click on it cause it looks like a pron website :rofl:
  6. Apr 16, 2024 at 8:27 AM
    rustyfromskowhegan
    2013 AC 4x4
    Thanks ya’ll! My motivation to DIY this is not really financially driven. More out of the inconvenience of not having a vehicle for a day. I work in office about 45 mins away from where I live. Bumming rides, taking Ubers, etc gets to be annoying so I’d like to save the trips to the mechanic for the important stuff or things that would end up really bad if I messed them up. I know how to do some stuff (oil, belts, pulleys, etc) but don’t have the most confidence when it comes to wrenching on the daily driver. I figured if I mess up the exhaust the worst case would be an extra loud truck until I can get it to the shop.
  7. Apr 16, 2024 at 9:17 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Any decent exhaust shop will have appointments and be done in less than an hour. I like Lou’s if you have any near you.
    Merling and ABA180 like this.
  8. Apr 16, 2024 at 9:44 AM
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    Pop’s Sex Haus?
  9. Apr 16, 2024 at 12:03 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    The tool helps, but if you have a pair of channel locks that is fine as well, make sure to spray them with your favorite penetrative oil first to help lube them up. I'd get new bolts and matching nuts since I'm pretty sure factory is nuts welded to the flange
  10. Apr 16, 2024 at 12:31 PM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Yep, there's the problem. It should be next door to...
  11. Apr 16, 2024 at 1:15 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    Sorry to hear it. I got tagged with an at fault accident last year even though I'm still not convinced. I didn't appeal it because from prior experience the Merit Rating Board is an insider club and if you don't know someone, they won't overturn the insurance company decision.
    I got rear ended down here in Texas earlier this month. I have thread in the 3rd Gen forum if anyone is interested. My insurance company assured me that it's the other guys fault and they'll fight the deductible out with his insurance company. Oddly enough, the body shop I'm using wants me to drop the truck off before they'll order parts. I have the estimate from the insurance company's contract appraiser, so I don't know why.
    On the short list of things I miss after moving my former body guy is one. For those interested, it's Apex on the Stoughton/Brockton line. Sean not only does great work, but he's not afraid to fight with insurance companies about supplements.
    TreeFortRichard and CTSpruceMica like this.
  12. Apr 16, 2024 at 1:17 PM
    HisDad
    Texas at last
    My daughter got a CX-5 last year and loves it. Oddly enough I mostly see younger women driving them. Nice car without the "Toyota Tax" the similar RAV4 has.
  13. Apr 16, 2024 at 1:27 PM
    HisDad
    Texas at last
    I'm not aware of a club in Easton that has a range the long. I used to belong to Ames (before we moved) and it's max range is 300 yards. Ames is a mostly rifle oriented club and the 300 yard range is pretty good. I used to joke about the guys with $5,000.00 ARs that shoot them like they are muzzle loaders.
    I liked that it was less than 10 minutes from my house and if I went weekdays I was usually the only person there.
    SilverBulletII likes this.
  14. Apr 16, 2024 at 2:03 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Mansfield maybe? It was a while ago, i just remember the general location and it took me 35 ish minutes to get there. There were competition type rifle folks there when we were there and those targets were well, well past the 100 yd range we were shooting at.
  15. Apr 16, 2024 at 2:06 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    Here u go...
    So the major issue I had was every time I replaced an upstream part...a downstream part failed...
    https://www.tacomaworld.com/threads...ment-on-a-2nd-gen-2-7l-4cyl-with-pics.730328/
    For the down stream fix...
    https://www.tacomaworld.com/threads...en-tacoma-today.6499/page-11887#post-28169096
  16. Apr 16, 2024 at 2:49 PM
    HisDad
    Texas at last
    Could be. I was only at that range once when I was taking an NRA instructor course. That was while they were rebuilding their clubhouse after it burned down. Their website shows a lot of pictures of competitions but I didn't see anything about facilities.
    Pugga[QUOTED] likes this.
  17. Apr 16, 2024 at 3:35 PM
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    I can source damn near anything arena.
    If you need something, let me know.
    This stuff is a significant portion of what I do for a living.
  18. Apr 16, 2024 at 3:39 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    She bought her 2016 when we first started dating - she had a Cobalt that she had been driving for ten years. She thought about looking at GM's equivalent (Equinox?), but a coworker with a Mazda told her how much she loved hers, so she was willing to take a look at them. As soon as she mentioned Mazda, I seized the opportunity to agree strongly with her coworker in hopes of steering her away from a small GM/Ford/Jeep/Dodge SUV. She drove a good condition used 2016 we found and liked it enough to buy it.
    I haven't met anyone who has been disappointed in theirs - I have a friend whose wife has around 170k on hers without any major issues. My mom bought an off-lease 2017 a few years ago after hearing about ours and another friend of hers' experiences with them. It's been good to her as well - I think the only issue she's had is a bad map SD card that caused the infotainment to act funny.
    jpereira2 likes this.
  19. Apr 16, 2024 at 4:34 PM
    TreeFortRichard
    Brian
    Looks like 300ft google maps
    GarlicFarts and HisDad[QUOTED] like this.
  20. Apr 16, 2024 at 4:51 PM
    Pugga
    Massachusetts
    That one's not it, the layout was different. You walked past the long rifle range and they had a pistol shed at the end, away from the parking lot. The long rifle range shot from an enclosed hut. Bostonbilly took me a while back, when I was new to firearms. I know it was a private club, but I don't remember what it was called.
