New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. May 19, 2024 at 7:11 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    I had been reading that - maybe I'll try to put one together today. I had read they don't like peppermint, so I sprayed some of stuff I use to repel mice. It did seem to work for a while, but since a shed is more exposed to the elements and less sealed than a house, it fades too quickly to keep up with it.
    My last shed had vents and it was never an issue, so I think you're onto something. This one doesn't - it's a little 4x8 lean-to that I built from a Lowes kit. I had been thinking about cutting spots to add some so it doesn't get quite as hot inside, but this is another reason to do that!
    These wasps keep building on the underside of the door header for some reason, haven't found anything in the eaves yet. I should have taken a picture before I took steel wool to it to clean it up this time, but it was funny - it looked like they went through about 100 attempts to start an attachment point before they were successful.
    Everything I read says "just seal the shed better" and that isn't super helpful because it isn't like we're dealing with a house door with weatherstripping and stuff - shed doors aren't usually designed to form a seal.
    I did read that rubbing bar soap on spots where they like to nest can work, and that they don't like citrus. I found some citrus bar soap today, so I think I'll give that a shot on the door header. Combined with ventilation and a fake nest, maybe if one thing doesn't work another will.
    tacobell007[QUOTED] likes this.
  2. May 19, 2024 at 7:21 AM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    I probably used the wrong term when I said "eaves." Where I had them in the old shed was right below the peak at the front of the shed over the doors. Which I think is where you have them. Put the vents there and it should solve your problem. Apparently, they don't like the air movement, so will nest in your neighbors shed instead of yours.
  3. May 19, 2024 at 7:58 AM
    js312
    Joe
    New England
    This one is a lean-to so it doesn't really have a peak like most sheds. I open the doors and surprise - wasp nest attached to the header. They get in and build there for some reason.
  4. May 19, 2024 at 10:45 AM
    HisDad
    Texas at last
    I would just put a vent above the door and if possible on the opposite wall.
  5. May 20, 2024 at 6:40 AM
    js312
    Joe
    New England
    Unfortunately I can't above the door - no space. If I do it, it'll have to be on the side walls.
    HisDad[QUOTED] likes this.
  6. May 20, 2024 at 6:45 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    What about setting up a fan in there blowing at it.
    Got the last one in my shed with the shop vac. Taped the hose to a stick and sucked them up. Works great on ground hornets.
    CTSpruceMica likes this.
  7. May 20, 2024 at 7:22 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
  8. May 20, 2024 at 10:25 AM
    js312
    Joe
    New England
    That's a possibility - I'd have to get power out there, though. It isn't actually attached to the garage in any way, so I just have a solar charging battery light in there now.
  9. May 20, 2024 at 11:58 AM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    Anyone selling some stock front coilovers for a 2nd Gen 4wd taco? My sister had a strut blow out.
    mach1man001[OP] likes this.
  10. May 20, 2024 at 12:01 PM
    GarlicFarts
    Lil Rhody
    @InCogNeatOh Parts
    He just did a lift this weekend, it's a 4runner but it's in the toyota family. Not sure what came off, just throwing out the thought.
    Darth_Yota[QUOTED] likes this.
  11. May 20, 2024 at 12:09 PM
    InCogNeatOh Parts
    InCogNeatOh Parts Well-Known Member
    We replaced front and back shocks and springs, plus front UCAs, they have just under 30k and less than 3 years old.
  12. May 20, 2024 at 12:52 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    I have a complete minus fasteners rear interior (everything - seatbel buckles, console, hinges, rear panel, seats, headrests, everything) for a 2nd gen Access Cab here, no rips or tears, little bit of storage dirt, sat in about three times before I pulled it for a dog deck like 10 years ago.
    Free for pickup, otherwise it's going away on the next bulky day at the transfer station.
  13. May 20, 2024 at 6:48 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Dumb question but any cupholders and if so what do the inserts look like?
    Merling likes this.
  14. May 21, 2024 at 3:40 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    He lives!!! We will hopefully be doing a swap out in the next 2 weeks for a 3rd gen set up replacing an oem set up with 6112s and the oem set up hopefully should be available. That is if you can wait a couple of weeks.....
  15. May 21, 2024 at 4:19 AM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    If the others don’t work out for you, I have a set from my 2011. They have about 60k on them and have been in the box on a shelf for a little while but you can have them if you need them.
  16. May 21, 2024 at 5:00 PM
    js312
    Joe
    New England
    I was cleaning out the garage and basement and put stuff on a table on the side of the road. I made a sign that said free stuff and taped it to the table. I thought about adding "but not the table" and thought nah, people won't be that dumb.
    I got home today and noticed the table was gone and a bunch of the stuff was just on the lawn. Looked back at the video and some lady showed up, took everything off the table and put it on the lawn, and took the table.
    It was only a $20 folding table so not a huge deal to replace it, but seriously?
  17. May 21, 2024 at 5:18 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I’d bet that the table would have disappeared even if you put a sign on it not to take it.
  18. May 21, 2024 at 5:37 PM
    js312
    Joe
    New England
    I thought it might disappear once everything else did, so I put one of the ones out that I liked the least. I was mostly surprised that someone dumped everything on the ground to take it.
  19. May 22, 2024 at 5:12 AM
    InCogNeatOh Parts
    Clearly you have too much faith in humanity
    HisDad, Merling, Pugga and 2 others like this.
  20. May 22, 2024 at 11:12 AM
    ABA180
    East Bridgewater MA
    We used to use small bins for recycling each week at trash day. I'd usually have a few returnable bottles but didn't bother to take them to the store. My recycle stuff was ending up on the lawn and one day I found out why..an older fellow collecting cans would take the bottles from my bin, but in the process knock a lot of other stuff out of the bin and just leave it on my lawn. I was home from work the next week on trash day and saw him do it..walked outside and politely told him if you ever touch that bin you better put back in the bin what you don't take or we have a problem.
    So yeah I don't have any real faith in people.
