New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Nov 8, 2024 at 1:59 PM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    How blown is too blown?
  2. Nov 8, 2024 at 3:54 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    That is too blown OR not blown enough
  3. Nov 8, 2024 at 5:02 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Blown but still drivable,
  4. Nov 8, 2024 at 6:10 PM
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Too blown is when it comes apart.
  5. Nov 9, 2024 at 3:17 AM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    Too blown is where the shaft goes in and out with zero resistance. It’s all used up, leaking all over the place. Hotdog down a shock body
    Think of the popular girl from high school
  6. Nov 9, 2024 at 3:35 AM
    Chasespeed
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Nah, that is blown out.....:spy:
    emelianenkov[QUOTED] likes this.
  7. Nov 9, 2024 at 4:13 AM
    emelianenkov
    Alex
    NORTH POLE
    Clapped out, perhaps? :notsure:
    Chasespeed[QUOTED] and jpereira2 like this.
  8. Nov 9, 2024 at 4:48 AM
    Chasespeed
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Hmmm.... i wanna say clapped is a lower level of... wear and tear?
    I mean, I've bought clapped out bikes, and such... but, never consider a blown out one...
    I dunno.... I guess it's all in perspective
  9. Nov 9, 2024 at 11:06 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Been working on the guest room at the real house. I don't have any before of the walls/ceiling because I was frankly just trying to get them done. Take my word for it - it was bad.
    Anyway, the paint save some dammits, cutting the top of the baseboards and trim, and the floor is done. I've been fighting the closet door for a while.
    The paint was the same as the hallway door and the trim but for some reason it had terrible adhesion, and when I went to start taking the top layer off, big chunks of multiple layers of latex came off, and that's when the side quest started.
    Here it is with the bulk of the latex stuff (5-6 layers) cooked off, and me realizing how much labor it was going to take to get the definition back out of the original beading in the four panels.
    Lots of work with a freehand box knife and 60 grit rolls.
    I put in as much labor as I cared to do, and got it sanded for paint and painted.
    Meanwhile, the door hardware, while old and solid, was mid century reproduction Eastlake style stuff - stamped steel brass plated and then later in its life lacquered black. I wire wheeled everything and set about with the treatment I decided to give it.
    20241109_111003.jpg 20241109_133812.jpg 20241109_133804.jpg 20241109_133819.jpg
    Parallel to this was the rehab of the floor register, before and afters as follows. Again, a solid piece, but a very good mid century stamped model and not, say, an original casting that I felt was worth preserving or correctly restoring.
    signal-2024-10-24-15-42-45-908.jpg signal-2024-10-24-15-44-18-838.jpg 20241109_134425.jpg
    Now that the door is off of the floor, I can take care of a few mysterious 6mm dents in the ceiling that have nothing to do with the 35 6mm plastic Airsoft BBs I found in the register, and get the new ceiling light installed. I have a couple of cast brass bulkhead lights from some ancient freighter. I had one all the way apart to see what would be involved in safely wiring them for an Edison bulb, and found that they had perfectly functioning ceramic Edison sockets in them that I was able to stick some THNN onto, along with a ground added via a self tapper in the fixture body.
    GarlicFarts, Pugga, HisDad and 7 others like this.
  10. Nov 10, 2024 at 4:17 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Are you sure that’s all latex? Careful with heat and sanding, that could be lead paint. It looks old enough.
    CTSpruceMica likes this.
  11. Nov 10, 2024 at 4:23 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    1918 advertisement
  12. Nov 10, 2024 at 5:06 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    That's with the latex mostly off - it was layers of white and beige, you can see the two panels still have yet to be heated and scraped. The older "malaise green" that you're seeing was, surprisingly, not leaded according to a test stick. It was very thin and sat on top of a very thin primer. I think it may actually have been milk paint put on in the 70s, based on the color. Same with the heat register, but some kind of enamel.
    CTSpruceMica and Pugga[QUOTED] like this.
  13. Nov 10, 2024 at 7:07 AM
    Pugga
    Massachusetts
    You’re on it, good that you’re using a test stick, you don’t want to heat and sand that stuff! I have similar doors in my house but it was definitely lead-based. I used a chemical stripper to de-lead my old doors and moldings.
  14. Nov 11, 2024 at 6:57 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    The photos don't do the light justice - it puts a nice warm glow really evenly through the whole room. 100% worth the couple hours of tinkering to adapt it and mount it.
    There are some touchups around the new fixture, but i'll take care of those when I take care of the couple other ceiling dammits
  15. Nov 11, 2024 at 1:06 PM
    wayne0
    wayne0 Well-Known Member
    Howdy all. Representing Danville, NH.
    2016 TRDOR-AC Silver sky metallic.
  16. Nov 11, 2024 at 2:48 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Welcome to the fun!!!
    Danville, you must be familiar with the Flying Wheels dealership...
  17. Nov 11, 2024 at 3:27 PM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    In Fremont right next to you. Travel down 111A through Danville every day.
  18. Nov 12, 2024 at 5:34 AM
    wayne0
    Pass it every day.
    ABA180[QUOTED] likes this.
  19. Nov 12, 2024 at 10:46 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    The tops of the baseboards need cut, but I'm going to make my sister the actual master painter do that. The plaster texture makes my novice hands nervous. Other than that, done and I'm happy with it.
  20. Nov 12, 2024 at 11:24 AM
    ABA180
    East Bridgewater MA
    I found Craig's YT channel when he was starting out, pretty interesting fellow.
    I forget, someone help me out.
    @wayne0 has questions about the frame on the 3G Tacoma, can someone give the crash course please?
