New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Nov 17, 2024 at 5:59 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    With the trees cleared and the trons bouncing off the tent frame I get just enough service go do text but not really get images out. I'll post em up later. I'm up at the spot getting the shitter dug and lined with my sister. It's always amazing to me how two people can get more than twice as much work done as one person if they know how to work together on the job.
    We've always worked really well together and I put most of the blame on spending a lot of time picking through the LEGO pile together. We know exactly how the other guy's hands are going to move and what they're going to reach for. I miss being able to do this more often.
  2. Nov 17, 2024 at 6:40 PM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Meh. They all suck in their own ways.
    I did like KAL though. They knew what was up. I've noticed DAL domestic was different than international, because they had to fight with Air France (BOS to CDL), so they stepped it up there.
    So that tells me they can, they just won't domestically, because profits.
    Turd Ferguson[QUOTED] likes this.
  3. Nov 18, 2024 at 7:39 AM
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
    There is a RAV 4 thread. Try posting your question there. https://www.tacomaworld.com/threads/rav4-owners-aficionados.755885/
    HisDad[QUOTED] likes this.
  4. Nov 18, 2024 at 7:45 AM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
  5. Nov 18, 2024 at 9:51 AM
    BostonBaja
    BostonBaja Active Member
    Ben
    NH
    2013 Tacoma TRD TX Baja 2005 Saab 9-2X Aero
    F&R LT
  6. Nov 18, 2024 at 10:13 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Theres a set in the barn. I prefer to wear my tires out axially instead of radially. I loose less ground clearance that way. You guys should try it
  7. Nov 19, 2024 at 1:40 AM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    Words too fancy. Got confused and installed cinderblocks for tires
  8. Nov 19, 2024 at 8:52 AM
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    Dads birthday, he was a big freshwater guy so I’m grateful to have gotten anything today
    would’ve preferred trout just didn’t have time to drive that far north to get to streams I’d think would have em
  9. Nov 19, 2024 at 9:31 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Put my ruffstuff order in. Does accutune usually have black friday sales? Wouldnt mind saving some cash on the shocks out back
  10. Nov 19, 2024 at 10:00 AM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    :jellydance:
    GarlicFarts likes this.
  11. Nov 19, 2024 at 10:05 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Oh you already have shocks, how about a ruffstuff order for you?:boink:
  12. Nov 19, 2024 at 12:09 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    crashngiggles and Brownmatthall like this.
  13. Nov 19, 2024 at 1:05 PM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
  14. Nov 19, 2024 at 6:33 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    20241117_154538.jpg IMG_20241118_163623.jpg 20241119_195851.jpg 20241119_203603.jpg
    Digging trenches and doing drywall wizardry. Feels good to get pro help.
    Merling, emelianenkov, Roody and 5 others like this.
  15. Nov 20, 2024 at 6:22 AM
    emelianenkov
    Alex
    NORTH POLE
    So far on our $2,000 WRX I’ve found:
    -Bad fuel pump (knew that when I bought it)
    -2 crossthreaded lug nuts
    -2 sheered lug studs (not the crossthreaded ones either!)
    -Weeping radiator hose
    -Massive exhaust leak from the catback
    -Clutch was replaced, but the flywheel is either warped or rusted. Shudders terribly under takeoff while using the clutch.
    -Vacuum leaks galore
    And the hilarious icing on the cake:
    -Rear O2 sensor came off, bung and all, with zero effort
    mach1man001[OP] and GarlicFarts like this.
  16. Nov 20, 2024 at 7:26 AM
    GarlicFarts
    Lil Rhody
    emelianenkov[QUOTED] likes this.
  17. Nov 20, 2024 at 7:59 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Does anyone know anyone that runs locked shocks? Its tempting to go for these instead of the Fox 2.0 LSC for $950
    BostonBaja likes this.
  18. Nov 20, 2024 at 8:24 AM
    emelianenkov
    Alex
    NORTH POLE
    Never heard of them. I wanted to run FOAs for a while but ended up with Kings.
    Might be good! At the end of the day, it’s just an aluminum tube with dampers and fluid. The name on the outside might not matter
  19. Nov 20, 2024 at 9:11 AM
    Brownmatthall
    2016 TRD OR DCSB
    I think the xterra loser runs them, dirt lifestyle is running them on the samurai build too I believe
  20. Nov 20, 2024 at 9:12 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    The green turd has rough countries up front and dobinsons in the back
