New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Feb 19, 2025 at 5:26 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Fact
  2. Feb 19, 2025 at 10:50 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    No expert re building, but I fought ice dams in the back of my house from the day I moved here in 2004. The ceiling in one of the 2 rooms wasn't insulated and i figured that might help but very little improvement. Both rooms have a vaulted ceiling as well.
    The roof is very shallow pitched, plus I suspect that the bathroom (which was insulated) wasn't built properly when it was added onto several years prior to my buying...since so many other things in the room weren't and some of it I could see as bad ideas even not being a builder of any kind.
    I would have to rake and/or shovel that half of the roof if I got more than 3-4 inches of snow, I finally reroofed with metal in 2021 and zero issues.
  3. Feb 20, 2025 at 3:04 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
  4. Feb 20, 2025 at 3:29 AM
    AllTacosFloat
    Boston ish
    About time! I’m looking forward to it
    super_white[QUOTED] likes this.
  5. Feb 20, 2025 at 6:00 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Heres my current ideas.
    That R36 adds from both layers. The rigid foam would be ISO and id use great stuff to seal all joints.
    Idea #2 would be to build some funky baffles that would go below the perlins and create the same 1" gap and either use blow in or fiberglass batts to insulate it all in.
  6. Feb 20, 2025 at 10:19 AM
    nuts4modela
    nuts4modela Well-Known Member
    chris
    chepachet RI
    2019 blue trd pro,2019 4runner trd pro
    I don't think that allows for enough ventilation
    AllTacosFloat and Pscdouglas like this.
  7. Feb 21, 2025 at 12:58 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Rigged up an arbor press to take hole chisels. Way better result and also faster. Still not using electricity so I don't think the spirit of the work has changed.
    Zippers are still a nightmare to saddle stitch though. The inner line took almost 4 hours. If you punch the zipper body with the chisels, it cuts fibers which weakens the zipper. I use oversize blunt needles, which push through the weave, but on tough nylon body zippers like this that's a lot of effort and the loop on the thread catches hard every time.
    CLC makes decent nylon zipper pouches, check Amzn.
  8. Feb 21, 2025 at 1:48 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    KYB strut mounts. Big washer on the top or bottom?
  9. Feb 21, 2025 at 2:24 PM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    big washer on top, bevel cupping the bushing-
  10. Feb 21, 2025 at 2:26 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Thank you. So it's just like factory.
    hyrule_trd[QUOTED] likes this.
  11. Feb 21, 2025 at 2:28 PM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Yep, well, at least I’ve not seen any different… of the two brands I’ve seen taken apart, Bilstien and Ironman.
  12. Feb 21, 2025 at 2:55 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I haven't pulled anything apart. I was just wondering when I saw the different sizes.
  13. Feb 21, 2025 at 4:39 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    I am through almost 3 tons of pellets and 200 gallons of oil. That has usually been enough to get me through the entire winter. I have one more ton of pellets so I should still be good but I was kind of hoping I would have some left over.
    Clark27 likes this.
  14. Feb 21, 2025 at 5:54 PM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    I must be close to 1000 gallons of oil :annoyed:
  15. Feb 21, 2025 at 6:00 PM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    I think I’m at 2.5 cord and like maybe 50 gallons of oil. We have that set to like 50
  16. Feb 21, 2025 at 6:05 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    I don't miss buying heating oil at all. We had a heat pump installed and it's worked fine this winter even on the coldest (teens) nights. Haven't turned on the emergency heating strips even once.
  17. Feb 22, 2025 at 4:37 AM
    js312
    Joe
    New England
    My pellet stove is a fireplace insert in the living room, so it's tough to circulate the heat through the entire house. I keep the boiler at 68 and it will usually run a bit every morning and occasionally throughout really cold days.
    I have an 18,000 BTU mini split but I only use it for A/C. It does a decent job heating, but our electric rates are really high so it would probably cost me more than oil and pellets if I used it regularly.
    HisDad[QUOTED] likes this.
  18. Feb 22, 2025 at 6:36 AM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    My house's HVAC is a nightmare.
    The oil forced hot air furnace feels undersized for the house. I have an attached family room with vaulted ceilings that yes, has leaky winodws but is always 6-10°F colder than the main house. I've choked down every vent in the main house to try to force hot air into that room and it still doesn't seem to help much. The previous owners widened a doorway to the dining room which cut the heating duct to our master bedroom. The solution was to cut holes in the floor of the master to let heat rise (stupid stupid stupid).
    In 2021 I added a Mitsubishi HyperHeat system, a ducted unit in my attic that controls the second floor and has some drops to the first floor as well as a ductless head in my family room. It's integrated with the heating system. From a heat standpoint it works great when it's on, at the cost of $600/mo electric bills (so much for being cheaper than oil like they said). The integration means that the temperature point in the family room is the control point for the oil furnace when it's too cold to run the main system, meaning to get 68°F in that room my house is at 74-78°F elsewhere, so I disable it.
    Also, I'm 99% sure the AC is either sized wrong, or filled wrong, or they did a horrible job explaining to me how it could work. I'm used to the old style AC where it's 110°F outside and you set your house to 64°F, you're getting that at the expense of your electric bill. There are times in the summer when it swings up past 90°F and my house can't get below 78°F even with the thermostat set at 70°F. I was told if I can get a 15-20°F ambient to inside swing I'm going great, and yes, I get that, but I don't get why it will start the day fine but as the day heats up it's like I'm just losing power. I'd expect the unit fan to start going full blast and it will barely be moving. I've had the HVAC company out more than once to complain and they're like "it just is". Honestly, the day the start-up guy came I remember distinctly him not wanting to be here and complaining the whole time. I just have this feeling the refrigerant isn't correct and that they're just ignoring me since it's still a warranty call.
    I'm just sick of my house either being a sauna or a fridge in the winter and then a sauna in the summer. If the temps are 45-85°F it's perfect, outside of that and I'm grumpy (simply because I paid a lot for the system).
  19. Feb 22, 2025 at 7:19 AM
    js312
    Joe
    New England
    I have a 1500 sq ft ranch and my 18,000 BTU mini split is enough for the whole house as long as we use it to maintain. Like the pellet stove, the biggest limitation is circulation (walls/distance from the unit since it's in the living room). We have to cool the living room a little more than we'd like to make everything else comfortable. If we set it to 68, the kitchen and dining room will be around 70 and the further away rooms, like my mud room/office and the bedrooms tend to hover around 73. We do keep a small window unit in our bedroom so we can keep it cooler for sleeping without making the rest of the house uncomfortable.
    I find that even when it's mid 90s and humid outside (hottest it gets here), it appears to be idling about as low as it can to maintain those temperatures. If we're gone and have it off and the house creeps up to 80 it takes a long time to get it back down.
  20. Feb 22, 2025 at 12:40 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    This punch press is a game changer.
