New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jul 4, 2025 at 4:40 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    If the bicycle shop is open tomorrow, I might go bug them about options for the 29er. Swapping out a cassette, crank cog and chain should be easy and cheap.
  2. Jul 4, 2025 at 4:41 PM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
  3. Jul 4, 2025 at 4:47 PM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
  4. Jul 4, 2025 at 5:03 PM
    replica9000
    2019 T4R ORP
  5. Jul 4, 2025 at 6:59 PM
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    I've had mine running in the basement for.... 6 years I think? Maybe 7?
    Anyway, when I get home Sunday, I can upload a tag on it if you want. Mine is set up to drain to the condensate pump for the 1st floor air handler.
  6. Jul 5, 2025 at 3:09 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Fair warning, half of what I did would make a bike shop like. Some bike shops are really big on compatibility and will tell you certain setups won’t work because the manufacturer doesn’t specifically say it will. Changing the cassette, they may try to get you to change the derailleur and shifter also. Changing the chainring could lead to a new bottom bracket and crankset, with all that you could be into some real money.
    HisDad and Chasespeed like this.
  7. Jul 5, 2025 at 3:40 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    I did a project for school using R to show gear ratio overlap with a 1 by conversion and then lost it.
    https://www.mtbr.com/attachments/gearing-chart1-jpg.1895930/
    But this is pretty much the same thing.
    https://www.mtbr.com/threads/tech-deep-dive-on-1x10-narrow-wide-conversion-gearing.1170101/
    When you set up a 1 by conversion you can kind of tailor it to your needs. It was actually one thing that road didn't take up. Road is all disc nowadays but they tried 1 by for a little bit and all the pros went back to a 2x8 or 2x10 depending, so they dropped that out of road bikes.
    That swap is super easy DIY, drive line alignments are a PITA but easy, just tedious. Easier with a 1 by though.
    It's similar to a vehicle nowadays - what corporate says will work is the only option for dealerships, which is why spark plugs on a turd gen from the dealership makes you disassemble half the engine, when you could just finagle it instead. Insurance and warranty and yadda yadda.
    Bikes are $$$$ nowadays, too. There's not much left on low end low range bikes. You go from Walmart to $$$$, nowhere in-between anymore, so I'm sure that's part of some shops being strict on that kind of thing.
  8. Jul 5, 2025 at 6:54 AM
    replica9000
    2019 T4R ORP
    When I bought my current mountain bike back in 2014, a 26" 24-speed was still normal. I don't need a 1x drivetrain, but all of the current mountain bikes are 29" 1x drivetrains. Top speed isn't really the focus of those bikes, so they come with 30t/32t chain wheels.
    Shimano has a 28/38/48 version of my current crankset. It's like I'd be losing 1st gear, but gaining 25th gear relative to the 24/34/42 crankset.
    If I bought the 29", and swapped the 30t for a 48t chain wheel, it would have a similar range except for the very low end for climbing. I also realize I'd have to pedal a bit harder to reach the similar speeds on a 29"
    These are the number using the calc linked several posts ago.
    Code:
    Gear Inches 26"
         Stock       |  Upgrade
         24t 34t 42t |  28t 38t 48t
    11   53  75  92  |  62  84  106
    13   45  63  78  |  52  71   89
    15   39  55  68  |  45  61   77
    18   32  46  56  |  38  51   65
    21   28  39  48  |  32  44   55
    24   24  34  42  |  28  38   48
    28   21  29  36  |  24  33   42
    34   17  24  30  |  20  27   34
    Gear Inches 29"
       Stock | Upgrade
         30t |  48t
    12   67  |  107
    15   53  |   85
    18   44  |   71
    21   38  |   61
    24   33  |   53
    30   27  |   43
    37   22  |   35
    46   17  |   28
    I suppose a gravel bike has a drivetrain more of what I'm looking for, but they seem to be more $$$ and I'm not a fan of the road bike handlebars.
  9. Jul 5, 2025 at 7:29 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Jason, where are you using your bike to be regularly out pacing the gearing?
  10. Jul 5, 2025 at 7:48 AM
    GarlicFarts
    Lil Rhody
    Tire sizes being a bit different so gear ratios are also a bit different, but there are plenty of flat bar gravel bikes out there.
    https://www.specialized.com/us/en/s...MIs6z6tfqljgMVH05HAR0RMRvEEAQYBCABEgI72vD_BwE
    Or if you do want some semblance of suspension, hard tail flat bar.
    https://www.specialized.com/us/en/r...MI5OWE4_qljgMVF2ZHAR1J_w0DEAQYASABEgJn2vD_BwE
    I don't care about specialized up or down, they're fine, just coincidence that they were both specialized from Google.
    Everything has gone to 1 by for clearance and simplicity, and opens up a spot for a control on the handlebar for a dropper post. Even my commuter bike is a 1 by for simplicity. I honesty couldn't tell you any gear ratios on that thing. She's cheap and rugged, and gets me to and from work and the stores easily.
  11. Jul 5, 2025 at 7:53 AM
    replica9000
    2019 T4R ORP
    There's a bicycle trail near me that goes from Cranston to Coventry, and there's also this one that I've ridden from Woonsocket to Cumberland.
  12. Jul 5, 2025 at 9:14 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    Like it...especially when I listened on my system and not on my tablet. That let me hear the bass line.
  13. Jul 5, 2025 at 9:26 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Reminds me of how Toyota would say I can't just swap in the delay wiper stalk and have delay wipers. They are not in that part of the business.
    And yes you can get spendy quick there.
    Me I'm just over here with my single speed bike, though some DO have a quick change spider and chain ring up front..does that count?
    Pugga[QUOTED] and GarlicFarts like this.
  14. Jul 5, 2025 at 12:10 PM
    Pugga
    Massachusetts
    Check out Poseidon bikes. I have one of their redwood models with the drop handlebars but they make flat bar versions also. They’re reasonably priced and a good value for what you pay. I’m pushing 3k miles on mine, I’ve abused the frame and upgraded everything but the way it came, out of the box, it was a great build for the price.
  15. Jul 5, 2025 at 5:43 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Got my bracket from @TacoTuesday603 today
    Tracking said Monday. I'll have to wait until Monday anyway as my drill/drill bits are at work.
  16. Jul 5, 2025 at 6:59 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I took the family to swank resort down the Cape for a long weekend for my wife's birthday. This place is super nice. I'm not used to going to a place with turn down service!
  17. Jul 6, 2025 at 6:17 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Idk what it's called (maybe cabana person) but when you go to the pool you check in and a employee grabs two sets of towels for each person. They bring you down and setup your longue for you. One towel is fitted to go over the cushion and the other one is for drying yourself after swimming. The drying towel is about the size of a twin size bed.
  18. Jul 6, 2025 at 7:03 AM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I think I've officially hit old man status (again).
    I don't mind fireworks from sundown until 11:00ish. Yes, I feel bad my kids are hiding scared because the house is shaking, but it's the weekend around the 4th and is to be expected. Lighting off fireworks at 1:30-2:00 AM is a bit inconsiderate, no?
  19. Jul 6, 2025 at 7:39 AM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Well la de da...
  20. Jul 6, 2025 at 8:50 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I know right? Lol!!!
    I asked an employee where to get ice and a few minutes later a person was at our door taking the ice bucket and getting us ice!
    CTSpruceMica[QUOTED] likes this.
