New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Mar 30, 2013 at 6:18 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Awesome thanks for you help mike. I am going to go with 25a and 12 gauge to be safe.
  2. Mar 30, 2013 at 6:29 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    Mike i have been copying you posts and saving them in my notes in my phone for reference haha, so i wont have to many more questions, you covered most of it. Althoughhh i was wondering one more thing. You said i have to make sure the add a circuit is oriented the right way, and i qoute
    Power should travel up the left pin in the picture above, across the fuses, then either back down the right pin or out the wire. You need a test light or some where to know which side of the fuse power is being fed to. If you install them backwards, they will still work, but power then has to travel across the bottom fuse, then across the top fuse and out the wire. Essentially, your bottom fuse would then be carrying the load for the original circuit and the new circuit and could become over loaded. Then, if the bottom fuse blows, you lose both circuits.
    If installed correctly, the stock circuit would be protected by the bottom fuse and the new circuit would be protected by the top fuse. You could blow either fuse and the other circuit would still be in tact and functioning.
    You said i need a test light? Or can i use a volt meter to make sure it is installed correctly?
  3. Mar 30, 2013 at 6:30 AM
    Stewtopia
    Stewtopia Member
    MA
    TRD Off-Road
    Thanks for the pic, our trucks are very similar. Cool to see what they would look like!
  4. Mar 30, 2013 at 6:41 AM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    I'm running my 42 with a 20a fuse
  5. Mar 30, 2013 at 6:42 AM
    emelianenkov
    Alex
    NORTH POLE
    Find the 4Runner haha. 104 trucks in total!
  6. Mar 30, 2013 at 6:44 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I said a test light because you can figure out what side of the fuse is the feed and which part goes to the accessory. I suppose you could make it work with a volt meter, you just need to figure out which side is the hot side of the fuse block so you can install the add-a-circuit correctly.
  7. Mar 30, 2013 at 6:45 AM
    Pugga
    Massachusetts
    Too easy... front and center.
  8. Mar 30, 2013 at 7:32 AM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    Trans gear oil was nasty YUCK
  9. Mar 30, 2013 at 7:34 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    I got lucky, my buddy who builds cars was in advanced auto when i went in to buy electrical stuff and he walked me through it.
  10. Mar 30, 2013 at 7:35 AM
    Pugga
    Massachusetts
    Nice! :thumbsup:
  11. Mar 30, 2013 at 7:35 AM
    evanmb31
    evan
    connecticut
    09 trd off road
  12. Mar 30, 2013 at 7:45 AM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    You could stuff a watermellon in there and not even clog it :eek:
  13. Mar 30, 2013 at 7:59 AM
    Pugga
    Massachusetts
    So many inappropriate jokes come to mind :eek:
  14. Mar 30, 2013 at 8:13 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    Whenever i see those trucks with huge stacks im tempted to throw shit in there haha
  15. Mar 30, 2013 at 8:19 AM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    i smell horrible
    changed diffs, t case, trans all redline MT90 redline
    flushed brake fluid all new
    changed oil
    bled and changed clutch fluid
  16. Mar 30, 2013 at 8:23 AM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Ill never do that trans again I'd rather pay someone. Filling it was a royal bitch. The hose blew off and I got an eye full of gear oil. Does hurt it feels really weird. Truck feels like new and It should for $300 in fluids
  17. Mar 30, 2013 at 8:51 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    That's what she said
  18. Mar 30, 2013 at 10:51 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    This might be a stupid question, can i ground wires or maybe even multiple wires to an existing ground point, like where the battery is grounded.
  19. Mar 30, 2013 at 10:52 AM
    aidenhardcore
    aidenhardcore Well-Known Member
    mike
    boston,ma
    2017 trd off road
    None yet but soon all black.
    Saw this on the highway. Putting it to good use.
    EA7E7DDA-2667-449D-904D-9012B0BA492D-682_a60a1a74ffddfdc728466af120939aeacd04db41.jpg
  20. Mar 30, 2013 at 11:05 AM
    Pugga
    Massachusetts
    Sure can. Actually, using a known good grounding point can really help with trouble shooting.
