New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Apr 2, 2013 at 4:44 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    Camber and toe should be at zero
    Caster around 2.5
    Your truck wanders to the right ?
  2. Apr 2, 2013 at 4:46 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Your most recent alignment looks about as good as you're going to get with stock UCA's and that lift. If it drives fine, I'd leave it be. The problem is the stock UCA's aren't adjustable so all the adjustment needs to be done with the LCA alignment tabs. On a lifted Tacoma, you run out of adjustment which is why you end up with good camber and toe but can't get the cast number high enough. You can trade off camber to gain more caster adjustment but that will just cause you to wear your tires more and also why you see some lifted trucks with their front tires looking like this \ /. LR UCAs allow you to set the tow and camber using the LCA alignment tabs, then adjust the caster separately using the UCA. Gives you a lot more freedom.
    :jellydance:
  3. Apr 2, 2013 at 4:47 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    David, LR UCAs are adjustable and can add up to 4 degrees caster, but something doesnt seem right, your caster is very low and in most cases you dont need to add more than 2 degrees caster with UCAs. You can also adjust camber with the LR UCAs which might make it easier for the alignment techs.
    Heres a good link for the light racing UCAs, click on the links for installation instructions and FAQ
    http://www.spcalignment.com/compone...Tacoma&year=2005+-+2013&from=USAFrom&to=USATo
  4. Apr 2, 2013 at 4:51 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Jealous!
  5. Apr 2, 2013 at 4:52 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    Coming from a guy who just purchased a WHAT ????
    I kept my POS 1st gen and sold my Ridgeline on YOUR advice :p :cool:..
  6. Apr 2, 2013 at 4:58 PM
    eborgie
    eborgie No Yotas Here
    Erik
    Bellingham, MA
    2023 Bronco Sasquatch
    I believe it's a fourth gen pickup. Haha. I had to take the shot at Miguel since he always takes them at the second gens.
  7. Apr 2, 2013 at 5:01 PM
    UrPebkac
    UrPebkac Well-Known Member
    David
    RI
    2016 GMC SIERRA
    John:
    yes ever so slightly. I am thinking it is the .8 camber...
    Mike:
    So I am def limited by the stock UCA.. but is it suppose to be in the negative??? and it is obvious that they can adjust it even more so with the second reading @ -3.7
    Evan:
    Looks like down the line LR UCA are in my future... Darn.
    Overall I should really correct the .8 camber on the front right to help reduce the wear...
    Anyone take a look at my rear alignment on the last image?? this is what is making me think their machine was off. I know my center pins are not sheared...
    And thank you all for your help!
    David
  8. Apr 2, 2013 at 5:06 PM
    snoope
    OK, I will give you that...not even a Tacoma....:rolleyes:
    And thanks for the advice ;), Connie is so in love with the ES , I might break the bank this season on the Tacoma...come on overtime :thumbsup:
    Miguel "LOVED" 2ND Gens until they broke...it will take a little longer for the 1st Gen to break but then what ?? A Nissan or a Jeep ???
    Miguel, here is a set of wheels & tires for you....the only one that trys to change tires more than you :p :D
    http://nh.craigslist.org/pts/3714161973.html
  9. Apr 2, 2013 at 5:09 PM
    eborgie
    Erik
    Bellingham, MA
    I have a couple maybes.
  10. Apr 2, 2013 at 5:16 PM
    Pugga
    Massachusetts
    I wouldn't put too much weight into that second read out... You even said the truck drove like shit so there was obviously something that was seriously wrong. I doubt that tech knew what he was going so I would use that read out for kindling and don't give it a second thought.
    The caster should be positive also... Sorry, I wasn't paying attention to that. I'm not sure why, or how, they are coming up with a negative caster. I wouldn't have thought that to be possible.
  11. Apr 2, 2013 at 5:17 PM
    johnnym
    john
    NH
    He could just pm mike . That's his add .
  12. Apr 2, 2013 at 5:24 PM
    snoope
    Mike must be working, no come-back.. ....even posted his truck "dirty" for the ad :eek:...
  13. Apr 2, 2013 at 5:25 PM
    Trail Squirrel
    Trail Squirrel Well-Known Member
    Jon
    Salem, MA
    11 TRD Off Road & 86 p/u w/350
    Question about my trail rig again. I'm looking to change my water pump, thinking about going electrical, anyone know advantages vs disadvantages?
  14. Apr 2, 2013 at 5:25 PM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    I'll give him $600 for that truck
  15. Apr 2, 2013 at 5:52 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    22re? It's easy enough to change. About a day of work going slow, and you don't have to remove the head.
    Edit: check out this link:
    http://www.4crawler.com/4x4/CheapTricks/EngineMods/TimingChain.shtml
  16. Apr 2, 2013 at 5:59 PM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    SBC 350. Electric from a crown Vic will cool it off wonderfully. You can do a thermostatic control so it's all done for you or have it on a switch HI off LOW. I like it switched because its less prone to fail.
  17. Apr 2, 2013 at 6:00 PM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
  18. Apr 2, 2013 at 6:09 PM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    Applying to New College in Florida. Woo! Worked things out with Sarah and we're feeling good about it :)
  19. Apr 2, 2013 at 6:13 PM
    09Tacomania
    09Tacomania Well-Known Member
    Scott
    Little Rhody
    09 Silver Streak Dbl cab 4x4
    Icon CO's, LR UCA's, Icon rear 2.0 rear resi's, Wheelers 1.5" 3 pk aal, blacked out badges, Andre's devil horn's, Extang tonneau. Oem racks
    Was that at Warwick Mall location ? I went there and the tech, an older guy gave me the exact #'s i asked for. I do have LR UCA's. My caster is at 3.0*
  20. Apr 2, 2013 at 6:14 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    That's right. And it's in his little avatar box thing on the left of the screen.
