New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Apr 11, 2013 at 2:44 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Noticed today that my door jamb says recommended tire pressure is 29 PSI, yet the light comes on at anything less than 35 PSI.
  2. Apr 11, 2013 at 2:45 PM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    So slow here today. I've installed gay mudflaps and re wired a golf cart to 24v
    On this fishy looking car
    Golf cart
  3. Apr 11, 2013 at 2:48 PM
    replica9000
    2019 T4R ORP
    Thought you worked for Ford? Closest thing you've shown off is that Mazda.
  4. Apr 11, 2013 at 2:57 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    Wut.... I have my tires set at 28. You must have the worst bumpsteer ever...
  5. Apr 11, 2013 at 3:00 PM
    replica9000
    2019 T4R ORP
    Maybe because the tires are much larger than stock?
  6. Apr 11, 2013 at 3:02 PM
    650H1
    Michael
    VA
    I disabled my tpms system all together, but before I did that I never had an issue...
  7. Apr 11, 2013 at 3:05 PM
    replica9000
    2019 T4R ORP
    Disabled with no light? If so, how?
  8. Apr 11, 2013 at 3:05 PM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    I'm at Mazda for a externship for school.
  9. Apr 11, 2013 at 3:06 PM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pressure chamber. Aka pipe bomb.
  10. Apr 11, 2013 at 3:07 PM
    replica9000
    2019 T4R ORP
    I thought about doing that with a wheel barrel tire.
  11. Apr 11, 2013 at 3:08 PM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Mine are 29 and 26
  12. Apr 11, 2013 at 3:08 PM
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Do it
  13. Apr 11, 2013 at 3:11 PM
    650H1
    Michael
    VA
    Pull out HVAC control panel, unplug it and move it outta the way, look in the hole for a red box, pull it out of the hole, that is the tpms cpu. Cut the red wire, then splice it into the blue wire, but do not cut the blue wire. Also, leave enough room on the red wire when you cut it so you can re-wire it together in case you ever sell the truck. This mod puts + 5 ohms on the tpms system so it will read that all the sensors are fine thus no obnoxious tpms light. Was one of my first mods, I don't even have tpms sensors and it's been fine for over a year and a half...
  14. Apr 11, 2013 at 3:22 PM
    replica9000
    2019 T4R ORP
    Thanks for the info. It's funny that I don't have half of the electronics you other guys have, yet I'm still trying to disable the ones I do have :D
  15. Apr 11, 2013 at 3:22 PM
    64Wildcat
    64Wildcat Black Jeep of the family
    Denis
    New Hampshire
    2015 Rubicon
    Finally got the winch controls mounted and the solenoid relocated and wired up,now all i have to do is spool the synthetic rope.:rolleyes:
  16. Apr 11, 2013 at 3:23 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    What does bump steer have to do with tire pressure
  17. Apr 11, 2013 at 3:47 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    Nice box Dave .
    How much is your school discount ?
  18. Apr 11, 2013 at 4:05 PM
    650H1
    Michael
    VA
    Not sure if serious...
  19. Apr 11, 2013 at 4:06 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    On my truck you set your tire pressures then set the monitor to that press with the button under the steering column
  20. Apr 11, 2013 at 4:23 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Serious. Bump steer is when you change suspension geometry (lift/lower) which changes the geometry of the steering components. While turning/ suspension cycling the steering components can hit other components due to said change in geometry : bump steer.
