New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Apr 11, 2013 at 4:27 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    Not getting scientific, bump steer to me is when you hit a bump and the steering wheel jars itself... Caused by bad shocks and over inflated tires....
  2. Apr 11, 2013 at 4:29 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    That's just worn components
  3. Apr 11, 2013 at 4:41 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Tell ya what, ill overlook it if you sell me your slider for cheap:p
  4. Apr 11, 2013 at 5:24 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I'm assuming all 5 tires have to be around the same PSI for that button to work? At first I thought that button was to reset the light when it went off, and just never worked. So maybe I can pull the sensors from the tires, and while they all read 0 PSI, use that button to set 0 an acceptable pressure?
  5. Apr 11, 2013 at 5:26 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    :boink::rofl:
  6. Apr 11, 2013 at 5:30 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Re-calibrate it. No need to disable it. Just set your psi to what you want and hold the button to recalibrate it for 10-15 seconds. It should stay off as long as you don't go under that psi, pretty sure you can set it at whatever you want
  7. Apr 11, 2013 at 5:37 PM
    replica9000
    2019 T4R ORP
    So potentially I could set them all to 0 PSI and throw them in the glove box... I think there is a minimum though.
    This looks like a good thread for info
    http://www.tacomaworld.com/forum/wh...ts-i-e-winter-summer-street-off-road-etc.html
  8. Apr 11, 2013 at 5:41 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The light comes on when you go more then 3% (I think) from the set point. The set point can be whatever you want within certain limits.
    I'd like to know as well... they aren't related.
    That's called hitting a bump, not bump steer :D
    No, I believe there is a minimum and maximum that you need your set point to fall between.
  9. Apr 11, 2013 at 5:46 PM
    replica9000
    2019 T4R ORP
    Can't find an exact number, but looks like a good chance that minimum pressure is 25% less than the door jamb sticker.
  10. Apr 11, 2013 at 6:02 PM
    evanmb31
    evan
    connecticut
    09 trd off road
  11. Apr 11, 2013 at 6:04 PM
    650H1
    Michael
    VA
    Disable them... Takes 5 mins
  12. Apr 11, 2013 at 6:13 PM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Agreed. Had to run a set of wheels w/out TPS installed, so the dealership turned the nanny system off for TPS.
  13. Apr 11, 2013 at 6:15 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Push the button, takes 10 seconds. No need to disable them unless you swap wheels all the time or constantly air down and don't want to see the light.
  14. Apr 11, 2013 at 6:18 PM
    RI Tacoma
    RI Tacoma Well-Known Member
    Tim
    Phx sometime soon
    2011 Sport DCLB
    OME 885's, Derped FJ TRD Wheels, Hankook Dynapro's ATM 265/75/16's, Retro's, WeatherTech Liners, Fog Light Mod, Bak Flip F-1, N-Fab Steps, 20% Tint, complete stereo, heated mirrors, Katzkin seats!!
    ^ Agreed. If you swap out your wheels and dont have the TMPS anymore, disable them. But if everything is there, might as well use it. I pulled the LED on mine because I swapped wheels
  15. Apr 11, 2013 at 6:21 PM
    YOTA LOVER
    NH
    Dunno about you guys, but going from a 95 taco into a 2011 is a drag with all of the nanny BS. Traction control can eat my ass.
  16. Apr 11, 2013 at 6:24 PM
    650H1
    Michael
    VA
    2008 FTW
  17. Apr 11, 2013 at 6:24 PM
    RI Tacoma
    Tim
    Phx sometime soon
    2011 Sport DCLB
    Traction control can be annoying, but I shut it off it the roads have any snow. Nothing worse than trying to pull into traffic and having the engine cut out
  18. Apr 11, 2013 at 6:27 PM
    replica9000
    2019 T4R ORP
    I'll probably get around to it when I do the ABS disable mod. Not a big deal right now since I'm only running one set of tires.
  19. Apr 11, 2013 at 6:28 PM
    YOTA LOVER
    NH
    It's the pits. Then there's the automatic braking around aggressive corners. Like I don't hear tire slip. Friggin BS.
  20. Apr 11, 2013 at 6:28 PM
    evanmb31
    evan
    connecticut
    09 trd off road
