New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Apr 22, 2013 at 10:12 PM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    Well you never OFFERED it lol. Damn
  2. Apr 22, 2013 at 10:13 PM
    emelianenkov
    Alex
    NORTH POLE
    Thanks guys.
    Congrats on the risk Evan! I'm sure it'll payoff for ya man
  3. Apr 22, 2013 at 10:21 PM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    Good Luck Evan.......hope it works out for ya bro.:)
  4. Apr 23, 2013 at 2:23 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Thanks guys!
  5. Apr 23, 2013 at 4:23 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Dave, I'll take it if your giving it away.
  6. Apr 23, 2013 at 5:46 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Alex, looks nice! No nomming and fapping together... bad idea :cool:
    I'm really curious to see what you think of them after your first off road trip having come from 285's.
    Like my case? You mean LCA bushings?
    I love the look of 1st Gens with 235's! :jellydance:
    Side note, I'm going to replace all the idler pulleys, the tensioner and the belt on my truck. Probably order a new carrier bearing while I'm at it. I know that only one of the pulleys is likely the culprit but if I'm going get in there and start tearing shit apart, I don't want to get it all back together just to have it start squeeking again next month.
  7. Apr 23, 2013 at 5:51 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Could you confirm which one is noisy just to be sure it is not another it em such as the alt or ps pump
  8. Apr 23, 2013 at 5:56 AM
    Pugga
    Massachusetts
    Not yet, but I'm pretty sure it's an idler since the noise is RPM related and does not change when I turn the wheels (testing the power steering pump) or jack up the electrical load. I suppose it could be the crank or the water pump but it sounds like it's the top, driver's side idler (and it looks like it's wobbling).
  9. Apr 23, 2013 at 6:00 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Morning
  10. Apr 23, 2013 at 6:00 AM
    BostonBilly
    Easton
    I'm sure it is an idler or the tensioner cause they def dont last as lo ng as the other items.
  11. Apr 23, 2013 at 6:01 AM
    BostonBilly
    Easton
    Morning to you
  12. Apr 23, 2013 at 6:01 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    Morning
  13. Apr 23, 2013 at 6:01 AM
    Pugga
    Massachusetts
    That too. I figure if I'm going to replace one, the others can't be too far behind so it sucks to spend the money, but I'll keep the 'good' ones as spares, replace them all and get a new belt on there.
  14. Apr 23, 2013 at 6:03 AM
    Pugga
    Massachusetts
    Mornin'
  15. Apr 23, 2013 at 6:09 AM
    BostonBilly
    Easton
    Sounds like a good idea. Does it come as a kit or a package? How much is the setup
  16. Apr 23, 2013 at 6:15 AM
    Pugga
    Massachusetts
    I'm looking at buying Gates pulleys and a belt through Rock Auto. Everything is just under $200 but I'm rethinking the tensioner. Apparently you have to buy the whole assembly, not just the pulley. Doesn't sound like much but once again, Toyota in all their infinite wisdom make the tensioner assembly double as the mount for the alternator and the compressor... Seriously, did a fucking 5 year old design this setup?!?! :mad: If the tensioner isn't bad, I'm not sure I want to tear everything apart to get at it. It involves moving A/C lines which i'm sure have gotten brittle with age and could end up costing me a lot more money if I break or crack one. Horrible, horrible, horrible design and a big F-you to the asshat that design this setup. Probably the same dipshit that was responsible for designing the rear driveline and suspension :rolleyes:
    /rant, sorry :eek:
  17. Apr 23, 2013 at 6:16 AM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    The part that usually breaks is the one we don't have any extras of. :annoyed:
    After this you'll never have to replace an idler again.
  18. Apr 23, 2013 at 6:20 AM
    Pugga
    Massachusetts
    Damn right! I likely will not own the truck long enough to require a second set of idlers :anonymous:
  19. Apr 23, 2013 at 6:24 AM
    BostonBilly
    Easton
    Gotta love it. When I left vw and ended up with honda I hated hated hated working on them. Everything was crazy design. You had to break loose the motor mount to change a belt and the water pump was inside and driven with the timing belt. So when and if you changed the t belt you should change pump just because where it was and also if it seized you would strip the belt and bend a valve.
  20. Apr 23, 2013 at 6:32 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Not unique, my Oldsmobile had the same stupid design with the tensioner. I found that out the hard way, plus the $800 water pump that's buried in the back of the engine.
